    Kerkythea Echo
    17 Posts 7 Posters 2.3k Views 7 Watching
      ROQ
      Anyone familiar with use of Kerkythea Echo for rendering night-lighting in Sketchup?
        remus
        Is there anything more specific we can help with? thats quite a vague question...
          bubbalove
          I've done a couple of night shots in Kerky... what exactly do you want to know?
          "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
            perk
            I'm doing one right now.
              ROQ
              Thanks to you all for responding... I'm in the process of (I think) setting it up to work with SU-7. I finally deduced that the .rbs files, et al, needed to go into the plugins folder, and now I'm downloading material libraries from their site.
              I'm wondering if any of you might know what happens when, under the Plugins menu, I ask it to "Export Model"? Nothing happened other than it created an .xml file that I saved to a new KT Folder inside of the customer's main file.
              I thought I'd see my SU-7 model in a KT window, but it's not happening.
              Thanks for any "light you may shed" on this issue.
                bubbalove
                After it is done exporting it should ask you if you would like to open the model Kerky... you did download the Kerkythea exporter plugin for Sketchup, right?
                • F Offline
                  FenS
                  Hi ROQ,
                  i'm not sure if this is helpful, but if i export a model with SU, then an xml is generated (in the folder that i specify).
                  Even though i get the question 'open KT with exported file' (or something like that), KT is not opened automatically (some Vista-problem?), but if i start KT myself, than i can open the (xml)file that was created with SU (7) (you have to look in the right folder ofcourse) and than i can see my file in KT.
                  I hope this helps?
                  Qué sais je? there is still so much to be learned...
                    ROQ
                    Critical info I failed to mention: I'm on a Mac machine, not PC.
                    Hope there's someone that can provide the same excellent info for my platform.
                      bubbalove
                      Ahh... well I use windows so I won't really be able to help. I'm sure someone on here uses Kerky for Mac. You might try to go to the Kerkythea forums, they're just as helpful if not more for your Kerky problems!
                        perk
                        FenS
                        I always have the same issue with Kerky not opening that way and I'm still on XP so I'm not sure what the problem is.
                          ROQ
                          Didn't know there was a Kerky forum... I'll go there...
                          Thank you to all!
                          • daleD Offline
                            dale
                            If you open Kerkythea, pull down the "File" menu, select "Open" it will take you to your computers directory hierarchy. Find the file folder with your xml file in it, highlight it and tell Kerky to open it.
                            I have an older mac that I have to sometimes place the file in a folder that comes up in the file heirarchy (see attachment, I put the file in the Kerky models folder) because for some reason it won't take me back to my desktop. Computers, can't live with em.......
                            • FrederikF Offline
                              Frederik
                              😮 Surprised to see this... 😲 😲
                              Thought it would be easy to see in our web-site...?!? 😕
                              In the Google SU plugins folder you'll find a file called "kt_path.txt"...
                              Open this file using i.e. Notepad and make sure that the string is pointing at the right version of KT... 😉
                              (I.e. C:\Program Files\Kerkythea Rendering System\Kerkythea.exe)
                              Cheers
                              Kim Frederik
                              • F Offline
                                FenS
                                Great,
                                I will try this, thanks!
                                • F Offline
                                  FenS
                                  took me a while, but i just looked for this file, but the file doesn't seem to be there at all (not in my plugin-folder, or somewhere else on my computer)...?
                                  I can make a txt-file ofcourse, but should there be somethings else in it, besides the name of the correct directory?
                                  • FrederikF Offline
                                    Frederik
                                    And you're sure that you've downloaded and installed the latest version of the SU2KT plug-in available from our site...?!? 😕
                                    Cheers
                                    Kim Frederik
                                    • F Offline
                                      FenS
                                      I think so,
                                      downloaded/installed SU2KT3_0.exe the 29th of November,
                                      downloaded the lights.zip the 15th of December,
