    Rope on a Pier
    4 Posts 4 Posters 693 Views 4 Watching
      casey344
      Been lurking and learning here for a few days. My name is Casey, I am an estimator for a boat dock company in South Carolina. I have just recently been learning how to use Sketchup and absolutely love it. Thank you for all for the time you take to contribute here.
      I have a dock design I am working on. Our customer wants 1-1/2" Nylon rope (two separate runs, one on top of the other) run between the 6" x 6" posts supporting his stationary dock. I've worked at it for at least an hour and cannot seem to get anything to work. I have included an example including the rope I found in the library. We traditionally run the rope through the 6" x 6", if possible I need to make it appear this way as well.
      Any help or direction would really help me.
        remus
        Probably the best way to do this is by drawing the rope as a cylinder first (using the follow me tool) and then apply a rope texture to it. Its a lot easier than modelling the actual rope and saves hugely on the poly count of the model. If you want a tut, gives us a shout and i'll knock something up.
        • E Offline
          ELYSIUM
          Check TaffGoch tuturial on making ropes, i think it's the fastest and best way to do that.
          Error 404 (Not Found)!!1
          (sketchup.google.com)
          • TaffGochT Offline
            TaffGoch
            I don't know, ELYSIUM, my method is pretty tedious. While it's precise, it can take a lot of work. (My tutorial model was really an exercise to demonstrate the capability of SketchUp ... and somebody dared me!)
            For quick representation of a rope, I'd try the textured method suggested by remus.
            For quickly producing an actual twisted construction, I'd use the "Follow me rotate" plugin. See this discussion:
            http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12965
            So, Casey, now you've got several options!
            (...and we haven't even gotten into the catenary-sag issue, yet.) 😆
            Taff
            "Information is not knowledge." -- Albert Einstein
