    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 251.8k Views 123 Watching
      ...The groups of interest (those I want to union or subtract etc) must be placed in their own seperate (temporary) file - as all other geometry is deleted !!!
      ๐Ÿ˜ฎ
      Good to know - I have only tested / played with it in (almost) empty models!
      • N Offline
        NewOne
        Hy! I get an error when trying to load the script. Is possible because of a vista-like patch that I have installed and changed some fonts.
        Error; #<SyntaxError; C;\Program Files\Google\Google SketchUp 6\Plugins\OSCoolean.rbs;1; no .<digit> floating literal anymore; put 0 before dot
        RBS1.0
        C;\Program Files\Google\Google SketchUp 6\Plugins\OSCoolean.rbs;1; syntax error
        RBS1.0
        Maybe is something that can be done to make the script working in this conditions?I don't know what is the last symbol in the error message.
        Below is what I see in npp.
        Thanks.
        this is what I see in notepad++
        • bagateloB Offline
          bagatelo
          Why don't know what our friend Oscar shares their plugins without the available source code, he shares them compiled. Maybe some could help him in the development.
          • ton baetenT Offline
            ton baeten
            Oscar,
            Thanks for a (probably) great script, but I cann't run it on my mac.
            Downloading the newest version results in a OSCoolean.rbs file.
            As could be expected, since the file-extension is rbs, it doesn't show up at all.
            Renaming it to OSCoolean.rb results in the following error-message:
            Error Loading File OSCoolean.rb
            /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/OSCoolean.rb:1: no .<digit> floating literal anymore; put 0 before dot
            RBS1.0
            /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/OSCoolean.rb:1: parse error
            RBS1.0
            /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/OSCoolean.rb:1: Invalid char `\030' in expression
            I very often use the intersect function to create complex 3d shapes and so this script would be very helpfull and time-saving for me.
            Any solution available ????
            Thanks for the help.
            greetings,
            Ton
            • OscarLokO Offline
              OscarLok
              Hi everybody,
              There is a newer version(15, Dec, 2008) out in the first post! (with intersect boolean improved only)
              Regarding "...The groups of interest (those I want to union or subtract etc) must be placed in their own seperate (temporary) file - as all other geometry is deleted !!!" and the rest matter...
              Will be settle in the last version.
              By the way, great to know that there is another New BOOLEAN script will be released soon !!! โ˜€ ๐ŸŽ‰
              Oscar ๐Ÿ˜„
              [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
                Ton, rbs files are just scrambled rb files and should run on Macs as well without any problem. If there is a problem, it is not in the extension or the fact that it's scrambled. The plugin should appear in the context menu, did you check it there?
                ๐Ÿ˜’ I've heard some rumours...
                We are all spoiled here too much... ๐Ÿ‘
                  ton baeten
                  Gaieus,
                  As usual you are right. The problem wasn't due to the file-extension.
                  Probably it was due to some other strange ruby interference. Yesterday I have been spending quite some time on copying many of my SU6 plugins to SU7. My SU6 plugins-folder contains about 136 items. So I decided it was/is time to really look into what I really need and what to keep, to get rid of duplicates and more. In fact a real mid-winter SU clean-up.
                  Oscar's 'new' intersection-plugin is one I really want and need. Installing it really didn't do anything, no trace anywhere.
                  That made me writing my 'contribution' to this topic.
                  Since this morning, the problem is solved. Oscar has approached me by PM offering me another download-version. I really appreciate that and have thanked him, but what might be more important, restarting GSU7 this morning was a complete disaster. What has gone wrong yesterday I don't know, but in the end I reinstalled a new clean version of GSU7 pro on my mac, downloaded Oscar's plugin as the first new entry in my 'virgin' plugins-folder and....everything works perfect.
                  I now start re-entering old plugins in GSU7 and will see what the result will be.
                  I have reported other strange plugin/ruby-interferences before, I just hope I don't have to report more.
                  If so, I will keep this community informed.
                  greetings,
                  Ton
                    Ah yes, unfortunately there are collisions sometimes between plugins no matter how careful (at least some/many of) the scipters try to be.
                    To keep my SU "clean" a little bit from plugins I rarely (but sometimes necessarily) use, I rename the extension to something meaningless (my custom one is rbb) so they simply do not load. When I occasionally need them, I just change the extension back for that (or more) session(s).
                    • CadFatherC Offline
                      CadFather
                      Gaieus, alternatively you can put them into a subfolder and call/load them up from Jim's rubytoolbar script.
                        ton baeten
                        I think I will go for some kind of 'Gaieus-solution'.
                        Jim's Rubytoolbar is windows only, so not for me, unfortunately.
                        I haven't seen any other subfolder-plugin-solution for the Mac (yet !!).
                        greetings,
                        Ton
                        • OscarLokO Offline
                          OscarLok
                          All 3 types boolean improved ! 18, Dec, 2008 ๐ŸŽ‰
                          http://www.youtube.com/watch?v=EHTeNwZY0jA
                          Newer version 15, Dec, 2008
                          http://www.youtube.com/watch?v=wxnYpbXXKfY
                          watch video from
                          http://www.youtube.com/watch?v=LlIX3ZS25jk
                          Oscar ๐Ÿ˜„
                          • OscarLokO Offline
                            OscarLok
                            Mary X'Mas & Happy New Year !!!
                            There is a newer version(18, Dec, 2008) out in the first post! (with All 3 types of boolean improved)
                            And, video in the second post!
                            Any comment are welcome!
                            Oscar ๐Ÿ˜„
                              There is something with your last version of the 15! ๐Ÿ˜„
                              SU 7 Splatch at any time and can't start! ๐Ÿ˜ฎ
                              If I erase your plug all works fine ๐Ÿ˜‰
                              All had working fine with your previous version โ—
                              Install / uninstall same result!
                                blajnov
                                Oscar ๐Ÿ˜„
                                With this version, Google SketchUp 7 is not started in general ๐Ÿ˜’, normally works only from the first
                                • OscarLokO Offline
                                  OscarLok
                                  And Now it should work, at least in my computer. ๐Ÿ˜‰
                                  The script is in the first POST. There are old & new version.
                                  Please give me more feedback after you try it. ๐ŸŽ‰
                                  Oscar ๐Ÿ˜„
                                    SU 7 is now starting ๐Ÿ˜„
                                    Works fine with your test file โ˜€
                                    Works not when I create myself the 2 boxes! ๐Ÿ˜ฎ (each box is a group)
                                    Must have the Pro version โ“
                                    Edit โ—
                                    Works with my boxes, but I must save my file and reload it before use your plug! ๐Ÿ˜‰
                                    Is that normal?
                                    my_try01.skp
                                      PS Another thing : you must draw something like an "egg timer" because user don't know if computer is calculating the boolean operation!
                                        A curious thing! ๐Ÿ˜„
                                        If the man is living that don't work! ๐Ÿ˜ฎ
                                        PS Another thing : seems SU 7 works better for your plug than V6, is that normal?
                                        my_try03.skp
                                        • OscarLokO Offline
                                          OscarLok
                                          Because the man is a component.
                                          If you explode him, than it work.
                                          At this moment, the stability is more important to me. I will include component in the future. โ˜€
                                          • OscarLokO Offline
                                            OscarLok
                                            Edit โ—
                                            Is that normal?
                                            It is not normal! Anyway, your download skp file is working fine!
                                            I will try to do more testing!
                                            • 15
                                            • 16
                                            • 2 / 16
