    Silvershadow's eye candy 1: The river runs thru it
    125 Posts 62 Posters 74.6k Views 62 Watching
      csome
      Thank both! Eva was just an example i could say a egg but is ok thank for the model!
      I am going to try that, i was using the sandbox tool.
      Tomorrow i will post my results thanks!
      Cya
      http://csome.wordpress.com/
        johnsenior1973
        csome - You might want to look at this for reference material when modeling your Eva:
        http://forums.cgsociety.org/showthread.php?f=132&t=655501
          csome
          Nice! thanks man...
          I am working on it, i could get the shape, now i am trying to get the real form of "Eva", but i could make the egg style form with follow me tool.
          I made the contorn in CorelDraw, adn then exportit, and presto, i had the shape.
          Nice tip.... lets see if i can reduce the number of faces to get a more smooth form.
          Cya !
            csome
            Well guys here is part of my result using any plugins.
            I have some questions.
            Why my surfaces go so shaped? or sloped .... how can i make that the curve of her body and head go more "natural shaped".
            And how can i make the black part of his eyes? i try to make some kind of "deformed sphere" but i didnt figure it out. 😞.
            I need some kind of plugin to model this? or i am using the tools in the bad way?
            Thanks in advice!
            Sorry for my bad english!
            Cya!
              csome
              http://img71.imageshack.us/img71/4568/evaxw6.th.jpg
              • plot-parisP Offline
                plot-paris
                to get a smoother shape, you have to increase the number of segments for the arcs, defining the outline, as well as the circle you used for the follow me process (you did use follow me, right?)
                if you select the circle, or the arc tool you can see a number in the VCB at the bottom right of your screen. for a circle the default is 24 edges, for an arc its 12.
                simply type in a new number of segments, before drawing the arc/circle.
                when you drew the shapes you can even select these shapes (one by one) and change the number of segments in the entity info window lateron (this only works, if it still is a flat shape. it doesn't work with extruded shapes anymore)
                for the eyes... I think the best way is to draw them onto the body of your model, so that you can apply a different texture to them.
                if you don't want to use any plugins (like the marvellous OnSurfaceTools) I would suggest, model a vertical shape of the eye, extrude it right into the head of eva. then you group this extruded eye-shape. now you select the the part of eva, where the face is, right-click and choose "intersect with model", which cuts the outline of the eye-shape into eva's face.
                now you can mirror the eye-shape (by scaling it horizontally to -1) and repeat the process for the other eye.
                if you don't want to see the edges around the eyes, you can select them and (right-click) "hide" them, after you coloured the faces.
                  csome
                  Hi thanks for your advices plot!
                  I will try to changue the segments of the line, and extrude later, and see the better results:D
                  And i will try to get that "Onsurfacetool" because i was trying to do thw way you tellme for the eyes, but i cant make it...
                  Thanks again for your patience and efforts to explainme.
                  I will post my results later, one i get a good model i will render it:D
                  Cya
                  • N Offline
                    notareal
                    Thanks for the post. It was really inspiring!
                      silver_shadow
                      THANX GUYS FOR ALL THE COMMENTS ECT 💚
                        silver_shadow
                        updated the list in the start, have put a render in the list, for those who havent seen the render, or dont want to go that far down paging thru the pages to find the render.
                          Click Draw
                          Hey Silver....your extremely talented. Do you use SU in your daily work?
                          Jeff
                          Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                            silver_shadow
                            hi there, thanx for the comment, i only use sketchup. My profession is to build models for an architectural firm all day 😄 quite nice
                            been using sketchup for 3 years. My primary render engine i use is mainly Vray for sketchup, been using that for a year an a half
                              Camille
                              hye !!
                              I'm a young french user and I don't understand all wich write on this page but I'm really really impressed !
                              this render is amazing, very very good !
                              When I'll be able to do 1/4 of that I'll be happy !!
                              very nice !
                              Camille
                                akololo
                                great job!!!!
                                by the way, im still confused how to make the background...like the mountain... how did u make it?.
                                hehe
                                thanks... and job well done!
                                  silver_shadow
                                  like the old fashioned way. Create a alpha of your render, or just cut out the background via photoshop.
                                  so you will have a model which has no background. Then just put a mountain image in behind the model.
                                    skyscraper100
                                    OMG!!!!! this is AWESOME!! 😮
                                    btw what software?
                                    The way you think Creates reality for yourself.
                                      silver_shadow
                                      hit there
                                      All the candy series was an experiment to see how far i can push sketchup untill it folds
                                      So to be true to the program, i had to use only sketchup for modelling. The first candy was not really intended to be rendered, but eventually got rendered in vray and a little bit of photoshop. The candy 2 model went the same path, all 100% sketchup, no elements were build in another program and then brought back, because then it would have defeated the purpose. Renderd in maxwell, vray, and fryrender.
                                      2008 i will start my last candy, trying to push sketchup for one last time, building everything in sketchup again. I hope it will be bigger and better and at least ten times more intense than candy 2. But we all have to wait and see 😉
                                        Andrija Posarić
                                        Silver, I am really amazed with your work. The final product looks fantastic, and I like the atmosphere in the scene.I see that you utilized a lot of rubies:-) I haven't heard for half of them but, I see they are very useful.
                                        Keep up the inspiring work, I haven't seen work of such quality for a long time here.
                                        Cheers,
                                        Andrija
                                        Cheers, Andrija
                                          I doubt he will 😉
                                          • W Offline
                                            wheay
                                            very nice work! and tutorials.. thanks for sharing it to all. keep it up. 😍
                                            "i try to learn everyday"
                                            http://designerslandmark.blogspot.com/
                                            • 5 / 7
