How to create an hour glass shape.
Hello all,
I am relatively new to the program and am trying to create a stool. I would like the stool to be similar to an hour glass (fatter at the top and bottom, skinnier in the center). I don't really know where to start. I've tried creating a circle and using the follow me tool over an arc, with little success. Thank you for your time. -
Sub-divide and smooth and FFD will be a great solution.
Solo,
Thank you for trying to help, but I have to be honest. I have no idea what you just said. -
Solo,
Ok I get it now. Thank you very much. -
If you don't have SubSmoove--follow me is great too. Draw the profile you want and FollowMe around the circle.
This took about 5 mins. Good Luck.
Thank you all. the stool turned out quite nice, but i had one more question. If i was trying to create the Kartell Gem Stool, is there a knurl tool or something to that effect that would triangulate the surface to have the realistic qualities of the stool. Thanks again I appreciate you taking the time to help.
Is this what you are trying to model?
yes that is the one. not necessarily my style but you do what you have to right?
Dear Chango70,
No, that is not my model. It is an image I got of the web. I posted it so others could see what was required. It looks tricky to model.
Regards,
Bob -
@watkins said:
Dear Chango70,
Regards,
BobOops sorry I thought it was a render you did. You just can't tell these days. Apologies.
How true!
Here is the final product. Thank you all for the help. It turned out pretty good.
