    Fractal Tree Maker for SketchUp - Free add-on
    extensions
    158 Posts 44 Posters 68.2k Views 44 Watching
    • Chris FullmerC
      Yeah Stu, that would be pretty easy. You could create all 4 seasons and then combine them in a DC. Then you could have a pull down option as to what season to display. You could also creat a series of heights for each season, then make a menu that would let you choose what age to show during what season. All of this is also do-able by some tricky layer management too though if you don't want to dig into DC's
      Alan beat me to it
      • Al HartA
        Al Hart
        (We were just talking about what to do about seasons about an hour ago)
        Although we are all looking for a good use for Dynamic Components, the layer idea might be better.
        You could have just 4 layers, the same in each component, and then change the season for all plants at the same time.
        Also, we could make a generator which allows you to specify bark and leaf images for each season and make all 4 seasons at the same time, and create the component with all 4 seasons in one step.
        And, of course, we could do the same with age - generating images for 2, 5, 1- and 15 years for each plant.
        Al Hart
        IRender nXt from Render Plus
        • Chris FullmerC
          I think I agree that seasons through layer management might make more sense here because it would be a universal change. DC asettings are per DC. So each tree would need to be changed separately. Or they would need to ALL be in one container component that could then pass on the season information to each tree in the model. But I think the layers might work better. Although the layers could get bulky if you start specifying 4 tree ages and 4 seasons. That's 16 layers. But I guess its not that bad for the great functionality it would provide.
          • EarthMoverE
            EarthMover
            This is exciting! The idea of changing seasons is great. What if there were some magical way to tie a dynamic component into sketchup's shadow date control, then hypothetically you could animate the changing of the seasons!
            Also, I'm still curious about flowering.......is it possible to add a feature for this?
            Content Creator at Skapeup
            • david_hD
              david_h
              @stu said:
              Dave...youve got me confused now.....how did you explode the tree without seeing it? šŸ˜•
              But anyway, there is no point in exploding the tree unless you are using it in a renderer like Podium [in which case the square shadow turns into a realistic shadow after rendering]
              At the moment, the trees dont cast shadows in SU....unless exploded....and by doing that you also loose the 'face me' capability.
              Oh, and Id loose the roots....looks a bit like one of those plastic Xmas trees šŸ˜„
              Stu . . .I didn't see it in Podium, that 's what I meant. When I exploded for a Podium view, It didn't render shadows at all. I will keep playing with it. and that was my first tree with this program. you're abso. Right. the Roots are bad. Walmart Xmas tree was my first thought as well. But I was just seeing how to do it and what it offered.
              Thx,
              D
              • G
                gaganraj
                i'm unable to install. is anyone else having issues? it said i was missing a certain .dll file and to reinstall. I tried that a few times, to no avail. then all of a sudden my license for v7 says its expired?!
                • Al HartA
                  Al Hart
                  We just posted a new version.
                  Give it a try.
                  If it says it is missing a DLL, try to note which one it is.
                  Downloads are available from:
                  http://www.renderplus.com/pdf/download.htm
                  Al Hart
                  • Al HartA
                    Al Hart
                    We uploaded a new version which:
                    1. Clips the roots at the ground - right now we make an image which includes roots below the ground. That is useful sometimes, but much too confusing.
                    2. Creates the image (and component) so that the center of the bottom of the trunk is at the center of the image (and component)
                    Downloads are available at: http://www.renderplus.com/pdf/download.htm
                    Al Hart
                    • Al HartA
                      Al Hart
                      I chatted with the developer today. He plans to add seasons someday - but he isn't quite sure how he would do it. I suggested allowing 4 leaf images per tree and using one for each season. But he says you will also want to change leaf density, size, etc. So for now, we are going to take an approach were you create different .ArPlant definitions for each season and we will combine 2 or more into a single plant by layer.
                      I also, didn't make much progress in implementing flowers or other items on a tree. One idea would be to create a leaf which is really two leaves and a flower and see if that offers any promise.
                      Al Hart
                        Sushij
                        Hi. I am running SU7 and can not get the shadows to work in SU Podium. They are just always black boxes. Is there something I am missing. I have done everything that was listed above, such as exploding them. But I can not get them to put correct shadows in a render. Thanks for your help. You are doing a great job.
                        ~Jeff
                        • soloS
                          Jeff, I'm going to take a guess that the reason you are not seeing a shadow could be because you have not created a ground plane for the shadow to cast onto maybe?
                            Stu
                            Jeff, Im not sure what the problem is....you seem to be having the same trouble as Dave.
                            What Im doing is exploding, and then for some reason exploding again until the component bounding box is gone and there is just a line outline left...I usually group the image for easier editing but it doesnt seem essential. At this stage you should be left with a square shadow.
                            With Podium 1.6, I work with the 'dark' shadow slider set to 8 or 10....PNGs seem to produce soft shadows when rendered but I have yet to see a square shadow after rendering.
                            Im using SU6, SU7, Win XP and Vista
                            EDIT:....This will ONLY work with Podium 1.6 beta
                            http://www.landesign.com.au
                              steelers05
                              OK i just downloaded this and tried it, but it is killing my computer. Do you have to have a beast of a computer to run this plugin? It literally took 5 minutes to start up and it was so slow running that is was practically unusable. I dont know if it is an installation issue, because it does work and pull up, it just doesnt work fast enough. Anyone had similar issues?
                              • EarthMoverE
                                EarthMover
                                My attempt at some flowering Crape Myrtles. I photoshopped flowers in with some leaves. Worked out okay. As far as the Podium shadows....worked good for me. Took some playing with the Dark and Light sliders.....believe it or not, I got the best results from having the light slider set down to 10 and the dark slider up to 35 with "use sun for shading" checked. With the sliders the other way, I found the shadows too faint to really see. (using 1.6)
                                http://img233.imageshack.us/img233/3808/2008112510142739szk4.th.jpg
                                http://img233.imageshack.us/images/thpix.gif
                                http://img219.imageshack.us/img219/3554/crapemyrtleredbx3.th.png
                                http://img219.imageshack.us/images/thpix.gif
                                http://img75.imageshack.us/img75/1971/crapemyrtleredalphawc9.th.png
                                http://img75.imageshack.us/images/thpix.gif
                                http://img219.imageshack.us/img219/4630/crapemyrtlewhitetd4.th.png
                                http://img233.imageshack.us/img233/5710/crapemyrtlewhitealphaed7.th.png
                                • david_hD
                                  david_h
                                  so what is the upper limit of Tree-ness to this thing? I was doing a conifer shaped tree, with some foliage of course set it to Medium. SU and RP Bogs down and I have to restart. Anyone else having this trouble?
                                  D
                                  • Alan FraserA
                                    Alan Fraser
                                    Al, is there any way of having the final render dictated by the view you set the tree to in the first screen? I tested a sample tree with just a single root....so I could tell the orientation...and it seems that whichever way you rotate the tree in the first window, it always renders from the same fixed point, with the root pointing to about 5 o clock.
                                    3D Figures
                                    • Al HartA
                                      Al Hart
                                      Trees should take just about 5 minutes (or less) to create. But it is definitely related to the speed of your computer and what else is going on.
                                      There is also a Render button in the Tree Editor (while you are defining the tree). It runs at about the same speed. It the render in the Tree Editor is much faster then the render in the final image maker, then let us know.
                                      If they are both too slow, then it is probably time to consider getting a newer computer.
                                      Al Hart
                                      • Al HartA
                                        Al Hart
                                        We set up the view with the camera at 1/2 the height of the tree, and pointing at the center of the tree.
                                        I presume you would like to be able to rotate the view (rather than raising or lowering the camera). We can add this. Also, we hope to add a re-render button so you can change things like the resolution or view and render again.
                                        We can't read the view from the first window, but we can let you rotate it in the second window.
                                        But give us a week or so to make the changes.
                                        Al
                                        Al Hart
                                        • AnssiA
                                          Anssi
                                          About performance issues:
                                          I tested on two computers.
                                          1. P IV 2.8 GHz (non-HT), 1.5GB RAM, Nvidia Geforce FX Go 5200, XP Home Finnish SP3, opens and runs very slow (more than an hour for medium image)
                                          2. P IV 2.66 GHz (HT), 2 GB RAM, old ATI 9200-based card, XP Pro English SP3, opens and runs a zillion times faster, about as fast as others have reported here, default conifer about 5 minutes medium size
                                          So I am puzzled. I used the same file to install on both.
                                          It might be the install: The first showed no progress at the "Microsoft Visual C++ Redistributable" window, it just stayed there for a while and then vanished, the second showed a progress bar. It worked the same with the earlier and later version.
                                          It might be the non-HT processor.
                                          It might be the Windows or language version
                                          It might be Norton security software: Norton 360 on the first, Norton Internet Security on the other.
                                          Never run into this kind of behaviour before. Usually the performance between the two is indistinguishable, with the first maybe a bit faster.
                                          Does this inspire any thoughts?
                                          Anssi
                                            Could be a graphic card issue if the app makes use of the card for the calculations... Just guessing here...
                                            With your input, this post could be even better šŸ’—
                                            • 5 / 8
