    [Plugin] Skin.rb
    237 Posts 66 Posters 205.7k Views 66 Watching
      stanmarsh
      @Edson
      do you have the latest skin22.rb? get it here if not.
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=6912
      • jujuJ
        juju
        I'm hoping I can get the problem I'm having sorted out. I've tried downloading and re-downloading the skin.rb with the icons but I just can't get it to show. I've made sure it's placed correctly, made sure it has been enabled, tried moving the icons from the skin folder to the main plugins folder (where the skin.rb resides) doesn't make a difference.
        Any ideas people?
        • V
          Voder Vocoder
          @voder vocoder said:
          I know Voder, but those Edges should be smoothed.
          I'm not sure I follow your point, Coen.
          Sorry for my late reply. I usually don't check my own posts I make in the forums. Bad habit I know. I'm usually caught up in other stuff happening in the backend.
          Anyway, I made a video explaining what I mean. Please have a look.
          I guess I did the same thing you did, Coen. That is, I failed to check back for a reply, and now months later, I find that you replied some time ago. Well no matter; we'll get to the bottom of this eventually, even if it takes years.
          I viewed your video. It still seems to me that the failure of the Soften dialog to smooth those particular edges is not a bug, for exactly the reason I stated previously, namely, they constitute the case of an edge that separates two faces that are coplanar within the one-decimal-place precision of the slider. That's what the "Soften Coplanar" checkbox is for.
          I just performed a small experiment. I created a wavy surface like the one you did and smoothed it using the Soften dialog, as you did. And as with your case, there were a few edges (which separated what appeared to be coplanar faces) that did not get smoothed. And when I checked the "Soften Coplanar" checkbox, they were smoothed. It seems to work fine to me; I don't know why you think it's buggy.
          Tell me this: if not for situations like this, then what is the "Soften Coplanar" checkbox for?
          ~Voder
          • V
            Voder Vocoder
            Ah.
            And what of my other earlier question? When you reported this as a bug during version 5 Beta testing, what was @Last's response? Did they acknowledge it as a bug?
            ~Voder
            • jujuJ
              juju
              Any ideas people?
              BUMP
              • V
                Voder Vocoder
                Any ideas people?
                It's pretty obvious, Juju, but you didn't mention that you checked the DB Tools toolbar. Did you?
                ~Voder
                • jujuJ
                  juju
                  Any ideas people?
                  It's there all right, but what are the icons (the image files contained in the "skin" folder within the plugins folder) for then?
                  • V
                    Voder Vocoder
                    Any ideas people?
                    Those images are the icons (command buttons) that appear on the DB Tools toolbar. There are four images in the skin sub-folder--a large and a small icon for each of the the two commands, Clean and Skin. The two that are used for the toolbar depends on whether you have "Use large tool buttons" checked under preferences. I suggest you put the image files back in the skin sub-folder so they will show up on the toolbar.
                    ~Voder
                      architectboy
                      Hello, friends, long time no see. Lament no longer over the fact that this script is not in development. I've recently gotten back to working on this script and have a new version for you all.
                      The loooong awaited upgrade
                      • V
                        Voder Vocoder
                        Darrel,
                        I'm delighted to see you back, and I'm excited that there's a new version. Would you mind explaining a bit about the new options?
                        Thanks for this.
                        ~Voder
                          remus
                          Oooh, what a nice surprise.
                          • ToboboT
                            Tobobo
                            Thanks Mate
                            Toby
                            Philippians 4:13
                            • W
                              watkins
                              Dear Darrel,
                              I note that the new script adds something extra. Do you have a User Guide document to explain how best to use this script?
                              Kind regards,
                              Bob
                                maxosmedia
                                SU crash!!! 😞 Without tears and comments
                                (SU 6.4.245, MacOS 10.4.11)
                                Previous versions Skin.rb work perfect
                                  architectboy
                                  Skin.rb was originally designed to only "skin", or connect, the sides, but it became evident that it sometimes should "prep", or prepare the sides for skinning by splitting the edges. I came up with two methods for skinning the sides and two methods for preparing the sides. I used to have a button for each method, but now I have one skin button and the settings dialog sets what methods skin.rb uses. I hope that you can figure it out. If someone can explain it better than me, please do.
                                  • V
                                    Voder Vocoder
                                    ...it became evident that it sometimes should "prep", or prepare the sides for skinning by splitting the edges.
                                    Darrel,
                                    It's not obvious to me what the benefit of prepping is. The granularity of the resulting shape is still determined by the original edges, is it not?
                                    Thanks,
                                    ~Voder
                                      architectboy
                                      Voder, prepping the edges creates the effect that the edges are connected, not just the vertices.Example1.jpgExample2.jpg
                                        these icons have disapeared?
                                        • ToboboT
                                          Tobobo
                                          Darrel,
                                          Thanks for the script but it crashed sketch up and i'm not sure what all the settings mean?
                                          Toby
                                          Philippians 4:13
                                          • GaieusG
                                            Cool Darrel, works just fine with my machine. Thanks for coming back. A lot of us were indeed quite curious where you could be. πŸ˜‰
                                            Nice options, too! πŸ‘
                                            • 11
                                            • 12
                                            • 6 / 12
