    Invert Selection - No Shortcut Key
    12 Posts 5 Posters 2.9k Views 5 Watching
      todd burch
      If his script is a right-click context menu option, and if its validation routine requires something to be selected before that option to invert will show up in the context selection menu, then you will have to select something in order to see his script show up in the shortcut key setting dialog.
      Say that fast 3 times.
        Or to put it the other way round...
        Select something, so that the right-click context-menu item would be available.
        Open Preferences
        Shortcut section
        Filter for 'invert'
        Set short-cut key
        Close Preferences
        You should now have a key set as required...
        • free agentF Offline
          free agent
          why doesnt this work for projections?
          • CadFatherC Offline
            CadFather
            thanks thanks thanks - this is what's happening though:
            suppose i have a cube and a sphere and they are not selected, when i click on the invert selection icon the cube and the sphere get both selected (works like select all), when i click again the they deselect (works like select none).
            now suppose the cube is selected, when i click on the icon the sphere gets selected (invert selection), click again and the cube gets selected (invert selection)
            when the same command is given a shortcut key: if no selection, then pressing the key has no effect - but it works from the icon.
            how/can i fix it?
            yes why not for projections? if you download the individual scripts from Didier's - you can then assign a key.
              Matt666
              Did you write a script ? Can we see it ? Or else we can write smt for you ? πŸ˜‰
              Frenglish at its best !
              My scripts
                CadFather
                Hi Matt, first i can barely deal with menus and that working through the night πŸ˜›
                thing is the script is already there but it has this strange behaviour which differs when run from icon and when run from shortcut key.. if you can sort something out.. from past experience, would i say no to monsieur Rubyn? πŸ˜„
                  Matt666
                  πŸ˜„
                  Can you show the script and the icon code please? We can do smt into the icon code.
                  For example, to look for a selevtion before starting the script...
                  My scripts
                    CadFather
                    thanks Matt - this is the menu code:
                    cmd03 = UI;;Command.new("Inverts Selection") {InvertSelection_.toggle} #if InvertSelection_.validate
                    cmd03.small_icon = "CD_ICONS/SELECT/invertselection_16.png"
                    cmd03.large_icon = "CD_ICONS/SELECT/invertselection_24.png"
                    cmd03.tooltip = "Inverts Selection"
                    cmd03.status_bar_text = "Inverts Selection"
                    cmd03.menu_text = "Inverts Selection"
                    gp_cd_zelect_tb.add_item(cmd03)
                    this is TIG's code to which the menu refers
                    # Copyright 2005-8, TIG
                    # Permission to use, copy, modify, and distribute this software for
                    # any purpose and without fee is hereby granted, provided that the above
                    # copyright notice appear in all copies.
                    # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                    # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                    # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                    # Name ;          invertselection.rb
                    # Date ;          v1.0 8/7/5
                    #				  v1.1 10/2/8 Edges of selected faces are respected.
                    # This script will invert the current selection from the context menu.
                    # It will respect the nesting level if you are editing a group / component.
                    require 'sketchup.rb'
                    class InvertSelection_
                     def InvertSelection_;;validate ###
                      model=Sketchup.active_model
                      ss=model.selection
                      return nil if (ss.empty?)
                      return true
                     def InvertSelection_;;toggle
                      ss=model.selection
                      ### add hidden smoothed edges to faces in selections ###
                      edges=[]
                      ss.each{|e|fedges=[]
                        fedges=e.edges if e.typename=="Face"
                    	fedges.each{|ee|edges.push(ee)} if not fedges.empty?
                      edges.each{|e|ss.add(e)} if not edges.empty?
                      ### Find everything in the current edit level.
                      model.active_entities.each {|e|ss.toggle(e)}###Flip selection
                    end # Class
                      Matt666
                      That's strange!
                      It works fine here!
                      Here is the code I've used, with an icon...
                      Try this and tell me if it's ok for you...
                      In case you have a pb in your code...
                      invertselection.zip
                      My scripts
                        CadFather
                        nope, doesn't work - but that means the conflict comes from other scripts present in cd_zelect.rb
                        will give it a look by elimination - Thanks Matt! πŸ‘
                          CadFather
                          solved - i needed to add a plugin menu item - with icon and context menu only i get that registering bug.
                          Thanks for all the help though! πŸ‘
