    New function on the 3D WH, 3D VIEW
    25 Posts 10 Posters 1.5k Views 10 Watching
    • marked001M Offline
      marked001
      nice...definitley helpful since SO much stuff on there is crap....haha.. definitely a cool plugin though, might have to look into using that.
      http://www.revision21vis.com
      instagram: revi21on
        KDSDESIGN
        sometimes it messes up and makes the model look like cr@p 😞
        Regards,
        █Kevin█
        (about 20% done)
          BTM
          It's true... I've had a couple models where textures, for some reason or another, appear with a blue tint.
          Ex: http://sketchup.google.com/3dwarehouse/details?mid=2ab6064a93f504ff1d11896425865490
          (A halo 1 extract, painted with halo 3 textures by Normandu, gun, interior textures, and more added by me. Look at the wheels)
          Meanwhile, some look fine
          http://sketchup.google.com/3dwarehouse/details?mid=ec26ff8e5bcd25a25dfd2d7998768282
          (halo 3 master chief extract, modified by several other users, textured by me with images off the web)
          ...and some are just ridiculous.
          http://sketchup.google.com/3dwarehouse/details?mid=7c50718a4811fb8c1b32aed2c3a48410
          (BLUE windows???)
            Cool feature, surely!
            And Google didn't even tell about it 😡
              remus
              Always good to get surprised every now and then, keeps you on your toes 👍
              • Chris FullmerC Offline
                Yeah, that is pretty cool! Thanks for pointing it out. The 3dwh is on my list of things to get familiar with. I felt bad bashing since I had never really used it 😄 So I'm trying to get a better understanding of it. so far so good, and this is a cool addition.
                • Alan FraserA Offline
                  Alan Fraser
                  FF has also been using this for the example models on its homepage for some time, but they are offline at the moment, because of a site overhaul.
                  I tweaked the code a little because I found that the standoff distance was too great in many cases...like looking at the model through wrong-way-round binoculars. I found it was even possible to get inside a model, rather than always viewing it from a distance.
                  A few of those animations...there was one of a marina...were used at a demo at basecamp.
                  The problem with the inside-looking-out animations are that you need many more frames, because the object of your attention...often something in the distance...is very subject to even a small change of angle of view, so 36 frames is an absolute minimum for a full rotation. Whereas you can get away with only 18 the other way around.
                  The full sequence for the marina was nearly 1 MB...not a good load time.
                  James has since come up with a new Ruby for us which spins the model on the spot, rather than the camera orbiting around the outside. It also has the advantage of maintaining whatever distance you set up initially in the window, so you know exactly what you are getting in advance. It's also quite useful to see the shadows changing as the model rotates relative to the sun.
                  3D Figures
                    KDSDESIGN
                    look up Tigre Feroce Lexington IS it makes it look HORIBLE (stupid bug)
                    Regards,
                    █Kevin█
                    (about 20% done)
                      Phil Rader AIA
                      Alan where can I get this plugin?
                      Also is it possible to keep use this plug-in but keep the shadows in the same location IE: I guess you would need to alter the sun location so I think I just answered my own question.
                      I did this 360 view:
                      http://www.nvizeon.com/360view/whc/index.html
                      I altered the html file created by webexporter and changed the images to ones I created by making 36 separate camera views around a circle and exporting the jpgs myself.
                      http://www.philrader.com
                        I looked this up on the warehouse and there is nothing there.
                        @Phil. Its on their downloads-plugins page here:
                        Error 404 (Not Found)!!1
                        (sketchup.google.com)
                        The first one un Under Viewer compatibility. Google SketchUp Web Exporter (Beta)
                          johnsenior1973
                            Well, so to say at least it reveals all the mistakes the guy did when he was even unable to clean that imported model. 👎
                            I'd leave that bug there like it is now. 👍
                              KDSDESIGN
                              wait, Imported? its his model
                              Regards,
                              █Kevin█
                              (about 20% done)
                                Phil Rader AIA
                                Chris, and Alan I meant the Ruby that "James" made that rotates the model. This is different than the web exporter plug-in. and Who is James?
                                  BTM
                                  another bug, I mentioned earlier.
                                  Look at the window. See anything funny?
                                  For some reason, the 3D viewer makes textures with differences in transparency turn blue.
                                    Yes, that's a known issue about it and "they are working on it..." 😉
                                      BTM
                                      I've noticed something: none of the most recent models have 3D views 🎉
                                        Scott Lininger said, maybe in another thread, that it takes a few days maybe for the 3dwh to process the 3d view. So give it some time, then you'll be able to see the 3d view.
                                          Phil Rader AIA
                                          Does anyone here know of a way to create SWF files that have the same effect. IE detect where the mouse is and cycle through image files: That way we only need to have one swf file to accomplish the same effect.
                                            Alan Fraser
                                            It's not too difficult, Phil. Just set up a line of mouseover objects along the bottom of the screen; each one linked to an image in a series generated by SU. Here's a bit of fun I did many years ago. It might be a little slow to load as it's on a defunct website, now cached by the Waybackmachine.
                                            Display
                                            (web.archive.org)
                                            3D Figures
                                            • 2 / 2
