    Silvershadow's eye candy 1: The river runs thru it
    125 Posts 62 Posters 76.4k Views 62 Watching
    • plot-parisP
      plot-paris
      to get a smoother shape, you have to increase the number of segments for the arcs, defining the outline, as well as the circle you used for the follow me process (you did use follow me, right?)
      if you select the circle, or the arc tool you can see a number in the VCB at the bottom right of your screen. for a circle the default is 24 edges, for an arc its 12.
      simply type in a new number of segments, before drawing the arc/circle.
      when you drew the shapes you can even select these shapes (one by one) and change the number of segments in the entity info window lateron (this only works, if it still is a flat shape. it doesn't work with extruded shapes anymore)
      for the eyes... I think the best way is to draw them onto the body of your model, so that you can apply a different texture to them.
      if you don't want to use any plugins (like the marvellous OnSurfaceTools) I would suggest, model a vertical shape of the eye, extrude it right into the head of eva. then you group this extruded eye-shape. now you select the the part of eva, where the face is, right-click and choose "intersect with model", which cuts the outline of the eye-shape into eva's face.
      now you can mirror the eye-shape (by scaling it horizontally to -1) and repeat the process for the other eye.
      if you don't want to see the edges around the eyes, you can select them and (right-click) "hide" them, after you coloured the faces.
      • C
        csome
        Hi thanks for your advices plot!
        I will try to changue the segments of the line, and extrude later, and see the better results:D
        And i will try to get that "Onsurfacetool" because i was trying to do thw way you tellme for the eyes, but i cant make it...
        Thanks again for your patience and efforts to explainme.
        I will post my results later, one i get a good model i will render it:D
        Cya
        http://csome.wordpress.com/
        • N
          notareal
          Thanks for the post. It was really inspiring!
            silver_shadow
            THANX GUYS FOR ALL THE COMMENTS ECT 💚
              silver_shadow
              updated the list in the start, have put a render in the list, for those who havent seen the render, or dont want to go that far down paging thru the pages to find the render.
              • C
                Click Draw
                Hey Silver....your extremely talented. Do you use SU in your daily work?
                Jeff
                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                  silver_shadow
                  hi there, thanx for the comment, i only use sketchup. My profession is to build models for an architectural firm all day 😄 quite nice
                  been using sketchup for 3 years. My primary render engine i use is mainly Vray for sketchup, been using that for a year an a half
                  • C
                    Camille
                    hye !!
                    I'm a young french user and I don't understand all wich write on this page but I'm really really impressed !
                    this render is amazing, very very good !
                    When I'll be able to do 1/4 of that I'll be happy !!
                    very nice !
                    Camille
                      akololo
                      great job!!!!
                      by the way, im still confused how to make the background...like the mountain... how did u make it?.
                      hehe
                      thanks... and job well done!
                        silver_shadow
                        like the old fashioned way. Create a alpha of your render, or just cut out the background via photoshop.
                        so you will have a model which has no background. Then just put a mountain image in behind the model.
                          skyscraper100
                          OMG!!!!! this is AWESOME!! 😮
                          btw what software?
                          The way you think Creates reality for yourself.
                            silver_shadow
                            hit there
                            All the candy series was an experiment to see how far i can push sketchup untill it folds
                            So to be true to the program, i had to use only sketchup for modelling. The first candy was not really intended to be rendered, but eventually got rendered in vray and a little bit of photoshop. The candy 2 model went the same path, all 100% sketchup, no elements were build in another program and then brought back, because then it would have defeated the purpose. Renderd in maxwell, vray, and fryrender.
                            2008 i will start my last candy, trying to push sketchup for one last time, building everything in sketchup again. I hope it will be bigger and better and at least ten times more intense than candy 2. But we all have to wait and see 😉
                              Andrija Posarić
                              Silver, I am really amazed with your work. The final product looks fantastic, and I like the atmosphere in the scene.I see that you utilized a lot of rubies:-) I haven't heard for half of them but, I see they are very useful.
                              Keep up the inspiring work, I haven't seen work of such quality for a long time here.
                              Cheers,
                              Andrija
                              Cheers, Andrija
                              • GaieusG
                                I doubt he will 😉
                                • W
                                  wheay
                                  very nice work! and tutorials.. thanks for sharing it to all. keep it up. 😍
                                  "i try to learn everyday"
                                  http://designerslandmark.blogspot.com/
                                    silver_shadow
                                    Hi Coen
                                    hee hee i think we all just have to wait and see whats its gonna be. sorry guys
                                    The thing about last time, it will definately not be my last model, its just doing these candy models is actually a real hard process, saving each day as a seperate file as you progress and try to document youre every move, where the normal way is just, build the model, and post it. But again, ive learned this is ACTUALLY the proper way to demonstrate youre model, so yea, i would not say it will be part of candy, but probably more similar stuff.
                                    • romboutR
                                      rombout
                                      @jim said:
                                      @solo said:
                                      I cannot seem to locate it but I once remember talk about a 'Greeble' script, my thinking was that this too could be a solution.
                                      However Silver you certainly used SP in a very creative way.
                                      It's not well documemented, but protrude can offset, protrude, and taper faces. Leave the second column blank unless you want a random number btween the range.
                                      [attachment=1:1pvfn6zh]<!-- ia1 -->protrude.jpg<!-- ia1 -->[/attachment:1pvfn6zh]
                                      This model was produced using these inputs:
                                      [attachment=0:1pvfn6zh]<!-- ia0 -->Clipboard01.jpg<!-- ia0 -->[/attachment:1pvfn6zh]
                                      hi jim, im workin on a mac and it seems it doesnt work for me... any help possible???
                                        Jim
                                        No word yet.
                                        I hope to be able to get back to working on Protrude before the end of March.
                                        • E
                                          EDMON242004
                                          hello silvsershadow, since i saw ur work done in sketchup i cant believe those can really be done using su, now i will be using it for all my projs, hope to see more of your tutorials, specially w/ window glass effects, thanks
                                          • P
                                            prismcnd
                                            OMG!!! I'm in sheer shock and amazement,absolutely breathtaking. DO NOT STOP! You are an inspiration to all
                                            “Whatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
                                            • 6 / 7
