@ Fredo (mainly)
how feasible is it to have a command that will take a polyline and smooth it out like a spline, bezier etc?
This command actually exists in the plugin bezierspline.rb, via the contextual menuwhen you select a curve.
If your curve is a BZ_Polyline generated by the BezierSpline plugin, then you'll have the possibility to convert directly to any Spline.
If you take a curve generated from native sketchup tools or other tools, and possibly grouped via Weld, then you need first to convert it to a BZ_Polyline, and then to a Spline. The reason is that you may want to edit some vertices (i.e. delete / move).
Hope this helps
PS: Thanks for the icons. Will integrate in a Refresh version that I will publish soon.
ah of course... Thanks Fredo, i even realise i had done it before..
fantastic! didn't know that. great!
