    Animation Walkthru....What to use?
    19 Posts 11 Posters 3.4k Views 11 Watching
    • F Offline
      fossa
      We have a client possibly wanting to see a walkthough of a proposed church. We generally tell people that want these things that we don't do them or point them to someone who does, who then scares them with the price. This particular one would be simple enough I think we could do it in house. The client understands that ILM and Pixar are not going to be involved and isn't expecting as such.
      Whats the best way to achieve this in sketchup. I've looked at Fraps and some others. What are people using to get simple walkthroughs in Sketchup?
        remus
        If your just after a straightforward walk through, you can mark camera positions (and other things, like layer visibility, takes a bit of messing about though) using scenes.
        You can then export an animation straight from SU.
          dylan
          There is SU Animate.
          http://www.ohyeahcad.com/suanimate/index.php
          Not sure how good it is, but I guess it is another option.
          http://dmdarchitecture.co.uk/
            Creasia
            The built in animation output is fine. You can also use the ASGVIS vray plugin for the best quality animation available from SU. Look at getting Whaat's smooth animation ruby script from this forum.
            • honoluludesktopH Offline
              honoluludesktop
              Fossa,
              Many of my clients love the SU animation as they are often unable to pay for anything high end, but appreciate something extra. With interior animations, keep your shadows off, they will flash unless you can avoid the "intentional" SU bug:-) Search the forum for a partial solution if you want to use SU to animate interiors with shadows.
              • F Offline
                fossa
                Thanks everyone...
                Looks like I'll just set up scenes and have a go at it. I thought there might be a better way.
                  remus
                  Their are a few rubies available to ease the process (and make your animations a little more slick.) Pick and choose according to your needs: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_cam_page.htm
                    mateo soletic
                    Have a look at this also http://www.walkabout3d.com/
                    I here is a quick sequence I made walking through and recorded it with screen capture device.
                    HotelT.rar
                    [Concept Illustrations](http://concept-illustrations.com/)
                    • plot-parisP Offline
                      plot-paris
                      the best way to get nice results is to use flightpath2, I think. if you get TransitionTimeEditor as well, it is quite easy to get some nice animations. you can buy both scripts in a presentation bundle at smustard for 14$.
                      now you only have to get fredo6's bezier curve plugin to create the camera path. and if you wan't to have it really easy, get the free camera line plugin from smustard as well.
                      and thats the procedure (I have only tested the use of cameralines once. but the rest definitely works great):
                      • first you set up the scenes you want with SketchUp
                      • then you use the CameraLine script (under the camera menu). it will create a path of connecting lines between the camera positions. at each connecting point an additional line will point in the viewing direction of each camera.
                      • group the camera direction lines to prevent them from connecting to the camera path
                      • now draw a bezier curve (I recon you use the f- spline, I believe that will stick closest to the path), connecting all the camera points.
                        make sure to press Ctrl at the beginning of the drawing process to unlock the curve from its drawing plane
                        group it to seperate it from other geometry.
                      • now draw a second bezier curve that leads from camera aim to camera aim (the tip of the camera direction line), using exactly the same number of control points.
                        this is important for timing the camera orientation later on.
                      • with both the camera path and the path for the camera focus created, you can delete the lines from the CameraLines script.
                      • next refine the curves by moving vertex points. you can even add control vertexes by double clicking anywhere on the curve or delete them by double clicking them again. but make sure to add/delete exactly the same number of vertexes at the same point of the curve to the camera aim path as you did to the camera path. like that you can ensure, that the camera and the camera aim move at the same speed (because for each segment of the camera path, the aim moves one segment as well). you can ensure that you worked precisely by selecting one curve after the other and compare the number of segments via the Entiti Info window. both have to be the same.
                        it may be quite difficult to move the points correctly in 3D space. to make it simpler you can use the arrow keys to lock the movement to one of the axes. it is easier to change the position one direction at a time.
                      • now, at last, you can use the flypath cript. choose the first curve as the camera path and then the second curve as Target Path. the script now creates loads of scenes, one for each segment of the curve.
                      • in the animation settings of SketchUp set the delay to 0 and the transition time to a low number (depending of the amount of scenes created and the speed you want).
                      • flightpath2 will manipulate the scene transition times so that no matter how uneven the distribution of vertexes along the curve is, the animation will stick to one speed. if that is what you want, you are finished now.
                        however, I found it very useful to be able to control the transition time by influencing the number of vertexes at different places of the animation (by adding mor control points).
                        to achieve that you need to use the TransitionTimeEditor script to set all the scene transition times back to default. like that the animation will speed up when the number of segments of the curve decreases and slow down when there are more segments.
                      • if you want to redo the animation to refine things, delete all the scenes and go over the curves again. the animation curves will be saved on a hdden layer called flight path.
                      if you work with a big model you should stay at a certain distance of any geometry with your camera to avoid the clipping problem. and don't pass through a shadow or you will face the clipping bug.
                      if you export the animation as still images with a higher resolution and sample it down to the right size later.
                      to assemble the images to a video you can use programs like the free virtual dub. you can use a filter to sample down the image size to the desired resolution while creating the animation video.
                      I hope this was of helf for you. tell us if you find any new tips and tricks. I would love to see some results, if you are allowed to post them.
                      • tinanneT Offline
                        tinanne
                        Jakob, this is very interesting and I would really like to have a go at this process, but I'm having trouble understanding what your saying. Any chance you can post a quick SU model with your instructions?
                        Executive Director : American Society of Architectural Illustrators
                        AIP 30 Competition opens soon. ASAI.org
                        Architectural Rendering
                          plot-paris
                          I am afraid I have to do that tomorrow - for I am thoroughly pissed at the moment 👊
                          but I'll definitely try to set up a proper tutorial at some point.
                            Panga
                            For a better render of walkthrough animation, don't forget Kerkythea, it's free, really simple to set up a walkthrough from sketchup scenes. For me the best way to achieve a good animation.
                            (www.kerkythea.net)
                            Bye.
                              kwistenbiebel
                              Thanks for that very good explanation Jakob!
                              This is probably the best solution (Su-Animate works similar and can do object animation) we have for sketchup for now.
                              It's not much...but it is something.
                              But it still remains a real challenge to get decent output.
                              I am wondering if this process can't be simplified.....
                              I mean, would it be difficult for one of the ruby wizards to write a new plugin that works easier (or improve the existing ones)?
                              1. Setup your scenes.
                              2. Run animation script that will create an EDITABLE curve with control points (like Fredos bezier tools) automatically and with immediate effect on the animation.
                              3. Easy speed control (sliders ?)
                              That would be so much easier....
                                plot-paris
                                one could even think to combine this with some functionalities of the Film&Stage plugin. so that you have a physical representation of your key-cameras in the model. moving the camera-component actually alters the whole animation, right clicking the camera lets you 'look through it' and change it's position from a first person perspective.
                                ideally the scenes in-between wouldn't be shown at all (neither as scene tabs, nor in the scene manager). on the other hand, then export to render engines would probably not be possible.
                                but thats a great idea, kwistenbiebel. I even remember us having a longer thread about that somewhere...
                                  kwistenbiebel
                                  Hi Jakob,
                                  I am currently trying a smooth animation using cameralines.rb , F-spline bezier curve and SU-animate to make the camera path and camera target path into animation frames.
                                  I am experiencing trouble though to get the F-spline to have more than 400 segments, and I would actually need 1171 😄
                                  Any suggestions?
                                  By the way, this is my last attempt on trying to get a smooth animation using sketchup.
                                  Even with combining all these little rubies, it remains tedious.
                                  If I can't sort it out properly, I'll go Cinema4D for all that has to do with animation....
                                    caddict
                                    Have to agree with this, super easy and fine results
                                      plot-paris
                                      kwistenbiebel,
                                      I am afraid for an animation of that scale (1171 frames! man, thats going to take a while to render 😉 ) SketchUp is indeed not the right program at the moment. but perhaps at some time all our suggestions will find their way into one almighty ruby. and then it will be a piece of cake to set up some nice film scenes...
                                      perhaps we should file through the 'mighty animation' thread and this thread again, get all the good ideas into a list, prop it up a bit with images to show what we want - and then approach all the ruby-masters in the hope that they see the potential... 😕
                                        kwistenbiebel
                                        Yes, but I think it would need the involvement of one of the ruby masters.
                                        I tried hard to get something smooth... using the method we discussed (cameralines.rb / F-spline bezier camera and target paths/ SU-animate or Flightpath2 for creating the frames).
                                        It is a hassle and you can not animate the field of view or animate a changing sun position.
                                        So actually it is not a good solution.
                                        Nevertheless, this was the end result (as in Pibuz' thread):
                                        http://youtube.com/watch?v=vEZm-20dVKE&fmt=18
                                        I am still convinced that Sketchup needs a simple timeline solution with recordable keyframes.
                                          caddict
                                          And yet, it seems like a pretty fine result to me!
