    SU or ...? for hard surface modeling
    33 Posts 16 Posters 6.3k Views 16 Watching
      There is nothing that SU cannot do.
      Music? ๐Ÿ˜‰
      In fact maybe yes with SktechyPhysics ๐Ÿ˜’
      • soloS
        Music can be done, check out TBD's ruby 'suave.rb' add music to your model.
        • K
          kwistenbiebel
          Very nice solution Solo!
          You always come up with strategies that makes it all look so easy. ๐Ÿ˜„
          (A little crit: Is it possible to have a bit of rounding/beveling at the intersection between the sink and that big bump ?)
            Indeed ! ๐Ÿ˜ฒ
            http://labs.plugins.ro/suave.gif
            • soloS
              Thanks chris, here is one with faucet turned on. (if I remember correctly you did something similar using Podium)
              http://img116.imageshack.us/img116/6834/sinkpourzi0.png
                RustyShack
                The water is brilliant! And thanks for the details on your method--it's essentially what I came up with myself (ie the lathe operation and intersecting I mentioned). It's certainly acceptable, but not perfect, with the main culprit being the sharp edge where the bumpout meets the bowl of the sink (as kwistenbiebel noted).
                I hadn't thought using follow me, as dale mentioned (thx for the tip!), so I'll give that a try, although merging this with the rim of the sink might be tricky. Solo, you mentioned "more bevelling" that could be done--were you referring to improving the bumpout/bowl join? The other annoying thing about the sink is that the profile of the bevel on the top edge of the bumpout is much different than the profile of the bevel around the perimeter of the sink, creating another (to me) difficult situation when these meet. It seemed like such a simple object when I began!
                gksl4: Hexagon looks quite interesting: there's a Mac version, not to much $$, but I couldn't find a demo to try out. I'll do some more research and see what I can find.
                karlfucious: silo does look interesting, but it seems to be heavily slanted toward pure organic form and character creation, no? Would it be suitable to creating objects with purely regular (although somewhat complex) shapes? Whatever the case, the intro/tutorials on their website have made me look at my bank account closely. As spectacular as sketchyFFD is, to see the tweak tool (I think) in operation was amazing!
                • soloS
                  I did some bevelling where the 'bulge' meets the sink, I should have done some more as it's not very noticable, but my point being that SU can be used to model almost anything if one tries.
                  Are you needing this for a product display or is it for a bathroom design? If indeed it is for a product then I understand your need to total accuracy, and would suggest using the blue prints to get the dimensions right and maybe even using Rhino for the modeling. It looks very much like the Kohler Botticelli brand BTW.
                  Anyway, one last render (was playing)
                  http://img386.imageshack.us/img386/7477/sinkpour1ub1.jpg
                  • K
                    kwistenbiebel
                    that water splash looks more advanced than mine.
                    Is the splash itself also done using Skeytchup? (an extrude of a bezier curve, triangulating and subdividing it with the Subdivide'nd Smooth plugin?)
                    • FrederikF
                      Frederik
                      ๐Ÿ˜ฒ ๐Ÿ˜ฎ
                      Like Kwistenbiebel, I would also like to learn more about how you've done the water splash, Pete..!!
                      PLEASE...!! ๐Ÿ˜‰
                      Cheers
                      Kim Frederik
                        RustyShack
                        Thanks for the great renders--you spent much more time/effort than you should have. The sink is for a bathroom design and I agree that total accuracy is not needed for this project. The real motivation for my post, which I should have made clearer, was to find out if there was an equivalent to SketchUp for this kind of modeling--in other words, an easy to use and learn program that handles beveling, filleting and merging complex curves as easily as SketchUp handles rectilinear forms (and many curved ones). The more I look, however, the more it seems that SketchUp is truly unique in its combination of usability and capability. SketchUp will remain my modeling workhouse, but I'm trying to see what (if anything) I should add to my workflow to make life easier when encountering "difficult" objects that SU doesn't natively handle well. I see Rhino has demo and is working on a Mac OS version, so perhaps I'll spend some time on it.
                          sepo
                          That water looks very good Pete. ๐Ÿ‘
                          • sketch3d.deS
                            sketch3d.de
                            @rustyshack said:
                            ...in other words, an easy to use and learn program that handles beveling, filleting and merging complex curves as easily as SketchUp handles rectilinear forms (and many curved ones)....
                            check ViaCAD Pro f. Win/OSX, a feature-based NURBS surface and volume modeler w/ intuitive user interface, history tree as well as all common vector-based CAD filters incl. a SU import:
                            http://www.punchcad.com/
                            imho THE sleeper in this price range (MSRP 250 U$)
                            have fun,
                            Norbert
                            • Gus RG
                              Gus R
                              Rusty,
                              This actually can be done using subdivide and smooth. I experimented with some techniques I've already been trying and came up with a rather simple method using not the actual curves of the sink but the tangent lines of the curves. I used a circle for the plan layout with 24 segments. You can also use a polygon as long as the legs reflect the tangent lines of either a circle or elipse.
                              You also have to place control lines here and there as shown on the image and the attached skp file. These will go at the point of curvature for the arcs of the profile, etc.
                              Here's the skp for you or anyone else to study.
                              robatto sink.skp
                              This is using a circle. However, you can do this with an oval or an ellipse. It can also be done using 1/2 of a basic polygon.
                              I'm generating a KT rendering and should have one up any minute now.
                              Gus
                              www.instagram.com/gusrobatto/
                              www.facebook.com/gusrobatto
                              • Gus RG
                                Gus R
                                Here's the KT render. You should be able to see the fillet at the junction of the bump out and the basin.
                                Gus
                                • GaieusG
                                  Nice one, Gus! ๐Ÿ‘
                                  • Gus RG
                                    Gus R
                                    Thank you Gaieus. Guess my insomnia serves a purpose.
                                    ๐Ÿ˜„
                                    • daleD
                                      dale
                                      Yes great work folks, I knew this would be a fun one to watch. ๐Ÿ‘
                                        RustyShack
                                        Gus ....you nailed it!! cheers to you!!
                                        I agree--that looks spectacular and relatively easy to model. When I tried using subdivide and smooth initially, I could not figure out how to control the subdivision. I was trying to draw elaborate grids etc etc and nothing seemed to work. Never occurred to me that a few well-placed control lines like the ones in your model would do the job.
                                        I will give this a go later today and see how it goes.
                                        • soloS
                                          Oh yeah, Gus got it pretty right! ๐Ÿ‘
                                          Remember me saying it looks like a Kohler Botticelli?, well out of curiousity I went to the Kohler site and there it was, I attach a link below, scroll down and click on the 'for installers and designers' tab and a .dwg becomes available for download, it's the actual model which can be opened up in SU for you to use.
                                          Enjoy.
                                          Invalid URL
                                          (www.us.kohler.com)
                                          OMG!!! see the price ๐Ÿ˜ฒ
                                          • Gus RG
                                            Gus R
                                            Thanks guys. Pete, thanks for the link. I might try doing one to scale later since this one was eyeballed.
                                            Modelhead, for another $500 you can also get one (1) towel bar. Throw in a tooth brush/cup holder for another $500 and you can have all three for $6,000!
                                            ๐Ÿ˜†
