    Windowizer4 now available!
    55 Posts 12 Posters 14.7k Views 12 Watching
      RickW
      @cheffey said:
      @utiler said:
      Cheers Rick.
      BTW, any plans for a doorizer? would be real handy to keep it 'in house'..... 👍
      I'm Voting for Doorizer also!!!
      Looks like I'm adding a "Doorizer" plugin to my ToDo list. 😄
      RickW
      [www.smustard.com](http://www.smustard.com)
        RickW
        @utiler said:
        Thanks so much Rick, bought it and loving it!!!
        A few questions:
        1. Great to see it cuts both faces; when deleting a window, the hole still remains. Is this normal? I just assumes that the whole window would act like a component but it appears that the opening is separate from the window [if grouped]...
        2. When extracting Windowizer4, i over-road a few rubies, I assume were part of windowizer30b5. Which files do I delete from the plugins folder that are only associated with windowizer30b5? I want to get rid of what i don't need...
        3. Color selection - there is 7 options for coloring both the frame and glass, is there a way to access the materials palette?
        Way 😎
        Glad you're happy with it! 😄
        1. Yes, the hole becomes part of the geometry of the model, just as if you had created the hole manually and then put a window in it (since components only auto-cut a hole in one face, it was the only way to penetrate a wall). I haven't yet decided the best way to handle deleting the windows yet. Part of the challenge is that things can be edited, and there's no guarantees of what geometry should stay or go.
        2. You can probably safely delete "EntsGetAtt.rb" (or move it to a subfolder to make sure everything else still works, prior to deleting it)
        3. Windowizer can currently only access the materials in the model. I know it's a pain, but you'll need to paint something with the materials you want to use before they'll show up in the list. I haven't given up, though - I'm still investigating how to get to the material palettes.
        RickW
        • F Offline
          fakircho
          Hi Rick
          Thank you for this great plugin. I have a issue on my Mac. I can not select any of the drop down options
          , such as frame material, glass material, make group and front side only. They just don't work, nothing
          happens when you click on them. Also i saved a style but then when i tried to make another window it just vanished.
          It would be great if this can be looked at for us Mac users.
          Thanks a lot, loving the new Windowizer
            RickW
            Looks like I've fallen prey to the infamous Safari-SU-Ruby bug. 😞
            I think I know how to work around it, but it will take some time.
            I'll post a notice when the updated files are ready to download.
            Thanks,
            RickW
              chango70
              Rick what is the Safari Su bug? Anyway I've tried it with Ruby Console open and it went like this:Question.jpg
                putnik
                Rick, will W4 work in SketchUp 5?
                http://keshas.info
                  RickW
                  @chango70 said:
                  Rick what is the Safari Su bug? Anyway I've tried it with Ruby Console open and it went like this:[attachment=0:10baznmq]<!-- ia0 -->Question.jpg<!-- ia0 -->[/attachment:10baznmq]
                  If you had Windowizer3, you would have an older version of offset.rb. Did you overwrite that one with the offset.rb from the Windowizer4 .zip file? The error messages suggest that could be the problem.
                  The Safari-SU-Ruby bug is a problem where webDialogs don't communicate back and forth with SU as they should. In this case, the plugin tries to add dropdown menu items to the webDialog (list of materials for frames and glass, and Yes/No preferences for "Group" and "Front Only" options). I suspect the bug is causing the blank dropdown menus.
                  Unfortunately, no. Because it uses WebDialogs, it requires SU6. If there's enough interest, I could try to rework it for SU5, but it would lose some functionality.
                  RickW
                    chango70
                    Hi Rick.
                    It is working now. Thanks alot!
                    One thing. I can't get it to cut walls still. When I made a 500mm thick wall and tried to use the plugin (i tried 500mm and 1000mm for max wall thickness) it didn't cut a hole through the wall. Am I doing something wrong?
                    Cheers
                      RickW
                      Urgh. Typo on my part. Re-download to get the fixed version.
                      RickW
                        chango70
                        Rick, stupid question but, do I use the same link Smustard sent me to Re-download? I tried that and it say it can't verify my email.
                        • EdsonE Offline
                          Edson
                          Thanks,
                          looking forward to it.
                          http://www.mahfuz.arq.br
                            RickW
                            This may seem like a dumb question, but did you use the correct email address? Some people have a seldom-used email address for PayPal, and sometimes forget that's the one to use to access the download.
                            RickW
                              RickW
                              To recreate a lost post:
                              I have uploaded an update to Windowizer4 that fixes an obscure bug (could cause a bugsplat when using Windowizer4 inside a group with "Front only" set to "Yes").
                              The next planned update will include a right-click-menu option to start Windowizer4, and I hope to have style exporting/importing done as well.
                              RickW
                              • utilerU Offline
                                utiler
                                Uploaded the update to smustard, Rick?
                                Just Curious...
                                • jujuJ Offline
                                  juju
                                  Rick, is it possible to mail a memo to people who've bought scripts when a newer version is available? If I didn't pass through here I wouldn't have known about the update (bug fix), and I bought & DL'ed on 11/11/08.
                                    RickW
                                    Correct - uploaded to Smustard.
                                    Yes, I intend to do that this weekend yet.
                                    RickW
                                    • jujuJ Offline
                                      juju
                                      Sweet! I've been trying to download the latest version through MySmustard but for the some or other reason it is not working at the moment, I also tried downloading using the download URL given in the e-mail I got from Smustard, but this too seems not to be working. I'll try MySmustard again later, I hope it'll be working then.
                                      • jujuJ Offline
                                        juju
                                        Got the latest update eventually. MySmustard is such a sweet plugin! If only there was something similar for the other plugins... 😞
                                        • EdsonE Offline
                                          Edson
                                          i could not get the original W4 to work on my mac but your latest update did the trick. there is no more need to use .m, .mm or .cm for metric units. W4 assumes the file units.
                                          a wish or two: why not have at least one transparent material in the glass material drop list? would it be possible to access the paint bucket when defining the material for the frame and glass?
                                          thanks for this great plugin.
                                            RickW
                                            While I haven't found a way to do an "eyedropper" from a dialog, remember that the W4 dialog is modeless - you can use the paint tool's eyedropper to select a material from the model and see what its name is in the Materials dialog, then select that same material from the dropdown in the W4 dialog.
                                            I know that's not ideal, but it's the best available option for now.
                                            RickW
                                            • 3 / 3
