    *Yawn* Alternatives to SketchUp
    70 Posts 28 Posters 14.1k Views 28 Watching
    • jujuJ Offline
      juju
      @tim danaher said:
      Because that's what the commission calls for. This is for 3DWorld magazine.
      Oooooohhh! Keep us posted! I buy it every month since introduced a few months back.
        ScottPara
        No to hijack the thread but another good magazine I found recently is "HDRI". Not as detailed as 3D world but also not loaded down with advertisements either.
        Scott
        Love the fact that some HATE my avatar.....
        • Tim DanaherT Offline
          Tim Danaher
          Cheers, all --
          I CANNOT get AvoCADo to run... I have the latest Java installed, but it keeps saying "invalid or corrupt .jar file". Anyone got it running on a Mac?
          I've only tried it in XP under Parallels, but no joy there...it crashes after the splashscreen.
          Juju -- it should be in the January issue. Did you see my Turning Torso Tutorial in issue 99? It's on their website somewhere.
          Edit: Scott -- a million! Wow. My most complex only has 133 000... I feel like a novice.
          Cheers,
          Tim
          http://vizarch.blogspot.com
            Click Draw
            Hi Tim,
            A good friend of mine uses Turbocad. I've watched him use it and tried it myself but didn't get to involved in it. If given more time, i would think it looks fairly easy to learn and the price seems fair. Have you checked it out before? The same friend also uses Google Sketchup but he hasn't lately. Old habits I guess...
            Good luck with the findings...
            Jeff
            Have I mentioned how much of a laugh I get out of some of the Signatures on here!
              dacad
              I think it's hard to compare anything with sketchup, but for me the ones that can come close to it are Caligari truespace, lusology modo, and silo
              Caligari Truespace - it's free (microsoft bought it to compete to skethcup so that people could also do buildings for virtual earth), it can do much more than sketchup (high poly, animation, physics, rigging, internal render and a reaaly cool real time render like the ones used in game) but hsi interface it's really not user frindly and can't really compare with sketchup easy to use
              Lusology Modo - it cost much more but this is really a professional program and was built from the ground up by some of the references and brains in the 3d world. Very advanced modeling tools and one of the most promissing render out there
              Nevercenter Silo - this is the one that comes close t skethcup but and the core is the same of sketchup : easy 3d modeling and colaboration with other 3d packages, but more for high poly organic modeling. It's more used ofr high poly modeling, advance uv tools and a lot of import export formats, but lack doesn't work so good has skethcup alone wihtout the help of other softwares.
              keep us posted about your work
              David
                ScottPara
                http://www.luxology.com/
                Actually Modo is not that much more than Sketchup. For all you get it is hard to not at least point it out.
                Sketchup $495 (new license)
                Modo $695 (new License)
                Scott
                  johnsenior1973
                  Modo is $895. The $695 price is a special offer.
                  • jolranJ Offline
                    jolran
                    Have you forgotten about Z brush? Have a copy on my computer running..
                    Although the interfaces are different I can definitely see a similarity between the 2.
                    Zbrush is recommended for Organic modeling and SU hard surface. Although it is possible for both modelingtypes in both of the programs.
                    Its the same push and pull strategies with finess tools.
                    I must say SU is THE most userfriendly program I ever haver used. So quick too
                    learn. Very logical approach. Z brush is a bit intimidating at first but also quite logical when one get used too it. I must confess I talking about Z.brush ver 2.5. Havent used ver3 so much yet. Have SU now 😄
                      ScottPara
                      Yes a special offer, and one I would suggest anyone looking for a modeler capable of doing just about anything MAX/C4D can do for less than 25% of MAX's cost should jump on this offer. Not to mention that Modo 401 will have HAIR, Volumetric lighting, and better animation controls (rumor has it). Even $895 is still one of the best deals out there for a modeler/render/UV editor/Sculptor....and the list goes on.
                      Scott
                        matteo
                        I have not found any good alternative to sketchup, but I use wings 3d, the free modeler, http://www.wings3d.com/ when I need some features that sketchup doesn't have:
                        1| the ability to handle a high number of polygons
                        2| it's a subdivision modeler: subdivide and smooth on steroids
                        3| the selection tool is powerful
                        4| it can export to 3ds, obj and lwo
                        I usually start a model in sketchup and when I need to add more definition to it I switch to wings 3d. You need to have sketchup pro, since it doesn't import skp models, so you must convert your model to 3ds before you can edit it in wings 3d.
                        hire me: http://www.nonsolo3d.it/ !
                          toxicvoxel
                          I think these two applications are closest to the Sketchup paradigm at the current time and worth watching to see how they develop:
                          http://www.3dvia.com/software/3dvia-shape/tour/
                          http://www.bonzai3d.com/
                            kwistenbiebel
                            I don't agree there.They both are supposed to be(come) Sketchup killers, but none of them support the major high end render engines (yet).
                            In these ages, that is critical.
                            Spaceclaim is another really fine modeler, let's say it is sketchup with Rhino (Nurbs) capability....but it lacks a good render engine or 3td party support for it, making it a non-option, at least in my case.
                              toxicvoxel
                              Kwist,
                              I do not believe that rendering is central to the Sketchup paradigm nor do I believe that rendering support is what will create a 'Sketchup killer'. Moreover I think it is a question of the high end renderers (and I can think of only one in this category) providing Sketchup support rather than the other way round.
                              What makes these products interresting to watch is the fact that they are very obviously targeting the same market as Sketchup in terms of user interface and graphics display. I have a real hope that these applications become contenders in the marketplace as they may help to reactivate development momentum of Sketchup itself.
                                Tim Danaher
                                Toxic --
                                Thanks for the shape link...that one's going in!
                                Hmmm... it's by Dassault Systèmes -- heavy hitters. And it's free! Oooh! Soft shadows!!!
                                edit: Kwisten ... I'm curious -- how do you mean 'doesn't support renderers'? ... Bonzai says that it can export in 20 different file formats.
                                Cheers,
                                Tim
                                • soloS Offline
                                  Like I said before, Hexagon 2 is IMO worth considering.
                                  And reasonably priced at $149.00
                                  http://i1.tinypic.com/2zxyzuw.jpg
                                    kwistenbiebel
                                    @toxicvoxel said:
                                    Kwist,
                                    I am not sure about that.
                                    Besides being a design tool, Sketchup is a communication tool.
                                    Presentation of a design to a client is key.
                                    It is the reason why Revit is criticised. It is good at 3D, making plans and documenting projects, but visualisation wise it just sucks...(and it is Autodesk, which means dusty and expensive 😉)
                                      toxicvoxel
                                      Kwist, last time I checked Sketchup did not do any rendering. I personally don't want a jack-of-all-trades application and would rather rely on individual specialist applications within my workflow that I can 'glue' together through customisation. That way I can choose the technology I want and will not be reliant on a single company for developing the technology.If my primary concern was rendering there would be better platforms to build my workflow arround.
                                      I think my post was a valid response to the original question. The issue of rendering support is not entirely relevant.
                                        kwistenbiebel
                                        I understand.
                                        It comes down on what you use Sketchup for I guess, and there is probably more than 1 type of SU-user.
                                        I would be the one that considers having the major render engines as important.
                                        But God forbid, Sketchup should NEVER have a built in PR render engine of itself, it should be 3td party software.
                                        I presume you are talking about alternatives for Sketchup purely as a 3D modeler.
                                        In that case, I would settle for having Sketchup and Rhino to complement it.
                                        Sketchup can do an awful lot as a modeler and I think it is just Nurbs, booleans etc... it misses. And that is where Rhino is really good at.
                                        If rendering,presentation and animation is important as well (for me it is), than C4D is a good candidate to go along with Sketchup.
                                          toxicvoxel
                                          Kwist, I volunteered the two applications in answer to the original thread question for the sake of comparrison because of some very obvious simmilarities for the purpose of his paper, rather than as serious alternatives at this stage.
                                          In fact our approach is simmilar - I use Rhino in conjunction with Sketchup and use it as a rendering platform for VRAY when I need it. A notable additional aspect of Rhino is that it offers fairly good CAD functionality on top of the modelling power it provides. (Although I would not use it if I was doing CAD production as my central activity, it is a very viable AutoCAD replacement for generating CAD data during the design stages.) There is also a BIM plugin system for Rhino coming on stream and Rhino is directly supported by Paracloud.
                                          An under-reported fact about Rhino is that many of the functions have the same names and params as in AutoCAD, making a transition easier than one might expect. (Loads of differences too but many simmilarities.)
                                          -Anyway we digress from the topic of the thread.
                                            kwistenbiebel
                                            Ok, getting back closer to the subject.
                                            @tim danaher said:
                                            The question is apps that work like SketchUp.
                                            To be honest, I don't have the feeling that there are real alternatives to SU.
                                            3DVIA and Bonzai clearly aim to be Sketchup, although I doubt they have the same quality.
                                            Concerning Bonzai, I think it is too soon to comment though as it is not out yet. But the fact that it derives from FormZ does not really give me the feeling that it will be as intuitive as SU is.
                                            I think the best real alternative for the moment, in terms of really being able to put it in a workflow, would be Spaceclaim.
                                            Very Sketchup like, more modeling capability than SU (Nurbs), but just a little less intuitive and less focused on architecture I think.
                                            @Tim, It is worth downloading the Spaceclaim trial version so you can judge for yourself.
                                            • 3 / 4
