    Silvershadow's eye candy 1: The river runs thru it
    125 Posts 62 Posters 74.6k Views 62 Watching
      sigue2000
      It's...I'm....Geeeeeeeeeeeeeezus. 😲
      I bow to thee.
      What?
      • dazzaD Offline
        dazza
        @silver_shadow said:
        hee hee yea its a real rare thing. This side of the word everyone thinks skp can only do blocks and is not a gr8 program to use for nicely rendered models.. i dont think so...
        πŸ’š
        I'm totally with you on that one.
        Work that guys like you, Solo etc... put out here is too good not to be taken notice of within the so called "big boys club" of arch viz software users and developers!
        Go Sketchup
        All people have the right to stupidity but some abuse the privilege.
          silver_shadow
          the sky i chose i wanted to show a specific part of the landscape and was not doing it 100% to my satisfaction to use as an hdri, so i photoshopped that in..
          • ely862meE Offline
            ely862me
            ok thx for answering!
            Elisei
            Elisei (sketchupper)
            Come and See EliseiDesign
            • soloS Offline
              http://img297.imageshack.us/img297/811/sgururu7.gif
              SU Guru smilley made just for you!
                csome
                IN SILVER SHADOW WE TRUST
                Man asome! i from ever was the guy who said "with sketchup you can do everything!... but no one believes me.
                NOW WE ALLL HAVE THAT PROOF.
                Congrats for your results on this works.
                I wanted to ask something.. the other day i was tryng to make "EVA" from the movie "Wall - e" but i dont have any plug int installed yet, and i tried to make it with The Sandbox tool, but i get no goods results.
                Its better to use the plug in "Subdivide And Smooth" from Smurstand?... In that case, i will buy it hehe...
                Cya and congrats for your efforts!
                Regards from argentina!
                http://csome.wordpress.com/
                  johnsenior1973
                  I don't think you need to buy subdivide and smooth for that. I think you should be able to model Eva using the follow me tool. This tutorial is to create a sphere, but if you just draw an Eva-like shape instead of using a circle you should be fine:
                  http://www.youtube.com/watch?v=iDbQhQjeP9g
                    seabass84
                    Error 404 (Not Found)!!1
                    (sketchup.google.com)
                      csome
                      Thank both! Eva was just an example i could say a egg but is ok thank for the model!
                      I am going to try that, i was using the sandbox tool.
                      Tomorrow i will post my results thanks!
                      Cya
                        johnsenior1973
                        csome - You might want to look at this for reference material when modeling your Eva:
                        http://forums.cgsociety.org/showthread.php?f=132&t=655501
                          csome
                          Nice! thanks man...
                          I am working on it, i could get the shape, now i am trying to get the real form of "Eva", but i could make the egg style form with follow me tool.
                          I made the contorn in CorelDraw, adn then exportit, and presto, i had the shape.
                          Nice tip.... lets see if i can reduce the number of faces to get a more smooth form.
                          Cya !
                            csome
                            Well guys here is part of my result using any plugins.
                            I have some questions.
                            Why my surfaces go so shaped? or sloped .... how can i make that the curve of her body and head go more "natural shaped".
                            And how can i make the black part of his eyes? i try to make some kind of "deformed sphere" but i didnt figure it out. 😞.
                            I need some kind of plugin to model this? or i am using the tools in the bad way?
                            Thanks in advice!
                            Sorry for my bad english!
                            Cya!
                              csome
                              http://img71.imageshack.us/img71/4568/evaxw6.th.jpg
                              • plot-parisP Offline
                                plot-paris
                                to get a smoother shape, you have to increase the number of segments for the arcs, defining the outline, as well as the circle you used for the follow me process (you did use follow me, right?)
                                if you select the circle, or the arc tool you can see a number in the VCB at the bottom right of your screen. for a circle the default is 24 edges, for an arc its 12.
                                simply type in a new number of segments, before drawing the arc/circle.
                                when you drew the shapes you can even select these shapes (one by one) and change the number of segments in the entity info window lateron (this only works, if it still is a flat shape. it doesn't work with extruded shapes anymore)
                                for the eyes... I think the best way is to draw them onto the body of your model, so that you can apply a different texture to them.
                                if you don't want to use any plugins (like the marvellous OnSurfaceTools) I would suggest, model a vertical shape of the eye, extrude it right into the head of eva. then you group this extruded eye-shape. now you select the the part of eva, where the face is, right-click and choose "intersect with model", which cuts the outline of the eye-shape into eva's face.
                                now you can mirror the eye-shape (by scaling it horizontally to -1) and repeat the process for the other eye.
                                if you don't want to see the edges around the eyes, you can select them and (right-click) "hide" them, after you coloured the faces.
                                  csome
                                  Hi thanks for your advices plot!
                                  I will try to changue the segments of the line, and extrude later, and see the better results:D
                                  And i will try to get that "Onsurfacetool" because i was trying to do thw way you tellme for the eyes, but i cant make it...
                                  Thanks again for your patience and efforts to explainme.
                                  I will post my results later, one i get a good model i will render it:D
                                  Cya
                                  • N Offline
                                    notareal
                                    Thanks for the post. It was really inspiring!
                                      silver_shadow
                                      THANX GUYS FOR ALL THE COMMENTS ECT πŸ’š
                                        silver_shadow
                                        updated the list in the start, have put a render in the list, for those who havent seen the render, or dont want to go that far down paging thru the pages to find the render.
                                          Click Draw
                                          Hey Silver....your extremely talented. Do you use SU in your daily work?
                                          Jeff
                                          Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                            silver_shadow
                                            hi there, thanx for the comment, i only use sketchup. My profession is to build models for an architectural firm all day πŸ˜„ quite nice
                                            been using sketchup for 3 years. My primary render engine i use is mainly Vray for sketchup, been using that for a year an a half
                                            • 5 / 7
