    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 306.8k Views 123 Watching
    • GaieusG
      Ah yes, unfortunately there are collisions sometimes between plugins no matter how careful (at least some/many of) the scipters try to be.
      To keep my SU "clean" a little bit from plugins I rarely (but sometimes necessarily) use, I rename the extension to something meaningless (my custom one is rbb) so they simply do not load. When I occasionally need them, I just change the extension back for that (or more) session(s).
      • CadFatherC
        CadFather
        Gaieus, alternatively you can put them into a subfolder and call/load them up from Jim's rubytoolbar script.
        • ton baetenT
          ton baeten
          I think I will go for some kind of 'Gaieus-solution'.
          Jim's Rubytoolbar is windows only, so not for me, unfortunately.
          I haven't seen any other subfolder-plugin-solution for the Mac (yet !!).
          greetings,
          Ton
          • OscarLokO
            OscarLok
            All 3 types boolean improved ! 18, Dec, 2008 ๐ŸŽ‰
            http://www.youtube.com/watch?v=EHTeNwZY0jA
            Newer version 15, Dec, 2008
            http://www.youtube.com/watch?v=wxnYpbXXKfY
            watch video from
            http://www.youtube.com/watch?v=LlIX3ZS25jk
            Oscar ๐Ÿ˜„
            [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
            • OscarLokO
              OscarLok
              Mary X'Mas & Happy New Year !!!
              There is a newer version(18, Dec, 2008) out in the first post! (with All 3 types of boolean improved)
              And, video in the second post!
              Any comment are welcome!
              Oscar ๐Ÿ˜„
                There is something with your last version of the 15! ๐Ÿ˜„
                SU 7 Splatch at any time and can't start! ๐Ÿ˜ฎ
                If I erase your plug all works fine ๐Ÿ˜‰
                All had working fine with your previous version โ—
                Install / uninstall same result!
                • B
                  blajnov
                  Oscar ๐Ÿ˜„
                  With this version, Google SketchUp 7 is not started in general ๐Ÿ˜’, normally works only from the first
                  • OscarLokO
                    OscarLok
                    And Now it should work, at least in my computer. ๐Ÿ˜‰
                    The script is in the first POST. There are old & new version.
                    Please give me more feedback after you try it. ๐ŸŽ‰
                    Oscar ๐Ÿ˜„
                      SU 7 is now starting ๐Ÿ˜„
                      Works fine with your test file โ˜€
                      Works not when I create myself the 2 boxes! ๐Ÿ˜ฎ (each box is a group)
                      Must have the Pro version โ“
                      Edit โ—
                      Works with my boxes, but I must save my file and reload it before use your plug! ๐Ÿ˜‰
                      Is that normal?
                      my_try01.skp
                        PS Another thing : you must draw something like an "egg timer" because user don't know if computer is calculating the boolean operation!
                          A curious thing! ๐Ÿ˜„
                          If the man is living that don't work! ๐Ÿ˜ฎ
                          PS Another thing : seems SU 7 works better for your plug than V6, is that normal?
                          my_try03.skp
                          • OscarLokO
                            OscarLok
                            Because the man is a component.
                            If you explode him, than it work.
                            At this moment, the stability is more important to me. I will include component in the future. โ˜€
                            • OscarLokO
                              OscarLok
                              Edit โ—
                              Is that normal?
                              It is not normal! Anyway, your download skp file is working fine!
                              I will try to do more testing!
                              • F
                                FenS
                                Hi oscarlok,
                                i'm looking at this thread and i am thinking that this might me the solution for what i was looking for, but i am not sure (somehow i think it might also be the functionality that i am nรณt looking for).
                                Is it somehow possible to merge 2 object, use your tool and get rid of all the parts that are not available in both objects?
                                I managed to create something with the letters F, R and @ (which in Holland sounds a bit like my name but it costed me a lot of deleting of the parts that i didn't need, i am wondering if this is possible with your creations without all the timeconsuming deleting?)
                                (http://www.youtube.com/watch?v=D2FEiWoAM6E)
                                Regards from Holland!
                                Fred.
                                Quรฉ sais je? there is still so much to be learned...
                                • OscarLokO
                                  OscarLok
                                  Hi Fred,
                                  Could you please upload your "Ready to Boolean SKP" (before boolean, but have model inside) here. So that I can test it!
                                  I am now holiday in China. And I will be back next year! ๐Ÿ˜‰
                                  Happy New Year
                                  Oscar
                                  ๐Ÿ˜„
                                  • F
                                    FenS
                                    Hi Oscar,
                                    sounds like a great way to spent newyear!
                                    I am not quite sure how to upload a skp yet, (and at this moment i am typing on another computer than the one on which i make my .skp's)
                                    but maybe i can write down how i did it? Maybe it is easy for you to replay?
                                    i create a square,
                                    i pushpull it up until i have a solid block.
                                    on the left side of the block i use the 'A' (write text) tool and just type the letter F,
                                    on the front of the block i write the letter R and i make this the same hight as the F.
                                    Then on top of the block i write down the '@' which i resize so it fits exactly (the hight of the '@' is the same as the width of the F and the (how do you call that in english? from left to right) of the '@' is the same as the (left to right) of the R.
                                    Then i pushpull all the object backwards as much as needed or even more.
                                    At this point (hopefully i have got this version on the other computer) i am ready to intersect and delete all the lines that i do not need, but i hope there is a faster way?
                                    I will try to find the skp on the other computer, the few coming days are very busy overhere so maybe a little silence from my part but in the meantime happy days and enjoy your stay in china!
                                    • P
                                      PRSS
                                      Hello
                                      To me the OSCoolean Beta(18-12-2008)is not working at all. It does nothing.
                                      In the ruby console I get the error message which i have attached.
                                      The previous ruby was working. Any clue?
                                      Thanks in advance
                                      with best regards
                                      PRSS
                                      OSCoolean Error.txt
                                      • F
                                        FenS
                                        Hi Oscar,
                                        i have recreated the .skp you were asking for.
                                        At this moment i have created a block 2000x2000x2000, inserted an F on the left side, a R on the front, drawn some help lines to the top and inserted the @ on the top and scaled it to fit between the lines (not exactly the right size but OK).
                                        I have pushpulled everything to the other side and normally now i would do a lot of erasing but maybe you know another way of doing this?
                                        Fred.
                                        FR@.skp
                                        • OscarLokO
                                          OscarLok
                                          @prss said:
                                          Hello
                                          Thanks in advance
                                          with best regards
                                          PRSS
                                          Is there any component in your SKP file, please?
                                          My script is ONLY working in group at the moment.
                                          Oscar
                                          • P
                                            PRSS
                                            Thank you for your reply Oscar. Yes the default face-me component Sang was there.
                                            Once I removed him, it works now. But it takes two to three times more time to do
                                            the operation than the previous first ruby script. But it is now working.
                                            Thanks once again
                                            With best regards
                                            PRSS
                                            • 15
                                            • 16
                                            • 3 / 16
