    Pools and Rounded Transitions
    13 Posts 4 Posters 999 Views 4 Watching
      bluered
      Greetings all!
      i am creating a skatepark for a design class and
      am having difficulties figuring out how to create
      rounded transitions and the insides of pools,
      basically the same problem.
      any suggestions?
      i'm currently using the free download of 6
      and am awaiting my 6 pro version in next day or so.
      Thanks!!!
      • soloS Offline
        Like this?
        pool slope.skp
        I will add a video soon as to how it's done.
        • soloS Offline
          By the way, welcome to GSCF.
          I used a ruby called 'round edges by bezier' found here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10370&st=0&sk=t&sd=a&hilit=round+edges+by+bezier
          [flash=640,480:3a86b6u8]http://vimeo.com/moogaloop.swf?clip_id=2491307&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=00ADEF&fullscreen=1[/flash:3a86b6u8]
          http://www.vimeo.com/2491307
            bluered
            thanks solo!
            i'll work with this a bit and see how i do.
            πŸ˜„
              bluered
              this helps a little, but it is not the result i am seeking.
              i am creating a concrete skatepark and i need to
              create transitioned embankments and pools that
              vary in height and angle.
              like for example, this link,
              Error 404 (Not Found)!!1
              (sketchup.google.com)
              how did this individual
              create this? do i need particular tools or is there
              some sort of appliable instruction?
                remus
                It looks as if you could do most of that with the follow me tool. Have a look at the mini tutorial for some more ideas.
                This method isnt particularly good for transitions and changes of angle. You might want to look in to the soap skin bubble plugin ( http://www.tensile-structures.de/sb_software.html ) and possibly subdivide and smooth.
                skatepark pool tut.skp
                  bluered
                  kewl, i got the soap, i do not have the follow me tool in
                  the version i have, just 6, not 6 pro.
                  i have bought it, but haven't received it yet.
                  is the follow me tool downloadable?
                    bluered
                    ok...i found the follow me tool, haven't tried it yet,
                    found the soap bubble tool, it RULES!
                    one issue...i haven't figured out how to put a
                    clean face on the wireframe...is this doable?
                      What clean face and what wireframe? Do you mean the facets of the result of SSB?
                      If so, simply right click > Soften/smooth and slide the slider until it is softened enough.
                        bluered
                        you guys rule!
                        thanks so much!
                        πŸ˜„
                        • soloS Offline
                          [flash=600,350:1fdzad25]http://vimeo.com/moogaloop.swf?clip_id=2517564&server=vimeo.com&show_title=1&show_byline=1&show_portrait=0&color=00ADEF&fullscreen=1[/flash:1fdzad25]
                          http://www.vimeo.com/2517564
                          seems to be cropping on my PC.
                            bluered
                            is there a way i can make all these lines appear less
                            prominent than they are, softer even, that the image
                            wouldn't look so sketchy...without starting completely over...
                              remus
                              If you go window->styles then click through the little row of buttons untill you get to one that has a little 'profiles' tick box, turn that off and the lines should appear less prominent.
                              Its a little hard to say looking at the pic, but getting the and holding ctrl while you go over the lines might help as well.
