    Create solid-appearing 3d models of a subsurface
    84 Posts 10 Posters 16.7k Views 10 Watching
    • GaieusG
      Hi GA,
      Yes, I saw the new registrant in the Admin panel and even thought it may have been you but couldn't make sure. You probably just didn't receive the confirmation email (sometimes these emails get blocked as automated emails often).
      Anyway, back to your question; right click on any of the three axes and choose reset from the context menu (click very precisely otherwise you don't get the menu).
      Also, when you imported your terrain mesh, select all, then the move tool, start moving and type [0,0,0] (or [0;0;0] if you have comma as a decimal separator) and hit enter. It will move everything to the origin.
      • G
        gealagie
        Great. Thank you. I may just leave all these terrain meshes (messes, really!) out in their distant space until i am sure I have imported all I'm planning to import. Then I may drag the lot of them as a group closer to original zero. I did not fully understand you, however. [0,0,0] while moving for the usual x-y-z import (would that be from a fixed-width columnar style import file as I used?). And then it's [0;0;0] for meshes imported with comma-separated import files? Semicolons for a comma file and commas for a fixed-width? Can I go "behind the scenes" and see how these meshes are stored?
        • G
          gealagie
          Gaieus--I did rightclick an axis, selected reset and the axes moved to what appeared to be close to the original zero. However, I tested by importing one of the TINs again and it was not coincident with it's twin in the model. My attempts to rightclick on the axis again will not bring up the reset option in the context menu. Are you sure the reset places it back at the original zero or does it back up only once?
          • GaieusG
            The comma vs semicolon means regional differences. With my Hungarian system, we use a comma to separate the decimals and a "decimal point"(well "period" or "full stop") to separate the thousands - just the opposite way than the English system. Many of the non-English systems work this way. So for "us who use a comma to separate the decimals" SU works with a semicolon when it comes to separate the co-ordinates. Sorry if I was misunderstandable.
            And yes, the reset puts the origin back to where it is originally. After resetting, the reset menu item is not available because there is nothing to reset.
            • G
              gealagie
              I have a couple layer questions. I have 40+ layers in this model. Each layer holds a single TIN terrain which has been grouped. I was very careful importing into this configuration.
              (1) Is there a way to toggle ALL layers on (or off) without clicking each in turn?
              (2) I'll select a group, and to remind myself which group/layer it is, I will right-click/Entity Info. Even though I know this group is in such-and-such a group/layer, the Entity Info popup will tell me it's Layer 0. Very disconcerting!
              • plot-parisP
                plot-paris
                (1) there are two ways:
                - create two scenes that only contain layer information. in the first you switch on all layers, in the second you switch off the desired layers. now you can turn the layers on or off simply by clicking on the scene tabs
                - you select all the layers you want to switch off in the layer window. when you now uncheck one of them, all the others will be unchecked as well. that approach is not as permanent of course, because if you reopen the file or need to check/uncheck a different layer, you will loose the selection.
                (2) are you sure that the group itself is on the layer and not merely the geometry within? if that is the case I would suggest to put the group onto the desired layer and put the raw geometry within the group back to layer0 (that won't change anything right now. but if you copy/paste some raw geometry from one group to the other, the chance of messing around with the layer assignment is smaller)
                • G
                  gealagie
                  I'll try those methods for (1). As for (2), it appears now many of the groups are contained on layer 0 and the elements of the groups as I intended are on the specific layers (I believe the opposite of what you suggested!). I apparently Cloud-imported the elements to their respective layers but grouped them while sitting in layer 0. I had intended for each TIN and its group to be neatly housed on a layer named to reflect the identity of the TIN. Oh well I'm sure it's no big deal to correct it now--just a nuisance! Thank you and the others for the help. I'll try to show some of this to you at a later date if and when I ever finish the geometry. Now then, I still have have a few rendering questions... 😉
                  • G
                    gealagie
                    I lost a group containing elements which i had worked long on and were finished. I probably deleted it mistakenly with a layer I was not aware it was associated. Now I still have this group in a past saved file and I would like to bring it--in place if possible (it abuts and matches perfectly to edges within other groups)--into the current file version of the model. I believe the answer to this may just be a matter of saving it as a component (something I read you guys do quite regularly once you've created, say, a furniture piece, that can be placed again in another model). I do not remember the tutorial videos showing exactly how one saves out components to a library for future use. I would like to know how, whether or not that is the simplest way to bring my group forward.
                    • Chris FullmerC
                      I think the fastest way is to open the model that has the group, select it and go to Edit>Copy.
                      Then open the file that is missing the group. And go to Edit>Paste In Place
                      It should just stick it right in the same physical location.
                      PS I'm really hoping to a screenshot or something soon 😄
                      • G
                        gealagie
                        That worked great. Thanks. I thought I had tried that once before without success, but I must have had layers or something set differently then.
                        Now I'm noticing something peculiar. 2 more of my groups just sort of went away. It could be I'm tied and making careless errors, but ???? I have 54 defined layers plus layer 0. Is there some arbitrary limit to the numbers of layers or groups you can use?
                        I WILL try to get you a shot or two when I have this just a wittle bit further along.
                        • Chris FullmerC
                          No, there's no limit to layers that I'm aware of. certainly wouldn't be near 54. Probably a simple careless mistake. are you using the outliner? I tend to delete or hide things too good when I use the outlines sometimes,
                          • K
                            kwistenbiebel
                            I would suggest trying Podium as it is probably the easiest render engine to start with.
                            As time is running out for you, you could ask some of the wizards here to render it for you.
                            I know Solo has a wide arsenal of tools both for tuning up the model as for rendering it.
                            But I leave it up to you to ask him....
                            • G
                              gealagie
                              Eeeek. What does it mean when a group turns RED?
                              • G
                                gealagie
                                Ok. I right clicked and Unlocked it. So what does it mean to be locked? Just dis-enables any modifications?
                                • GaieusG
                                  Exactly.
                                  • G
                                    gealagie
                                    Still something peculiar about that group. I selected all the groups in the project (with intent to rotate them all in unison), and now this trouble group (the one that was red and I unlocked) remains black instead of blue when the supergroup is selected and it fails to rotate with the supergroup. Any ideas?
                                    • GaieusG
                                      Hm. Try to edit it and see if its content i not locked (thinking of your unusual way of handling raw geometry on different layers within groups, I wouldn't be surprised) 😒
                                      • G
                                        gealagie
                                        Thank you. Editing it seemed to jog it out of its confusion.
                                        • G
                                          gealagie
                                          I would like to adopt the workflow you and others use. I believe you create raw geometry on layer 0 and cut/paste it to a layer you have defined. I have tried that and only in a few instances have been successful--I go where I want it pasted and find both Paste and Paste in Place grayed-out. Specifically, I cut or copy selected elements from layer 0 (typically the selection would be from a group so I would be in group edit mode in layer 0 with layer 0 active), close the edit on layer 0, activate the destination layer, and then find the Pasties grayed out in the pull-down menu! I'm doing something wrong.
                                          • GaieusG
                                            You still think of Layers like some "places" where you can cut and paste things from and into.
                                            Think of them like some kind of blinders instead which - when turned off - are shut and close your view from them. So to "put" something onto a different layer, just select that entity, right click > Entity info > and there just change the layer.
                                            If this raw geometry is within a group, edit the group, select all inside and follow the steps above.
                                            • 2 / 5
