    Invitation to the SketchUcation collection
    155 Posts 26 Posters 233.2k Views 26 Watching
    • GaieusG
      Note that you need to have a Google account for this and you need to send that email address to Hazza so that he invite you as collaborators.
      Also, there is a limited number of changes you can make and to which you can revert your collection, so from time to time "purge" older changes from the History tab.
      Happy collecting! πŸ‘
      Hazza, be careful with the permission settings!
        Sawduster
        Here is a Neo-Queen Anne Tall Chest
        Error 404 (Not Found)!!1
        (sketchup.google.com)
        May all your dimensions be the sum of their total.
        Jerry
        http://www.sawdustersplace.com
        • K
          ktkoh
          I need some help on uploading files to the 3d warehouse. I have some furniture models that I saved as kmz files but when I tried to upload one it gives me an error message that there needs to be at least one model in the file to upload.
          Any ideas what I am missing?? JillsBed.kmz
          Keith
          • H
            Hazza
            What is a kmz file? What program did you use to create it?
            3D warehouse only lets you upload SketchUp models.
            See all of my SketchUp models here.
            • GaieusG
              kmz is the file type SU creates from a model for Google Earth. From SU you can only upload kmz files however on the front page of the WareHouse you can directly upload kmz files as well. But you cannot use them in SU later so unfortunately it would no be help for SU modelers.
              • H
                Hazza
                The last 4 links take you to the same model.
                • K
                  ktkoh
                  Thanks for the help loading models to the 3d warehouse.
                  Here are the models I uploaded there are some that don't show the full joint detail as I have been using loose tenons and sometimes add this as I build in the shop. Otherwise all parts are components and to scale.
                  http://sketchup.google.com/3dwarehouse/details?mid=200fe2e2486a0ddf85c5f690e9252fc5
                  http://sketchup.google.com/3dwarehouse/details?mid=c9dd43888905630285c5f690e9252fc5
                  http://sketchup.google.com/3dwarehouse/details?mid=3357d112432da01b85c5f690e9252fc5
                  http://sketchup.google.com/3dwarehouse/details?mid=509d9d137fd7465a85c5f690e9252fc5
                  http://sketchup.google.com/3dwarehouse/details?mid=f006ed79465eb37a85c5f690e9252fc5
                  http://sketchup.google.com/3dwarehouse/details?mid=754372e400efa8a485c5f690e9252fc5
                  Thanks for looking
                  Keith
                  • K
                    ktkoh
                    I fixed the links so all models are shown
                    Keith
                    • H
                      Hazza
                      I will have a look at these tomorrow.
                      • H
                        Hazza
                        Sheet music cabinet:
                        Sorry, but criteria 4 is "No overlapping solids".
                        Have a look at the "side slats" component, it overlaps the side rail, the side slat and the post. Same thing with the shelves and the back.
                        Media Center:
                        Meets the model criteria, although I have a woodworking type question about the bottom rails. They seem to be mortise and mortise not mortise and tenon joints. Is that a mistake or do you put in a seperate piece of wood to fill both holes?
                        Dresser:
                        It's a complex model with many pieces but what I looked at looked all good.
                        Youth desk:
                        Same issues as the music cabinet, in the same locations too, side rail, side slat and legs.
                        Night Stand:
                        At first the orbiting was weird, then I figured out you had the camera in parallel projection. There are gaps in the woodworking like between the bottom stetcher and the shelf but it meets the criteria.
                        Queens size bed:
                        The foot board and head board overlap both the rails. It does not stop it being in the collection but I thought you would like to know some of the components don't have material on all faces, for example the ends and bottom of the side rails.
                        • GaieusG
                          You've become rather picky, Hazza! πŸ˜›
                            @hazza said:
                            [b]Media Center:
                            Hazza, are you familiar with "loose tenon" joinery?
                            http://www.kk.org/cooltools/festool-domino-joiner-sm.jpg
                            http://www.werkzeug-news.de/news6/img/h-festool-domino-aw4.jpg
                            • K
                              ktkoh
                              Thanks for lookig at the models. I had forgot that I omitted the slots for the slats in the models where the 1/4 panels sit in the rails and styes. I will remeber to include that in the future and will go back and fix the models.
                              Yes I have started to use loose tenon joints since I built a fixture that works with an old shop smith and works like a horizontal router so long parts are no longer a problem. (except my shop is narrow and crowded)
                              The gap in nightstand is intentional and required for seasonal wood movement as the shelf is solid wood.
                              I only use texture where visible from the front and sides most of the time to show the family what thier designed furniture will look like and to get the approval to build.
                              Keith
                              • H
                                Hazza
                                Yes and it's what is not accepted into the collection that sets the quailty. If I let that model slip in why not the next one. Then the next one that is slightly less quailty than that... etc etc.
                                No, that's why I asked. I am a SU modeler that does woodwork models, not a woodworker that does SU models.
                                I have no doubt in my mind that there is heaps of woodworking stuff I have never seen before. That's why I like detailed woodworking plans. I am able to follow the plans with no prior woodworking knowledge.
                                Now I am familiar with loose tenons... you learn something everyday.
                                When you do let me know and I will add them to the collection.
                                • GaieusG
                                  Yes, I know exactly. I was just pulling your leg. πŸ˜‰
                                  • H
                                    Hazza
                                    Yeah I know you were but it was just in case others came across the thread and thought I WAS being too picky. I would have thought of a witty reply but my caffine system has too much blood in it.
                                    • K
                                      ktkoh
                                      I understand about standards and I am fine with you saying that the models need fixing to be included. That seems reasonable to me.
                                      Keith
                                      • bazB
                                        baz
                                        Heres my contribution.
                                        http://sketchup.google.com/3dwarehouse/details?mid=72c2d871fba975c7d797e188153f356&prevstart=0
                                        With reference to woodgrain orientation, it always used to be a real pain, but now in su7 you can edit the image in pshop. Simply save the texture as a copy in su. Export it to your image editor, rotate the image 90 degrees and voila!
                                        Baz
                                          Nice chest you've got there, Baz.
                                          I wouldn't want to have to fit those dividers though. Are you going to build it?
                                          Hazza won't like it because the case isn't drawn as separate components. πŸ˜‰
                                          • P
                                            peweuk
                                            Baz
                                            I am drawing some cabinets to be made from sheet material in V7 and found this useful feature, and that is what I did at first BUT....
                                            I then decided I wanted the model to work with the cutlist plugin (planning a whole kitchen) and found that to do it this way requires 2 images with different names, one for each material orientation, which causes Cutlist to show the board layout on 2 different sheets (one for each material) instead of one.
                                            So I revisited the model and changed the axis for the parts which needed it (top, shelf and bottom) and this allowed me to use the same texture for all parts.
                                            The cabinets are all created as Dynamic Components in V7 (for easy parametric re-sizing) and the alterations to the X, Y, Z sizing was easily done in the Components Attributes window once I changed the axis.
                                            So if you are designing with a lot of cabinets (such as a kitchen) and are looking to use a cutlist output (either the plugin or a spreadsheet) the axis change is the way to go.
                                            • 3 / 8
