    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 236.1k Views 123 Watching
    • OscarLokO Offline
      OscarLok
      Hi ๐Ÿ˜„
      This ruby tool can do intersect, union, cut, trim and split with both groups & components.
      This is beta really, it is important to save your work before using the tool.
      Here is the New improved OSCoolean (Dec 2013) !
      I know that there is boolean function in SU 8 Pro, but not SU 8+ free version.
      There are great improvement in SU 8, so I use the SU 8 feature to write a new OSCoolean for SU 8 and up.
      Again, it is a beta version, it is important to save your work before using the tool.
      This time, OSCoolean has a toolbar for selecting 2 groups, speed improved and more stable.
      Dec 2013 version
      • Components feature added.
      • Unneeded dialog removed.
      Oct version
      • Trim & split feature added.
      • Language file added.
      • Chinese language. (open the file OSC_Language.lag in the Oscar folder with Notepad, then change the Lang=1 to Lang=2)
        [flash=480,385:2e6uaetl]http://www.youtube.com/v/_sX-WB06qdg?fs=1&hl=en_US[/flash:2e6uaetl]
      [flash=480,385:2e6uaetl]http://www.youtube.com/v/FjZLX3j7PhM?fs=1&hl=en_US[/flash:2e6uaetl]
      [flash=480,385:2e6uaetl]http://www.youtube.com/v/pqLOh8Q8pnE?fs=1&hl=en_US[/flash:2e6uaetl]
      Oscar ๐Ÿ˜„
      Latest version now available at the PluginStore [RBZ
      Not yet compatible with >=v2014 ๐Ÿ˜ž] http://sketchucation.com/pluginstore?pln=OSCoolean
      This is the Oct version for SU 8(Old Ver)
      2013 version for both group & component.
      [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
      • soloS Offline
        Looks very interesting and promising. ๐Ÿ‘
          linea
          That looks really good, a function that I have wanted for a long time.
            Oscar,
            This looks amazing! Nomore cleanups, no more messing with unwanted geometry! ๐Ÿ‘
              sepo
              Excellent news....Thank you very much...
                Great! I've always wanted boolean operations in SU.
                • CadFatherC Offline
                  CadFather
                  Thanks Oscar!
                  ..guess it should have been part of the scf powertoolbar! ๐Ÿ˜’
                    Well,finally had some time to play with it - but the same as Coen; nothing seems to happen no matter how I combine the things. ๐Ÿ˜ž
                      Jim
                      Here is the error in the Ruby Console:
                      Error; #<NameError; uninitialized constant OSCoolean;;Oscar>
                      (eval);331;in `Cut'
                      (eval);376
                      (eval);376;in `call'
                      • I Offline
                        ilay7k
                        > (eval);331;in `Cut'
                        > (eval);376
                        not only cut-command
                        (eval);1068;in `Intersect'
                        (eval);1204
                        (eval);1204;in `call'
                        (eval);3878
                        (eval);1161;in `Cut'
                        (eval);1206
                        (eval);1206;in `call'
                        (eval);3878
                        (eval);1114;in `Union'
                        (eval);1205
                        (eval);1205;in `call'
                        (eval);3878
                        • Jean-FrancoJ Offline
                          Jean-Franco
                          Hi, same as Coen and Gaieus.
                          Jean-Franco
                            GUNAWAN W
                            nothing happen,
                            no error messages. ๐Ÿ˜’
                              tulacong
                              Thank oscarlok
                              • OscarLokO Offline
                                OscarLok
                                Hi Everybody,
                                Oh ya! "Error: #<NameError: uninitialized constant OSCoolean::Oscar>" (Thanks for Jim & ilay7k 's error report)
                                Sorry ! part of my def script is under another ruby script in Class Oscar.
                                Anywhere, I have repackage OSCoolean script and with OSCoolean.skp for testing.(In the FIRST post)
                                Oscar
                                • bagateloB Offline
                                  bagatelo
                                  Is this an answear to this?
                                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14217
                                    remus
                                    Yep, this is a boolean tool, although still under development, as the author says.
                                    • MarianM Offline
                                      Marian
                                      Thanks Oscar,
                                      This is a very cool tool, although a bit buggy, it's another work simplifier and enhancer for Sketchup
                                      , can't wait for the improved version.
                                      Good luck. ๐Ÿ˜‰
                                        Thanks Oscar! Now it works (although indeed there are some little bugs - especially when there are coplanar faces with a union for instance)
                                        ๐Ÿ‘
                                        • BepB Offline
                                          Bep
                                          Great development Oscar.๐Ÿ‘ ๐Ÿ‘
                                          Bep van Malde
                                          "History is written by the winners"
                                            Tell us when V 1.0 is released! โ˜€
                                            • 15
                                            • 16
                                            • 2 / 16
