    [Solved] My script keeps bugsplatting :(
    19 Posts 5 Posters 2.6k Views 5 Watching
      But it only loops through entities and adds it to the selection if it doesn't already contain that entity. Doesn't build a hash at all, even though I had plans for that for a variation of the tool.
      I wonder if it's because it's recursing method.
      Extract of the methods (contained in a module originally)
      	### FACES ### -----------------------------------------------------------
      	# --- Select Connected Planar Faces ---
      	def self.select_connected_planar_faces
      		sel = Sketchup.active_model.selection
      		original_face = sel[0]
      		original_vector = original_face.normal
      		self.get_planar_faces(original_face.edges, original_vector)
      	def self.get_planar_faces(edges, vector)
      		# Loop through all the edges...
      		edges.each { | edge |
      			# ...get the faces and add the planar faces we haven't selected yet
      			edge.faces.each { | face |
      				if face.normal == vector && !sel.contains?(face)
      					sel.add( face )
      					self.get_planar_faces(face.edges, vector)
        Maybe it crashes because the code run across the same entity so many times.
        Maybe if I build a list if all entities I've checked and make sure I don't check the ones I have I can avoid the crash. For whatever reason it might be...
          It appear to be the recursive part of the script. I just tried the Loop from Edge method I wrote earlier on a strip of 1x200 squares and that crashed as well.
          But I don't know how I can do this without recursive methods.
          Does this sound like a SketchUp bug rather than a script bug? I've not experienced any scripting languages that crashes on recursive methods like this.
          • scottliningerS
            scottlininger
            Hey Thomthom,
            Is this happening for you in SU6 or 7 or both?
            There were a whole class of what we called "iterator" bugs that we fixed in SU7. These had to do with looping across entities in models. This crash sounds like it's similar.
            Cheers,
            • Scott Lininger
              SketchUp Software Engineer
              Have you visited the Ruby API Docs?
              Yes. I was working with SU7, but I just tried SU6 and it happend there as well.
              I just did little recursing test:
              		@debug = 0
              		self.recursive
              	@debug = 0
              	def self.recursive
              		@debug += 1
              		puts @debug
              		self.recursive
              The script reaches 489 (last number I see in the console before SU splats.
              Doesn't seem to be related to iterating entities as this code simply is an infinite recursive loop.
              But it will be triggered easily when iterating over lots of geometry. 😞
              So I suppose this is one for the bug reports? Any preferred channel? Any way to track bug reports?
                Appears that deep recursing is a problem in many languages. http://stackoverflow.com/questions/233013/how-does-your-favorite-language-handle-deep-recursion
                  I refactored the code to an iterative loop instead of recursing.
                  		face = sel[0]
                  		vector = face.normal
                  		edges = face.edges
                  		while faces = select_connected(edges)
                  			# We now have a list of connected faces...
                  			edges.clear()
                  			faces.each { |face|
                  				# ...check each face if it's co-planar
                  				if !sel.contains?(face) && face.normal == vector
                  					sel.add( face )
                  					edges += face.edges
                  	def self.select_connected(edges)
                  		ents = []
                  		edges.each { |edge|
                  			ents += edge.faces
                  		return (ents.length > 0) ? ents ; nil
                  Success! Haven't run into any limits yet.
                  Basically: recursing is bad!
                    Matt666
                    I often use this method... 😞 😞
                    Frenglish at its best !
                    My scripts
                      Well, as long as you know that the recursing won't goo too deep it's ok. But when iterating over geometry it easily loops hundred or thousands of time which is when you end up with a call stack error.
                      When I was looking around for a solution of this I found some interesting reading that converting to iterative loops instead of recursing can be much more efficient.
                        Matt666
                        Yep. Iterative method can save time compared with the recursive method... But recursing is much more beautiful !!
                        My scripts
