    Invitation to the SketchUcation collection
    155 Posts 26 Posters 233.2k Views 26 Watching
    • K
      ktkoh
      Thanks for the help loading models to the 3d warehouse.
      Here are the models I uploaded there are some that don't show the full joint detail as I have been using loose tenons and sometimes add this as I build in the shop. Otherwise all parts are components and to scale.
      http://sketchup.google.com/3dwarehouse/details?mid=200fe2e2486a0ddf85c5f690e9252fc5
      http://sketchup.google.com/3dwarehouse/details?mid=c9dd43888905630285c5f690e9252fc5
      http://sketchup.google.com/3dwarehouse/details?mid=3357d112432da01b85c5f690e9252fc5
      http://sketchup.google.com/3dwarehouse/details?mid=509d9d137fd7465a85c5f690e9252fc5
      http://sketchup.google.com/3dwarehouse/details?mid=f006ed79465eb37a85c5f690e9252fc5
      http://sketchup.google.com/3dwarehouse/details?mid=754372e400efa8a485c5f690e9252fc5
      Thanks for looking
      Keith
      • K
        ktkoh
        I fixed the links so all models are shown
        Keith
        • H
          Hazza
          I will have a look at these tomorrow.
          See all of my SketchUp models here.
          • H
            Hazza
            Sheet music cabinet:
            Sorry, but criteria 4 is "No overlapping solids".
            Have a look at the "side slats" component, it overlaps the side rail, the side slat and the post. Same thing with the shelves and the back.
            Media Center:
            Meets the model criteria, although I have a woodworking type question about the bottom rails. They seem to be mortise and mortise not mortise and tenon joints. Is that a mistake or do you put in a seperate piece of wood to fill both holes?
            Dresser:
            It's a complex model with many pieces but what I looked at looked all good.
            Youth desk:
            Same issues as the music cabinet, in the same locations too, side rail, side slat and legs.
            Night Stand:
            At first the orbiting was weird, then I figured out you had the camera in parallel projection. There are gaps in the woodworking like between the bottom stetcher and the shelf but it meets the criteria.
            Queens size bed:
            The foot board and head board overlap both the rails. It does not stop it being in the collection but I thought you would like to know some of the components don't have material on all faces, for example the ends and bottom of the side rails.
            • GaieusG
              You've become rather picky, Hazza! πŸ˜›
                @hazza said:
                [b]Media Center:
                Hazza, are you familiar with "loose tenon" joinery?
                http://www.kk.org/cooltools/festool-domino-joiner-sm.jpg
                http://www.werkzeug-news.de/news6/img/h-festool-domino-aw4.jpg
                • K
                  ktkoh
                  Thanks for lookig at the models. I had forgot that I omitted the slots for the slats in the models where the 1/4 panels sit in the rails and styes. I will remeber to include that in the future and will go back and fix the models.
                  Yes I have started to use loose tenon joints since I built a fixture that works with an old shop smith and works like a horizontal router so long parts are no longer a problem. (except my shop is narrow and crowded)
                  The gap in nightstand is intentional and required for seasonal wood movement as the shelf is solid wood.
                  I only use texture where visible from the front and sides most of the time to show the family what thier designed furniture will look like and to get the approval to build.
                  Keith
                  • H
                    Hazza
                    Yes and it's what is not accepted into the collection that sets the quailty. If I let that model slip in why not the next one. Then the next one that is slightly less quailty than that... etc etc.
                    No, that's why I asked. I am a SU modeler that does woodwork models, not a woodworker that does SU models.
                    I have no doubt in my mind that there is heaps of woodworking stuff I have never seen before. That's why I like detailed woodworking plans. I am able to follow the plans with no prior woodworking knowledge.
                    Now I am familiar with loose tenons... you learn something everyday.
                    When you do let me know and I will add them to the collection.
                    • GaieusG
                      Yes, I know exactly. I was just pulling your leg. πŸ˜‰
                      • H
                        Hazza
                        Yeah I know you were but it was just in case others came across the thread and thought I WAS being too picky. I would have thought of a witty reply but my caffine system has too much blood in it.
                        • K
                          ktkoh
                          I understand about standards and I am fine with you saying that the models need fixing to be included. That seems reasonable to me.
                          Keith
                          • bazB
                            baz
                            Heres my contribution.
                            http://sketchup.google.com/3dwarehouse/details?mid=72c2d871fba975c7d797e188153f356&prevstart=0
                            With reference to woodgrain orientation, it always used to be a real pain, but now in su7 you can edit the image in pshop. Simply save the texture as a copy in su. Export it to your image editor, rotate the image 90 degrees and voila!
                            Baz
                              Nice chest you've got there, Baz.
                              I wouldn't want to have to fit those dividers though. Are you going to build it?
                              Hazza won't like it because the case isn't drawn as separate components. πŸ˜‰
                              • P
                                peweuk
                                Baz
                                I am drawing some cabinets to be made from sheet material in V7 and found this useful feature, and that is what I did at first BUT....
                                I then decided I wanted the model to work with the cutlist plugin (planning a whole kitchen) and found that to do it this way requires 2 images with different names, one for each material orientation, which causes Cutlist to show the board layout on 2 different sheets (one for each material) instead of one.
                                So I revisited the model and changed the axis for the parts which needed it (top, shelf and bottom) and this allowed me to use the same texture for all parts.
                                The cabinets are all created as Dynamic Components in V7 (for easy parametric re-sizing) and the alterations to the X, Y, Z sizing was easily done in the Components Attributes window once I changed the axis.
                                So if you are designing with a lot of cabinets (such as a kitchen) and are looking to use a cutlist output (either the plugin or a spreadsheet) the axis change is the way to go.
                                • bazB
                                  baz
                                  Thanks Dave, I actually made this many years ago as my 'masterpiece' (in the sense of the traditional apprentice/journeyman/master, guild system.) I cut each of those mitres on the dividers with a 'donkeys ear' shooting board, and they are a dry fit.
                                  If you push a drawer closed firmly most of the rest slide open, I was pleased with that:)
                                  Not sure I understand about about your component comment re hazza?
                                  Baz.
                                  ps: sorry about the daggy photo, its the one I used for photomatching, all the good shots of this are on slide. (another job to get round to:(
                                    Ah, the perfect piston fit drawers. You are indeed a master. Excellent work.
                                    You didn't glue the dividers to each other? That's a neat arrangement.
                                    Are you still doing cabinet work.
                                    re: The component comment, The case sides, top and bottom are all one blob of geometry. Hazza's criteria is that every part you'd make in wood must be a separate component. I think your model is fine as it is.
                                      @hazza said:
                                      If I wanted to seperate it into 4 pieces so that I could take measurements I could not do so without many many hours of SU work.
                                      Well twenty one minutes, anyway. πŸ˜‰
                                      • bazB
                                        baz
                                        πŸ˜‰ [attachment=0:2hwuri2c]<!-- ia0 -->min_chest_of_drawers[2].jpg<!-- ia0 -->[/attachment:2hwuri2c]
                                        Lol.
                                        baz
                                        • H
                                          Hazza
                                          Baz
                                          Dave is right, each piece of wood does need to be a seperate component OR group to met the criteria. The outside box is one group. If I wanted to seperate it into 4 pieces so that I could take measurements I could not do so without many many hours of SU work.
                                          As for the material orientation, you could change that in SU6 without "editing" the texture in an external application:
                                          1. Edit the component (or group)
                                          2. Right click the face you want to change
                                          3. Select "Texture -> Position"
                                          4. Right click face again
                                          5. Select "Rotate -> 90 (or 180 or 270)"
                                          • H
                                            Hazza
                                            Dave Dave Dave...... you may have been able to seperate them in 20 minutes but we are talking about my SU skills and experience aren't we? πŸ˜‰
                                            I did exagerate on the hours and hours but I think he now understands what is required. The model may be obvious to a woodworker, but I am not. I am a modeler that does woodwork models, that difference in emphasis means it has to be obvious.
                                            • 3 / 8
