    Fractal Tree Maker for SketchUp - Free add-on
    extensions
    158 Posts 44 Posters 68.2k Views 44 Watching
      richcat
      Al your a
      http://nxt.accurender.com/emoticons/emotion-30.gif
      Leaf if attached if body wants.
      Take a look at AndriyG81 for some bark textures.http://www.sketchucation.com/forums/scf/viewtopic.php?f=40&t=13226
      • GaieusG
        Hi Richcat,
        Thanks for the leaf! And surely there are a couple of superb bark textures down there! šŸ‘
          digby dart
          Thanks Al Hart. šŸ˜„
          • soloS
            Al
            When making Palm trees the bend option shows in the raytrace but not in the component, it straightens out.
            • Alan FraserA
              Alan Fraser
              Fill yer boots.
              http://local.wasp.uwa.edu.au/~pbourke/texture_colour/bark/
              Plus all the leaves you could ever want.
              Note: these are links to collections, not the images themselves.
              http://www.3dmd.net/gallery/index-22-page-1.html
              3D Figures
                richcat
                Heres another link from old post by ilay7k on leafs, but I have not tried it out yet http://www.polas.net/download/leaves.php
                • EarthMoverE
                  EarthMover
                  Al, thanks for sharing......this really made my morning. It's like Onyx for Sketchup! Amazing stuff! I'll see if I can do some testing as well.
                  EDIT - Al, when I download from the link you provided on the renderplus forum, I get a .zip file that is empty (0 bytes)......any ideas?
                  Content Creator at Skapeup
                    richcat
                    @alan fraser said:
                    I used my technique for exporting a vector outline from PS, then merged that and the image directly in SU. It takes about 10 minutes, but it's a little more controllable.
                    Hi Alan do you have a link to this please - I tried a quick search with no results.
                    • Alan FraserA
                      Alan Fraser
                      This version isn't quite ready for the 3DW yet, but here's a SU shadow-casting version. I didn't use the script; I used my technique for exporting a vector outline from PS, then merged that and the image directly in SU. It takes about 10 minutes, but it's a little more controllable.
                      Link to tutorial
                      tree 8m.skp
                      3D Figures
                      • Alan FraserA
                        Alan Fraser
                        Link added.
                        3D Figures
                          richcat
                          Thanks Alan šŸ‘ (I tried searching "exporting a vector outline from PS")
                            JuanV.Soler
                            Thank you very much Al, šŸ˜„
                            • GaieusG
                              Try again, Adam; it should work.
                              • bigstickB
                                bigstick
                                I have downloaded this and it is an exe file, which means Windows only. Any chance of a Mac version too Al?
                                • Al HartA
                                  Al Hart
                                  The Fractal tree software is Windows only, and I just can't seem to get the developer interested in MAC version.
                                  Al Hart
                                  IRender nXt from Render Plus
                                  • Al HartA
                                    Al Hart
                                    @at3d said:
                                    Stu, I have installed and located within SU but when pressed to, what I hope will activate, nothing happens in SU.
                                    My machine is running Vista, could this be an issue?
                                    Try opening the Ruby Console, and typing in: load('RpTreemaker,rb') and see if you get any error messages. Of if you get any error messages when you click Plugins/RpTreeMaker.rb
                                    If there are no problems there, go to: Program Files\Render Plus Systems\RpTreeMaker
                                    and see what happens when you run TreeEditor.exe by hand. There may be a DLL or something which is missing.
                                    Al Hart
                                    • Al HartA
                                      Al Hart
                                      @alan fraser said:
                                      Excellent Plugin Al. It's good to hear that it's technically possible to load new bark textures also.
                                      We didn't learn that we could add bark and leaves until yesterday. If I had read Richcat's leaf post earlier (and more carefully) I would have known.
                                      If you use your own leaves and bark and post the model to the 3D Warehouse, then anyone downloading the model and trying to use the same leaves and bark as the basis for a new tree will not have them. The 2D image will work fine - but if you want to use the .ArPlant tree definition, the images will be missing.
                                      We will plan to store the images on the SU component as well, so that users can truly share the designs.
                                      Al Hart
                                      • GaieusG
                                        Yet another one - now an attempt to make a plane ("like") tree.
                                        And the link to the WH:
                                        http://sketchup.google.com/3dwarehouse/details?mid=2e7a72e69abb669cffe3705437c1b39c
                                        • Al HartA
                                          Al Hart
                                          @at3d said:
                                          I have loaded the link but once back in SketchUp 6(Pro) and selecting the plugin nothing is happening...any suggestions?
                                          See the next post )two posts down) where I offer some debugging ideas.
                                          404 Not Found
                                          (www.sketchucation.com)
                                          Al Hart
                                          • Mike LuceyM
                                            Mike Lucey
                                            Firstly a BIG thanks Al. This is very generous of you and just
                                            further demonstrates the ethos of the SketchUp Community. I'm a
                                            Mac user also BUT we do have BootCamp so should be able to use
                                            Fractal Tree Maker šŸ‘ Hey! we can't always have the best of
                                            both Worlds šŸ˜‰
                                            Mike
                                            With your input, this post could be even better šŸ’—
                                            • 2 / 8
