    Barn WIP
    56 Posts 5 Posters 3.1k Views 5 Watching
    • soloS Offline
      Csaba, I normally type x23.
      Anyway, mannie I hope this helps:
      http://img399.imageshack.us/img399/5838/circlearrayvl3.gif
        Mannie
        Ah, that is easier to follow thanks Solo, gonna give this a try in a few mins πŸ˜‰
        just finnished the ladder πŸ˜‰
          @solo said:
          Csaba, I normally type x23...
          😳 Yes, exactly. Sorry Mannie for misleading you! 😳
            Mannie
            Almmost i guess, except for the openings betweeen the planks that is. πŸ˜‰
              Mannie
              with straight planks i can do it now πŸ˜‰
                I think an easier way is to use the follow me tool.
                Attached is a file. When you open it,
                1. click on the surface of the circle with the Select tool (note that I exploded the circle to get the pieces to be faceded instead of softened but it could have been done by lowering the softening angle as well)
                2. then click on the face of the piece with the Follow me tool
                  If you still want to assemble it from pieces, now turn one of them into a component, delete the rest and do the radial array with this component (they will obviously fit nicely).
                Barrel.skp
                  Mannie
                  Thanks that is easier indeed, however i learned both ways now so that is allways a good thing 😎
                    Yes, exactly, that's the main point. πŸ‘
                      Mannie
                      Good morning πŸ˜‰
                      One last question about this, i think i calling it done, but i noticed when i did the test render in vue to see how it would look like the materials on the inside became the same as i stick on the outside in vue. Is this normal ? or do i have to do something to it so that won't happen ?
                      Thanks in advance
                      M.
                        Where inside? On the back faces?
                          Mannie
                          Yes i think the back faces when i give it a material in SU that is ok but in vue it aint
                            Topmost rule when it comes to rendering: in SU never let a back face be displayed (and never try to render it in an external renderer). If you see any back (blueish) face while modeling, immediately right click and "reverse faces" (you can do this with a whole selection set as well).
                            So was thisthe problem or have I misunderstood something?
                              Mannie
                              That is the problem then, if i reverse one side the other side get purple and vice versa πŸ˜‰
                                Well, obviously a face has two sides; a fron one (generally some kind of white or beige) and a back one (some greyish blue by default).
                                  Mannie
                                  next time i close the doors πŸ˜‰
                                    No, just in general give everything a thickness - like in real life.
                                      Mannie
                                      Thanks. i'll remember that for my next one, scene in vue is almost set up now πŸ˜‰.
                                      • 3 / 3
