    Invitation to the SketchUcation collection
    155 Posts 26 Posters 233.2k Views 26 Watching
    • H
      Hazza
      For those that are following along at home, I worked out how to change the orientation of the texture so that the grain of the wood runs along instead of across:
      1. Edit the component.
      2. Select the face that you want to change the texture orientation.
      3. Right click it.
      4. Select "Texture -> Position"
      5. Click and drag the green circle 90 degrees.
      6. Click outside the area to close the texture orientation tool.
      7. Go to 2 for all faces that need changing.
      8. Close the component.
      See all of my SketchUp models here.
        If you want to turn the texture 90° (or 180° or 270°) you could right click at step 5, click on Rotate and choose the angle from the menu.
        • H
          Hazza
          Is there a script that would allow you to right click once and select "Rotate material 90 degrees" instead of having to right click it twice?
            Not that I'm aware of. If you correct the alignment immediately before applying the material to faces in other components, you can use the eyedropper to sample the material and get the alignment done properly.
              SchreiberBike
              Hazza,
              You are right about the widely varying quality in the warehouse. A select list has possibilities.
              Here are a couple which I think would meet your criteria. I often do a model with full joinery, then do a simplified version which could be used as a component in another model. I'm also very interested in critical feedback in order to learn to model and design better.
              Frank Lloyd Write Lamp
              Full detail: http://sketchup.google.com/3dwarehouse/details?mid=18809736617cbe7e4326824bb7387d70
              Simplified: http://sketchup.google.com/3dwarehouse/details?mid=5abda7d039ec115b72349ee87c19f053&ct=mdrm and http://sketchup.google.com/3dwarehouse/details?mid=ff479dddbb48197aea61e619272daaca&ct=mdrm
              The workbench I'm trying to get finished.
              http://sketchup.google.com/3dwarehouse/details?mid=ecb23fa93ef7ea58fe4e85d9b619cbad
              A study for a carved walking stick.
              http://sketchup.google.com/3dwarehouse/details?mid=f8f977a3da859f4097046e48d8f1e936
              A bunch of shaving horses in varying levels of detail.
              design by Roy Underhill: http://sketchup.google.com/3dwarehouse/details?mid=148b2dfb4528637c3b2e33f081a6a142
              design by Drew Langsner: http://sketchup.google.com/3dwarehouse/details?mid=b91c7fb48520572997046e48d8f1e936
              design by Richard Burton: http://sketchup.google.com/3dwarehouse/details?mid=e8edc210a6a5155997046e48d8f1e936
              design by John Alexander: http://sketchup.google.com/3dwarehouse/details?mid=8f4a4436ce431db97046e48d8f1e936
              design by Brian Boggs/Lie Nielsen: http://sketchup.google.com/3dwarehouse/details?mid=8edddcdd3d53628697046e48d8f1e936
              And a study which does not meet your criteria at all, but which has been very useful to me in planning a shaving horse design:
              http://sketchup.google.com/3dwarehouse/download?mid=67ca271cb7cf77013b2e33f081a6a142&rtyp=lt&ctyp=other&ts=1221827759000http://sketchup.google.com/3dwarehouse/download?mid=67ca271cb7cf77013b2e33f081a6a142&rtyp=lt&ctyp=other&ts=1221827759000
              Error 404 (Not Found)!!1
              (sketchup.google.com)
              Many more at http://sketchup.google.com/3dwarehouse/search?uq=18231480013402454788 . Not all are woodworking projects, but there are many which could be useful to woodworkers.
              • H
                Hazza
                Great news, Google has added a new feature to the 3D warehouse. You can add collaborators for a model or even a collection. I am opening up the "SketchUcation Woodworking" collection to anyone that wants in.
                Send me a PM with your e-mail address and I will add you as a collaborator. Collaborators are be able to add models to the collection.
                This additional feature is a step towards my vision of this woodworking collection being "owned" by the SU community.
                • GaieusG
                  Note that you need to have a Google account for this and you need to send that email address to Hazza so that he invite you as collaborators.
                  Also, there is a limited number of changes you can make and to which you can revert your collection, so from time to time "purge" older changes from the History tab.
                  Happy collecting! 👍
                  Hazza, be careful with the permission settings!
                    Sawduster
                    Here is a Neo-Queen Anne Tall Chest
                    May all your dimensions be the sum of their total.
                    Jerry
                    http://www.sawdustersplace.com
                    • K
                      ktkoh
                      I need some help on uploading files to the 3d warehouse. I have some furniture models that I saved as kmz files but when I tried to upload one it gives me an error message that there needs to be at least one model in the file to upload.
                      Any ideas what I am missing?? JillsBed.kmz
                      Keith
                      • H
                        Hazza
                        What is a kmz file? What program did you use to create it?
                        3D warehouse only lets you upload SketchUp models.
                        • GaieusG
                          kmz is the file type SU creates from a model for Google Earth. From SU you can only upload kmz files however on the front page of the WareHouse you can directly upload kmz files as well. But you cannot use them in SU later so unfortunately it would no be help for SU modelers.
                          • H
                            Hazza
                            The last 4 links take you to the same model.
                            • K
                              ktkoh
                              Thanks for the help loading models to the 3d warehouse.
                              Here are the models I uploaded there are some that don't show the full joint detail as I have been using loose tenons and sometimes add this as I build in the shop. Otherwise all parts are components and to scale.
                              http://sketchup.google.com/3dwarehouse/details?mid=200fe2e2486a0ddf85c5f690e9252fc5
                              http://sketchup.google.com/3dwarehouse/details?mid=c9dd43888905630285c5f690e9252fc5
                              http://sketchup.google.com/3dwarehouse/details?mid=3357d112432da01b85c5f690e9252fc5
                              http://sketchup.google.com/3dwarehouse/details?mid=509d9d137fd7465a85c5f690e9252fc5
                              http://sketchup.google.com/3dwarehouse/details?mid=f006ed79465eb37a85c5f690e9252fc5
                              http://sketchup.google.com/3dwarehouse/details?mid=754372e400efa8a485c5f690e9252fc5
                              Thanks for looking
                              Keith
                              • K
                                ktkoh
                                I fixed the links so all models are shown
                                Keith
                                • H
                                  Hazza
                                  I will have a look at these tomorrow.
                                  • H
                                    Hazza
                                    Sheet music cabinet:
                                    Sorry, but criteria 4 is "No overlapping solids".
                                    Have a look at the "side slats" component, it overlaps the side rail, the side slat and the post. Same thing with the shelves and the back.
                                    Media Center:
                                    Meets the model criteria, although I have a woodworking type question about the bottom rails. They seem to be mortise and mortise not mortise and tenon joints. Is that a mistake or do you put in a seperate piece of wood to fill both holes?
                                    Dresser:
                                    It's a complex model with many pieces but what I looked at looked all good.
                                    Youth desk:
                                    Same issues as the music cabinet, in the same locations too, side rail, side slat and legs.
                                    Night Stand:
                                    At first the orbiting was weird, then I figured out you had the camera in parallel projection. There are gaps in the woodworking like between the bottom stetcher and the shelf but it meets the criteria.
                                    Queens size bed:
                                    The foot board and head board overlap both the rails. It does not stop it being in the collection but I thought you would like to know some of the components don't have material on all faces, for example the ends and bottom of the side rails.
                                    • GaieusG
                                      You've become rather picky, Hazza! 😛
                                        @hazza said:
                                        [b]Media Center:
                                        Hazza, are you familiar with "loose tenon" joinery?
                                        http://www.kk.org/cooltools/festool-domino-joiner-sm.jpg
                                        http://www.werkzeug-news.de/news6/img/h-festool-domino-aw4.jpg
                                        • K
                                          ktkoh
                                          Thanks for lookig at the models. I had forgot that I omitted the slots for the slats in the models where the 1/4 panels sit in the rails and styes. I will remeber to include that in the future and will go back and fix the models.
                                          Yes I have started to use loose tenon joints since I built a fixture that works with an old shop smith and works like a horizontal router so long parts are no longer a problem. (except my shop is narrow and crowded)
                                          The gap in nightstand is intentional and required for seasonal wood movement as the shelf is solid wood.
                                          I only use texture where visible from the front and sides most of the time to show the family what thier designed furniture will look like and to get the approval to build.
                                          Keith
                                          • H
                                            Hazza
                                            Yes and it's what is not accepted into the collection that sets the quailty. If I let that model slip in why not the next one. Then the next one that is slightly less quailty than that... etc etc.
                                            No, that's why I asked. I am a SU modeler that does woodwork models, not a woodworker that does SU models.
                                            I have no doubt in my mind that there is heaps of woodworking stuff I have never seen before. That's why I like detailed woodworking plans. I am able to follow the plans with no prior woodworking knowledge.
                                            Now I am familiar with loose tenons... you learn something everyday.
                                            When you do let me know and I will add them to the collection.
                                            • 2 / 8
