    Windowizer4 now available!
    55 Posts 12 Posters 17.6k Views 12 Watching
    • GaieusG
      Okay, I have figured it out.
      On my "European" keyboard layout the decimal separator is comma. All the sizes appear with commas except the max wall thicknes which is separated bz a dot (period / full stop - call it as you wish) by default in the webdialog. If I manually change that to a comma, the script works.
      I guess this will be an issue with other localisations, too.
      Now I will get into the translation at last.
        RickW
        Gai,
        Glad you figured that out. I'll have to make some notes for using it and humbly ask the great volunteers who helped with the dialog to help once again with translating the documents.
        Thanks,
        RickW
        www.smustard.com
        • T
          thinkbuild
          Dear Rick -
          I haven't downloaded W4 yet (but I will soon) and I was just thinking - I've got a small project in Sweden, and there, we have triple-glazed windows. Do you think it would be possible to add an option, "# of panes of glass"? In Germany, we also use double-glazing and so on...I was thinking, I could perhaps just make a "thick" single pane but there might be situations in which it would be useful to model the "real" situation...
          I imagine it might at some point get a bit much, but since you are already working at such a high level of detail...
          Just a thought.
          best wishes,
          Jason
          • david_hD
            david_h
            RICK. I just purchased and am using it. It is awesome. Anyway to put it in a context menu rather than the pull down?
            It's much more friendlier that way> . . . 💚
            • C
              cheffey
              I just purchased it as well, and that's my only request is to add to a right-click dialog as David mentions.
              Works flawless though, going to be such a time saver.
              BROS RŌMAN BRÄUN
              • C
                chango70
                Rick I can't get it to work for some reason. I've unzipped everything into the plugins folder. When I use the Windowizer4 dialogue it creates a single group. Am I doing something wrong?
                • utilerU
                  utiler
                  Thanks so much Rick, bought it and loving it!!!
                  A few questions:
                  1. Great to see it cuts both faces; when deleting a window, the hole still remains. Is this normal? I just assumes that the whole window would act like a component but it appears that the opening is separate from the window [if grouped]...
                  2. When extracting Windowizer4, i over-road a few rubies, I assume were part of windowizer30b5. Which files do I delete from the plugins folder that are only associated with windowizer30b5? I want to get rid of what i don't need...
                  3. Color selection - there is 7 options for coloring both the frame and glass, is there a way to access the materials palette?
                  Way 😎
                  Just Curious...
                    RickW
                    Sounds like I need to put a right-click menu item in place... 😄
                    No problem - I'll add it to my list.
                    RickW
                    www.smustard.com
                      RickW
                      For metric, you need a dot between the number and the units, i.e. 50.mm
                      Hope that helps.
                      EDIT: I looked again at the image you posted. My first answer is still correct, but I see something I need to try to fix for default metric users: the default settings are 2" and 4", which are being converted to '~51mm' and '~102mm' without the dot, so that's my problem to fix. But, at least there's an easy workaround - make sure there's a dot. 😉
                      Thanks for making me aware of that issue.
                      RickW
                      www.smustard.com
                        RickW
                        @thinkbuild said:
                        Dear Rick -
                        Just a thought.
                        best wishes,
                        Jason
                        I could add that if there's enough interest. We use double-glazed windows here, too. I just arbitrarily decided (for the sake of lower poly counts, primarily) that only the outside faces of the glass would be modeled, so I use 1" thick glass (which in reality would be two panes of 1/4" glass with a 1/2" airspace) for my models. The only other option right now is zero-thickness glass, which will draw a single face only. But, like I said, if there's enough interest, I could add it.
                        RickW
                        www.smustard.com
                          RickW
                          Any suggestions for the Visual Reference PDF?
                          I wanted everything to be clear and easily cross-referenced, but it's possible I missed something. Is there anything that is not explained well enough?
                          Also, if there's any feedback on the new Window Styles feature, I'd be glad to hear it. I'm still developing the Styles Manager (including rename/delete/import/export), so if you have any suggestions, now is the time. 😄
                          Thanks, everyone!
                          RickW
                          www.smustard.com
                          • utilerU
                            utiler
                            There is one thing I thought about to do with the dialogue box, Rick....
                            You have a 'mullion width' and 'mullion height' input. I worked out that one is for horizontal and the other is for vertical sizes. I thought is would be easier to differentiate Mullions from Transom; as they are know in building terms. It would also mean changing the input mode as well for 'Vertical panels' and 'Horizontal panels' to say 'number of mullions' and 'number of transoms" but maybe you have travelled to far down the road with the script to go back and change this..... just a thought, would make it easier to understand.
                            Just Curious...
                              RickW
                              I could change "vertical panes" and "horizontal panes" back to "rows" and "columns", which is the terminology I used previously. Changing mullion height to transom height isn't a big deal as it only affects the dialog and the documentation. Thanks for the comments.
                              RickW
                              www.smustard.com
                              • utilerU
                                utiler
                                Cheers Rick.
                                BTW, any plans for a doorizer? would be real handy to keep it 'in house'..... 👍
                                Just Curious...
                                • C
                                  chango70
                                  Hope that helps.
                                  Hi Rick. Thanks for the quick reply. I still have the same problem this morning after following your instructions. I'll post an image when I have time.
                                  • GaieusG
                                    Hi rick again,
                                    I think that I'm running into some isues (I can elaborate later and attach images).
                                    The Max wall thicknes doesn't sem to work for me; it's always the sum of the frame thicknes nd frame inset (OR I am doing something wrong).
                                    I see your script is not scrambled so I can re-write my version to start with some more handy values in metric (although I hate ruining others' work) 😄
                                    Anyway, I will include a re-translation of the html file to be added instead of this one now. Can I place charset metatags into the <head>?
                                    • C
                                      cheffey
                                      @utiler said:
                                      Cheers Rick.
                                      I'm Voting for Doorizer also!!!
                                      BROS RŌMAN BRÄUN
                                        RickW
                                        @gaieus said:
                                        Hi rick again,
                                        It's clear I need to make some modifications for metric users, so I'll try to get that done ASAP.
                                        "Max Wall Thickness" simply describes the maximum distance between 2 faces for them to be considered a "wall". If two faces are within the distance, Windowizer will cut an opening; otherwise, it will not. This is applicable primarily when using it for full 3D buildings where you have interior and exterior areas modeled.
                                        RickW
                                        www.smustard.com
                                          RickW
                                          @chango70 said:
                                          Hope that helps.
                                          Try again with the Ruby Console open, and let me know if you see any error messages.
                                          RickW
                                          www.smustard.com
                                            RickW
                                            @cheffey said:
                                            @utiler said:
                                            Cheers Rick.
                                            Looks like I'm adding a "Doorizer" plugin to my ToDo list. 😄
                                            RickW
                                            www.smustard.com
                                            • 2 / 3
