    Replace texture without remapping
    3 Posts 2 Posters 1.8k Views 2 Watching
      Some times after I've mapped a model I want to tweak the texture a little. Only thing is that when I reload the texture, texture with exact same size and proportion, the mapped textures are reset.
      I can understand that textures with different proportions could cause problems, but when I replace a texture with another one with exact same size or proportion I expect that the texture mapping is preserved.
        richcat
        Have you seen this thread http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=13403
        It might help - the entity info way seems to work
          Cheers for that possible workaround. I'll check it out.
          Though, I still wish for a better method in SU. The process really needs to be easier.
