    IMAGE SIZE FOR GALLERY
    17 Posts 7 Posters 1.4k Views 7 Watching
      dolphus
      How do some guys get larger images into the gallery i annot get more than +- 800 MB is there a way of showing the same file BIGGER?
        remus
        You can upload it to an image hosting site (like photobucket) and then link it to here using the [img]URL%20here[/img] tag.
          dolphus
          Thank you remus I have registered at photobucket but could you please make it slightly clearer for a dummy how do i link with the gallery? many thanks so far...regards
          • plot-parisP Offline
            plot-paris
            I am using imageshack.us
            but I assume it works the same way. once you have uploaded an image you will get some links. either take one of those (the one without any brackets and stuff) or you right-click on the image, choose properties and then copy the image path.
            then, in a post press the "Img" button above the text window and paste your link between the brackets.
            try it here. thats the right place (and not like me, who tried it in a gallery thread) πŸ˜„
              remus
              Once youve uploaded a photo to photobucket you should get a little white box under the pic with some text in the form [img]a%20URL[/img]. If you copy and paste that in to a post here it will show up in your post.
              If you quote this post you'll be ale to have a look at what i mean. Check out the next line for an example.
              http://farm3.static.flickr.com/2150/2746713748_7837fc0470_o.png
              p.s. you beat e to it plot.
                dolphus
                [IMG]http://i458.ph
                I have tried hope to see result after submit ???? thanks so far guys
                  dolphus
                  Red face what did i do wrong?
                    dolphus
                    [img][IMG][http://i458.ph[/img]
                    Daylight 1
                      remus
                      it looks like youve only got the first part of the URL, it should be an entire web address (ending with .jpg) that you put between the tags.
                        dylan
                        Daylight 1
                        Dolf when posting an image you just need: [img]linkhere[/img]
                        I notice you have [img][IMG] and your link does not seem to be correct.
                        http://dmdarchitecture.co.uk/
                          remus
                          [img]http://farm3.static.flickr.com/2150/2746713748_7837fc0470_o.png[/img]
                          it should be in that format when you type it in to the reply box.
                            It's not more easy? πŸ’š
                            Copy the address' link on a new line
                            Select all the address
                            press the Button Img (above the text that you are typing)so no error possible πŸ˜’
                              dolphus
                              http://i458.photobucket.com/albums/qq304/dolphus_006/big1.jpg
                              Success at last thank you all regards Dolf
                              • H Offline
                                Hazza
                                To see if what you have in the reply box will show up as expected use the Preview.
                                If the photo shows then well done, now click the Submit, if not then you have fluffed something, try again.
                                See all of my SketchUp models here.
                                • EdsonE Offline
                                  Edson
                                  i also use photobucket. i tried to post 1024px wide pictures here but they get cropped on wide screens. so i always make 800px wide copies for the purose of posting here.
                                  one word of caution. be careful not to remove the picts posted here from where they are kept so that the links do not get broken.
                                  http://www.mahfuz.arq.br
                                    dolphus
                                    Thanks as you can see I found out the "hard way" unfortunately that's how I learn Cheers once again thank you all fr the help
                                    http://i458.photobucket.com/albums/qq304/dolphus_006/SU293.jpg
                                    Now i can do it
                                    • H Offline
                                      Hazza
                                      @dolphus said:
                                      Now i can do it
                                      I still get it wrong, if I am posting an image I ALWAYS use the preview.
