    Texture: how to map it to a bending cylinder
    21 Posts 8 Posters 5.6k Views 8 Watching
    • V
      Voder Vocoder
      Remus,
      My apologies. If using projected texture this way is what you were talking about, then it does indeed seem to work. Very clever idea: my compliments.
      And Taff, it was real quick and easy.
      ~Voder
      • soloS
        http://img122.imageshack.us/img122/3787/psimagecw7.jpg
        http://img117.imageshack.us/img117/5377/supluspspfl7.jpg
        • TaffGochT
          TaffGoch
          I based my wrap-around interpretation upon...
          ...so the lines wrap around the cylinder all the way through...
          ...assuming he meant "...all along the length."
          I first considered using a projection from the side as well, but that would only work with specialized cases (and it works well, as demonstrated by Remus and solo.) I, myself, have put side projections to good use, in the SU modeling of terrain altitude:
          http://sketchup.google.com/3dwarehouse/details?mid=77627ea5941ff3d387ecd6083924dba
          I sought a solution that would work with any geometry, no matter how it twists-and-turns in 3 dimensions. No such luck, without the tedious, repeated sampling/painting. Makes me wonder if our community ruby gurus have pondered this?
          Taff
          "Information is not knowledge." -- Albert Einstein
          • V
            Voder Vocoder
            Sure, Taff, if you want to add emphasis on "around," be my guest, but one could just as easily add emphasis this way:
            As I said, CurryPork could have done us all a favor by selecting his words--and his picture--with greater care.
            At this point, I guess we could either assemble a panel of semanticians, cryptologists, and empaths to try and unravel this mess for us, or we could simply say we gave it our best shot and walk away from it, with no cause for shame.
            I vote for the latter.
            ~Voder
            • C
              CurryPork
              I apologyze for my bad english (my third language). I knew my question didn't make sense, but what I meant is how would you wrap that texture as TAFF had shown with his colored image. And thanks Remus and Voder for demonstrating that this can be done with the projected map. It works well for what I wanted to accomplish.
              Thanks everyone.
              • C
                CurryPork
                OK, it's not working as well as I thoght... I applied the projected texture to the bent cylinder and it looks fine but when I rotate this shape, it doesn't hold the texture since the texture is "projected". Any suggestion on how to resolve this is appreciated.
                  remus
                  Could you post the model? i cant reproduce the issue.
                  • GaieusG
                    Hi Curry Pork,
                    When you have applied the texture, turn on hidden geometry (View menu), right click on one of the facets > texture >position and without doing anything else, hit enter.
                    Now turn off hidden geometry, select the Paint bucket tool and press Alt. It will turn into a sampler; sample the still selected facet and apply it to the whole surface of your tube.
                    If this does not screw up the UV coordinates (in which case I second what Remus says; post your model), it should fix the texture move issue.
                    • V
                      Voder Vocoder
                      To reproduce the effect I depicted above (which is a series of circumferential rings running all along the bent cylinder, and which consistently gives that appearance from all angles), paint the texture with the stripes turning through a bend onto a vertical surface (a rectangle) that is lined up with the bent cylinder itself, just as I have shown. Then right-click the rectangle and select Texture > Projected. Then use Alt-Bucket to sample the projected texture, and finally click on the bent cylinder with the Bucket tool.
                      See attached.
                      ~Voder
                      bent-cylinder.skp
                      • C
                        CurryPork
                        Thanks everyone and thanks Voder for posting that model. I think I got this figure out so there's no need to post my model anymore.
                        Again, thank you all.
                        • romboutR
                          rombout
                          oke solo how would i do this than. it needs to go around
                          • GaieusG
                            That's because of projecting the texture. It is "best" when seen from the front you project it on AND from the back (although it's mirrored there) but on the sides it's always "smeared" like that. This is the nature of projection and it is (well) intended to behave like this.
                            You should rather wrap that texture around or use Whaat's UV Tools plugin to map it cylindrically.
                            Could you attach that Kerky image itself?
                            • romboutR
                              rombout
                              this is what i got... i moved to a different project but got a UV mapping problem again
                              the second image is where i got a problem again
                              resolved it a bit
                              the new problem
                              ther project
                              • GaieusG
                                Well, a texture is extremely hard to position in 3D in a way that it looks seamless all, three connected faces. But this is similar to real world; an upholsterer (is that the proper word?) couldn't adjust the pattern seamless either. You can, of course, achieve much better results than in your picture (see attached).
                                Here I made the rounded edges with Fredo's RoundEdge by Bezie plugin. Then made the following steps:
                                1. Turned on hidden geometry
                                2. painted the top face with the material
                                3. right click > Texture > Position (do nothing but...) hit Enter
                                  (this will "fix" the texture coordinates to the face instead of the word coordinates)
                                4. sampled the material and applied it to the small facets of the rounded edge one by one advancing from top to bottom on both sides
                                5. sampled the material from the side and applied it to the vertical facets proceeding from outside towards the corner - where eventually you can see the inevitable seam between the two sides.
                                  Of course, you can "hide" this corner seam with some "carelessly" and "untidily" placed blanket or anything here but as I said above, this seam would (most probably) be there in real world, too.
                                • arail1A
                                  arail1
                                  Is there any way to do the opposite? Make the texture follow the curve rather than go perpendicular to it - as in the grain of wood following the curve in bent wood furniture? Or following the line of a railing?
                                  • GaieusG
                                    Well, this question is just "right at the perfect time". There's a new plugin called UV Toolkit with which you can easily do this although you'll ne3ed "special" textures for this as it will stretch the whole texture onto the individual facets of a curved structure.
                                    If you look at my post there (second in the topic) and my second, tubular arch there, first, before I rotated the texture, the stripes ran "lengthwise", nicely following the curve.
                                    Of course, it is not desirable with a brick arch but is with your grain example. It's just a matter of segments in the curve to be nice.
