    Terrain Modeling Question
    23 Posts 8 Posters 2.4k Views 8 Watching
      andymaw
      Hi all,
      Is there a way to remove a central part of a terrain leaving a gap? In CAD, hatching is done with 'islands' so was wondering if there is an equivalent in SU.
      Cheers
        You can always do this by drawing the shape of this "island" on a flat face, then push/pull it up so that it intersects the terrain where you want it - just like a cookie cutter - then make sure you are in the context of the terrain (they are generally groups so edit the group), double click on the terrain surface (or triple click if it is not a single mesh), right click > Intersect > ...with model.
        Now you can select the surface of your island and simply delete it.
        Exiting the group, simply delete your cookie cutter.
          andymaw
          Magic, that worked a treat. Thank you
            Glad I got it through - I was wondering if I could make myself clear enough (I actually often wonder about this 😲 )
            • plot-parisP Offline
              plot-paris
              clear as my tea, Gaieus (...they drink it with a lot of milk here in England) 🀣
              just kidding...
              another way is to use the drape tool: position the flat face of your island over the terrain, and select it. then press the 'drape' button of the sandbox tools and click on the terrain. the outline will now be drawn onto the terrain.
              is pretty much, what Gaieus' method does - only that you are not in danger of accidentally intersecting your terrain with geometry other than the island footprint (but make sure to save before using the drape tool, a bug splat may be the only result you get)
                Yup - how it didn't come to my mind! Sure; the drape tool! In fact it is just designed to do such operations without my cumbersome workaround!
                (well, I got up at about 4:30 am and still working past 3 pm) 😞
                  plot-paris
                  ...and still replying within 3 minutes. do you have some little notifier tool running, that pops up, when a new post has been placed in a thread you are active in? if yes, where can I get it? if no, how do you do it (being so fast)?
                  by the way: such an application would be fantastic to be included in SketchUp. thus I could post all day without my boss noticing, that I am not actually modeling πŸ˜„
                  didn't we have a discussion about it some time ago?
                    @plot-paris said:
                    ...do you have some little notifier tool running, that pops up, when a new post has been placed...?
                    Sure, this is it:
                    http://www.sketchucation.com/forums/scf/styles/prosilver/imageset/forum_unread.gif
                    (I mean the little pencil.
                    And this is my screenshot (after this post I'll have to check out the gallery πŸ˜„ )
                      plot-paris
                      ah, I see. but you don't have a little program that makes an annoying noise as soon as something is posted (you know, like some sort of instant messenger).
                        No. I keep an EYE on... πŸ‘Š
                        (the other one is under surgery anyway...) 😞
                          plot-paris
                          oh, that doesn't sound too well. did a piece of metal fly from your hammer while excavating a roman church? hope everything will be fine πŸ‘ (I find it really hard to read subtitles in movies with only one eye).
                          if your eye should happen to get inhumanly red (like it happens quite often after a surgery), could you take a photo and post it? πŸ˜‰
                          andymaw, sorry for jacking your thread. and Gaieus, tell me if I was out of order; I am not very sensitive in these things. had a long row with my flatmate the other day, because I told her she would drop dead half way through her marathon if she kept on smoking.
                            Haha. I wouldn't even think of a 100 metre run with my almost 30 years of smoking habit! 😞
                            Anyway, I have a cataract in my right eye (used to have one in the left as well but that was operated some 2.5 years ago already). Now it's about high time for the right eye as well. πŸ‘Š
                            • EdsonE Offline
                              Edson
                              jakob and csaba,
                              i still prefer the intersect way over the drape tool as it is not always reliable. and jakob, do not you get notifications by email about the topics you subscribe to?
                              http://www.mahfuz.arq.br
                                True that the drape tool in not always reliable although often it is not because the imported dxf linework does not close properly (i.e. you couldn't create a simple face with it either).
                                Also, as I experienced, the drape tool ha been greatly enhanced in SU 7 - and it is also faster than before.
                                  timdaviespimlico
                                  Hi Gaieus,
                                  I only just joined the community and have been reading your thread about the scripts etc to convert spot points from autocad accross to sketchup - i'm not a coder but i have worked with computers for 20 years so i'm hoping i'm not stupid but i've tried all the links and have not been able to get it to work - could you point me in the right direction!! - i've got about 2-300 points in an autocad file from an architect each point has a cross and a 6digit decimal (ie 100.040 ) .
                                  any advice much appreciated!
                                  cheers
                                  tim davies
                                  'Rome wasn't built in a day, but they didn't have sketchup!'
                                    Hi Tim and welcome!
                                    Are those "crosses" components when imported to SU? The best would be if they were instances of the same component (as I remember a topic with such a case).
                                    What do the digits stand for? Elevation maybe?
                                      timdaviespimlico
                                      Hi Gaieus, Thank you for your time in getting back to me.
                                      i've attached a screenshot showing the number data with the cross (x) as it appears in Autocad and then in su7 how the points come in without the numbers and just the x which have 6 edges and also a length!
                                      thanks again for your time .
                                      shows data in cad
                                      shows su7 conversion with 6 edges and length
                                      • AnssiA Offline
                                        Anssi
                                        SU does not import CAD Text objects, but if those "crosses" are at the right elevations, you can use the Sandbox from Contours tool to fit a terrain surface onto them. It may not be the most beautiful one, but it might work.
                                        Anssi
                                          timdaviespimlico
                                          thanks guys for your advice - i just checked and the elevation data isn't there - all the crosses have the same value in entity info and are the same plane! i'm going to try and fudge it!
                                            Kenny
                                            Tim, it looks like the survey you have is in 2D only. Go back to the architect who could ask the surveyor if he has done the survey with 3d points. I've had a few situations where the 3D information is collected in the survey but you have to request it in 3D format otherwise it is sent out in 2d only.
                                            Failing that, the numbers you have are spot heights which can be converted to 3D. See this thread: http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=14409&st=0&sk=t&sd=a&hilit=cloud
                                            I couldn't get it to work at first but email the developer who is very helpful if you have a problem.
                                            Kenny
                                            http://www.townscapesolutions.co.uk/
