    30 Watt Fishbulb
    32 Posts 11 Posters 3.9k Views 11 Watching
      ScottPara
      Cool concept but if you are going to have the lightbulb as the main focal point then a high poly lightbulb is a must.
      Scott
      Love the fact that some HATE my avatar.....
      • soloS Offline
        That's pretty cool and I must agree getting a higher polygon bulb will help, maybe just apply one iriteration of SDS to smooth it.
          princedragoncok
          Yeah I agree everyone. The bounces were already set at their highest, shadow quality not though. I tried 1 iriteration and in fact it worked the first time but I got greedy and went for 2 and messed things up. Now 1 doesn't seem work anymore (at least with regard to texture preservation).. will try again. Thanks for the feedback!
          • soloS Offline
            Hope you do not mind, I liked the idea so much that I thought I'd give it a go too.
            I used Vue for the render.
            http://img207.imageshack.us/img207/2756/fishbulbwc4.jpg
              If you plug the bulb in, an easy way tocook a fish soup... 😉
              • E Offline
                ENG. YASEEN
                **It's amazing idea and work ،In particular the 2th photo
                thank's**
                My Website:
                http://xyz4studio.blogspot.com/
                  princedragoncok
                  Not at all, v nice. Your fishbulb appears to be a lot more robust than mine! I have to say i'm interested in trying out vue. So a few quick questions for the vue master: whats the learning curve like? and which package would you reccommend (as there seems to be loads). Thanks
                  • EarthMoverE Offline
                    EarthMover
                    I think both renders would serve well with a touch of caustics reflection on the ground as the light passes through the water in the bulb.
                    Content Creator at Skapeup
                      Click Draw
                      Very nice renders both. When rendering, do you set the glass material to 0% opacity and reflection to 100%?
                      Jeff
                      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                        princedragoncok
                        Totally agree, but I don't think I have that option with Hypershot? correct me if I'm wrong
                        As far as I know, v-ray is the only renderer supporting caustics at the moment.
                        Jeff
                        Well with hypershot its simply a matter of applying a default glass material that comes with the program. If I was to make glass with Podium however I'd probably make a translucent material, set it to 10-15% opacity, and 85-90% reflection.
                          Click Draw
                          Well....I finally bit the bullet. I just bought VRay for SU. I'm feeling a bit sick all of a sudden. I better take next week off from work ...LOL.
                          Jeff
                            princedragoncok
                            Jeff
                            Nah your going have to work overtime now! V-ray is the benchmark so definitely not a bad investment. Learning curve is a bit horrible though, so brace yourself for a stressful first few renders. Hmm I'd actually like to try this current render out with v-ray.. or maybe let someone else do it - how about you clickdraw?
                              Click Draw
                              Sure PDC,
                              I'll give it a go for sure. I'm just waiting for my activation code via e-mail but once I have it I'm in! Post your model for me or PM me. Thanks for the chance 😄 .
                              Jeff
                              • soloS Offline
                                Jeff a Vray render of this would be great, nice one to sharpen your teeth on.
                                Vue does caustics too, I chose not to have them as they complicated the scene to much (looked very busy)
                                Vue's learning curve is hard to assess, I learned it so long ago, on version 4, it was easy as I only used it to create terrains for use in Max, and over time I started to learn it without trying to learn it. Vue is pretty straight forward really, the only difficult part is the node based functions IMO.
                                  princedragoncok
                                  Cheers for the info solo. The scene is available to everyone to download for seven days.
                                  https://www.yousendit.com/download/WnBSVWRqTStoMlVLSkE9PQ
                                    EarthMover
                                    Hey prince
                                    Thanks for sharing the model. I ran the bulb through SDS with 1 iteration and then gave it a go with hypershot. Render took about 3 min.
                                    • soloS Offline
                                      Vue again.
                                      http://img294.imageshack.us/img294/5427/fishbulbrg0.jpg
                                      added a 'green' one too.
                                      http://img172.imageshack.us/img172/172/flourescentvuese3.jpg
                                        EarthMover
                                        Pete, that's great!! The caustics make a world of difference. Did they add a lot of render time?
                                        • soloS Offline
                                          Actually it was faster this time as I reduced the radiosity (I had radiosity and skydome in first one) and slightly increased the ambience, so the render was slightly faster, I did enable the 'accurate caustics' in render settings.
                                            kwistenbiebel
                                            Glass and fluids in glass are extremely difficult to render in Sketchup (if not impossible).
                                            The normals are difficult to control.
                                            Here's my try, but it is completely wrong:
                                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/bulb-a.jpg
