    Windowizer4 now available!
    55 Posts 12 Posters 16.2k Views 12 Watching
      RickW
      @chango70 said:
      Rick I can't get it to work for some reason. I've unzipped everything into the plugins folder. When I use the Windowizer4 dialogue it creates a single group. Am I doing something wrong?
      For metric, you need a dot between the number and the units, i.e. 50.mm
      Hope that helps.
      EDIT: I looked again at the image you posted. My first answer is still correct, but I see something I need to try to fix for default metric users: the default settings are 2" and 4", which are being converted to '~51mm' and '~102mm' without the dot, so that's my problem to fix. But, at least there's an easy workaround - make sure there's a dot. 😉
      Thanks for making me aware of that issue.
      RickW
      www.smustard.com
        RickW
        @thinkbuild said:
        Dear Rick -
        I haven't downloaded W4 yet (but I will soon) and I was just thinking - I've got a small project in Sweden, and there, we have triple-glazed windows. Do you think it would be possible to add an option, "# of panes of glass"? In Germany, we also use double-glazing and so on...I was thinking, I could perhaps just make a "thick" single pane but there might be situations in which it would be useful to model the "real" situation...
        I imagine it might at some point get a bit much, but since you are already working at such a high level of detail...
        Just a thought.
        best wishes,
        Jason
        I could add that if there's enough interest. We use double-glazed windows here, too. I just arbitrarily decided (for the sake of lower poly counts, primarily) that only the outside faces of the glass would be modeled, so I use 1" thick glass (which in reality would be two panes of 1/4" glass with a 1/2" airspace) for my models. The only other option right now is zero-thickness glass, which will draw a single face only. But, like I said, if there's enough interest, I could add it.
        RickW
        www.smustard.com
          RickW
          Any suggestions for the Visual Reference PDF?
          I wanted everything to be clear and easily cross-referenced, but it's possible I missed something. Is there anything that is not explained well enough?
          Also, if there's any feedback on the new Window Styles feature, I'd be glad to hear it. I'm still developing the Styles Manager (including rename/delete/import/export), so if you have any suggestions, now is the time. 😄
          Thanks, everyone!
          RickW
          www.smustard.com
          • utilerU Offline
            utiler
            There is one thing I thought about to do with the dialogue box, Rick....
            You have a 'mullion width' and 'mullion height' input. I worked out that one is for horizontal and the other is for vertical sizes. I thought is would be easier to differentiate Mullions from Transom; as they are know in building terms. It would also mean changing the input mode as well for 'Vertical panels' and 'Horizontal panels' to say 'number of mullions' and 'number of transoms" but maybe you have travelled to far down the road with the script to go back and change this..... just a thought, would make it easier to understand.
            Just Curious...
              RickW
              I could change "vertical panes" and "horizontal panes" back to "rows" and "columns", which is the terminology I used previously. Changing mullion height to transom height isn't a big deal as it only affects the dialog and the documentation. Thanks for the comments.
              RickW
              www.smustard.com
              • utilerU Offline
                utiler
                Cheers Rick.
                BTW, any plans for a doorizer? would be real handy to keep it 'in house'..... 👍
                Just Curious...
                  chango70
                  Hope that helps.
                  Hi Rick. Thanks for the quick reply. I still have the same problem this morning after following your instructions. I'll post an image when I have time.
                    Hi rick again,
                    I think that I'm running into some isues (I can elaborate later and attach images).
                    The Max wall thicknes doesn't sem to work for me; it's always the sum of the frame thicknes nd frame inset (OR I am doing something wrong).
                    I see your script is not scrambled so I can re-write my version to start with some more handy values in metric (although I hate ruining others' work) 😄
                    Anyway, I will include a re-translation of the html file to be added instead of this one now. Can I place charset metatags into the <head>?
                      cheffey
                      @utiler said:
                      Cheers Rick.
                      I'm Voting for Doorizer also!!!
                      BROS RŌMAN BRÄUN
                        RickW
                        @gaieus said:
                        Hi rick again,
                        It's clear I need to make some modifications for metric users, so I'll try to get that done ASAP.
                        "Max Wall Thickness" simply describes the maximum distance between 2 faces for them to be considered a "wall". If two faces are within the distance, Windowizer will cut an opening; otherwise, it will not. This is applicable primarily when using it for full 3D buildings where you have interior and exterior areas modeled.
                        RickW
                        www.smustard.com
                          RickW
                          @chango70 said:
                          Hope that helps.
                          Try again with the Ruby Console open, and let me know if you see any error messages.
                          RickW
                          www.smustard.com
                            RickW
                            @cheffey said:
                            @utiler said:
                            Cheers Rick.
                            Looks like I'm adding a "Doorizer" plugin to my ToDo list. 😄
                            RickW
                            www.smustard.com
                              RickW
                              @utiler said:
                              Thanks so much Rick, bought it and loving it!!!
                              A few questions:
                              1. Great to see it cuts both faces; when deleting a window, the hole still remains. Is this normal? I just assumes that the whole window would act like a component but it appears that the opening is separate from the window [if grouped]...
                              2. When extracting Windowizer4, i over-road a few rubies, I assume were part of windowizer30b5. Which files do I delete from the plugins folder that are only associated with windowizer30b5? I want to get rid of what i don't need...
                              3. Color selection - there is 7 options for coloring both the frame and glass, is there a way to access the materials palette?
                              Way 😎
                              Glad you're happy with it! 😄
                              1. Yes, the hole becomes part of the geometry of the model, just as if you had created the hole manually and then put a window in it (since components only auto-cut a hole in one face, it was the only way to penetrate a wall). I haven't yet decided the best way to handle deleting the windows yet. Part of the challenge is that things can be edited, and there's no guarantees of what geometry should stay or go.
                              2. You can probably safely delete "EntsGetAtt.rb" (or move it to a subfolder to make sure everything else still works, prior to deleting it)
                              3. Windowizer can currently only access the materials in the model. I know it's a pain, but you'll need to paint something with the materials you want to use before they'll show up in the list. I haven't given up, though - I'm still investigating how to get to the material palettes.
                              RickW
                              www.smustard.com
                              • F Offline
                                fakircho
                                Hi Rick
                                Thank you for this great plugin. I have a issue on my Mac. I can not select any of the drop down options
                                , such as frame material, glass material, make group and front side only. They just don't work, nothing
                                happens when you click on them. Also i saved a style but then when i tried to make another window it just vanished.
                                It would be great if this can be looked at for us Mac users.
                                Thanks a lot, loving the new Windowizer
                                  RickW
                                  Looks like I've fallen prey to the infamous Safari-SU-Ruby bug. 😞
                                  I think I know how to work around it, but it will take some time.
                                  I'll post a notice when the updated files are ready to download.
                                  Thanks,
                                  RickW
                                  www.smustard.com
                                    chango70
                                    Rick what is the Safari Su bug? Anyway I've tried it with Ruby Console open and it went like this:Question.jpg
                                      putnik
                                      Rick, will W4 work in SketchUp 5?
                                      http://keshas.info
                                        RickW
                                        @chango70 said:
                                        Rick what is the Safari Su bug? Anyway I've tried it with Ruby Console open and it went like this:[attachment=0:10baznmq]<!-- ia0 -->Question.jpg<!-- ia0 -->[/attachment:10baznmq]
                                        If you had Windowizer3, you would have an older version of offset.rb. Did you overwrite that one with the offset.rb from the Windowizer4 .zip file? The error messages suggest that could be the problem.
                                        The Safari-SU-Ruby bug is a problem where webDialogs don't communicate back and forth with SU as they should. In this case, the plugin tries to add dropdown menu items to the webDialog (list of materials for frames and glass, and Yes/No preferences for "Group" and "Front Only" options). I suspect the bug is causing the blank dropdown menus.
                                        Unfortunately, no. Because it uses WebDialogs, it requires SU6. If there's enough interest, I could try to rework it for SU5, but it would lose some functionality.
                                        RickW
                                        www.smustard.com
                                          chango70
                                          Hi Rick.
                                          It is working now. Thanks alot!
                                          One thing. I can't get it to cut walls still. When I made a 500mm thick wall and tried to use the plugin (i tried 500mm and 1000mm for max wall thickness) it didn't cut a hole through the wall. Am I doing something wrong?
                                          Cheers
                                            RickW
                                            Urgh. Typo on my part. Re-download to get the fixed version.
                                            RickW
                                            www.smustard.com
                                            • 2 / 3
