    Invert Selection - No Shortcut Key
    12 Posts 5 Posters 2.9k Views 5 Watching
      Or to put it the other way round...
      Select something, so that the right-click context-menu item would be available.
      Open Preferences
      Shortcut section
      Filter for 'invert'
      Set short-cut key
      Close Preferences
      You should now have a key set as required...
      • free agentF Offline
        free agent
        why doesnt this work for projections?
        • CadFatherC Offline
          CadFather
          thanks thanks thanks - this is what's happening though:
          suppose i have a cube and a sphere and they are not selected, when i click on the invert selection icon the cube and the sphere get both selected (works like select all), when i click again the they deselect (works like select none).
          now suppose the cube is selected, when i click on the icon the sphere gets selected (invert selection), click again and the cube gets selected (invert selection)
          when the same command is given a shortcut key: if no selection, then pressing the key has no effect - but it works from the icon.
          how/can i fix it?
          yes why not for projections? if you download the individual scripts from Didier's - you can then assign a key.
            Matt666
            Did you write a script ? Can we see it ? Or else we can write smt for you ? πŸ˜‰
            Frenglish at its best !
            My scripts
              CadFather
              Hi Matt, first i can barely deal with menus and that working through the night πŸ˜›
              thing is the script is already there but it has this strange behaviour which differs when run from icon and when run from shortcut key.. if you can sort something out.. from past experience, would i say no to monsieur Rubyn? πŸ˜„
                Matt666
                πŸ˜„
                Can you show the script and the icon code please? We can do smt into the icon code.
                For example, to look for a selevtion before starting the script...
                My scripts
                  CadFather
                  thanks Matt - this is the menu code:
                  cmd03 = UI;;Command.new("Inverts Selection") {InvertSelection_.toggle} #if InvertSelection_.validate
                  cmd03.small_icon = "CD_ICONS/SELECT/invertselection_16.png"
                  cmd03.large_icon = "CD_ICONS/SELECT/invertselection_24.png"
                  cmd03.tooltip = "Inverts Selection"
                  cmd03.status_bar_text = "Inverts Selection"
                  cmd03.menu_text = "Inverts Selection"
                  gp_cd_zelect_tb.add_item(cmd03)
                  this is TIG's code to which the menu refers
                  # Copyright 2005-8, TIG
                  # Permission to use, copy, modify, and distribute this software for
                  # any purpose and without fee is hereby granted, provided that the above
                  # copyright notice appear in all copies.
                  # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                  # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                  # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                  # Name ;          invertselection.rb
                  # Date ;          v1.0 8/7/5
                  #				  v1.1 10/2/8 Edges of selected faces are respected.
                  # This script will invert the current selection from the context menu.
                  # It will respect the nesting level if you are editing a group / component.
                  require 'sketchup.rb'
                  class InvertSelection_
                   def InvertSelection_;;validate ###
                    model=Sketchup.active_model
                    ss=model.selection
                    return nil if (ss.empty?)
                    return true
                   def InvertSelection_;;toggle
                    ss=model.selection
                    ### add hidden smoothed edges to faces in selections ###
                    edges=[]
                    ss.each{|e|fedges=[]
                      fedges=e.edges if e.typename=="Face"
                  	fedges.each{|ee|edges.push(ee)} if not fedges.empty?
                    edges.each{|e|ss.add(e)} if not edges.empty?
                    ### Find everything in the current edit level.
                    model.active_entities.each {|e|ss.toggle(e)}###Flip selection
                  end # Class
                    Matt666
                    That's strange!
                    It works fine here!
                    Here is the code I've used, with an icon...
                    Try this and tell me if it's ok for you...
                    In case you have a pb in your code...
                    invertselection.zip
                    My scripts
                      CadFather
                      nope, doesn't work - but that means the conflict comes from other scripts present in cd_zelect.rb
                      will give it a look by elimination - Thanks Matt! πŸ‘
                        CadFather
                        solved - i needed to add a plugin menu item - with icon and context menu only i get that registering bug.
                        Thanks for all the help though! πŸ‘
