    Windowizer
    86 Posts 36 Posters 18.3k Views 36 Watching
      RickW
      @fletch said:
      Hi Rick, this looks great! congrats!
      Thanks! 😄
      @fletch said:
      can a value of "0" be specified for the frame and have it therefore only build divider mullions/muntins? this way we would be able to use it to subdivide panels in a previously built curtainwall system?
      Yes 😉
      @fletch said:
      Will it have the option to be only one sided curtainwall? the additional polys will be very heavy in the scene if they are not needed. I would then have to keep the old windowizer as I prefer the lowest polys possible... for quicker SU response and quicker render times.
      Yes, there will be a "front-only" option.
      @fletch said:
      Is there a way to make the grouping a component instead? one that cuts the opening? Say I picked 3 identical faces, and told it to make the window, and it were to make it, make it a component, and place the component in all three places for me... that would be powerful. 😎
      I think I could modify it to make a component - I'd have to do some research on instance placement (haven't used it for a while, so it's a bit rusty). The more difficult part is verifying that the faces are the same size/shape.
      RickW
      www.smustard.com
      • erikBE
        erikB
        Hi Rick,
        Now here is a ruby I use so often !! Even with its current limitations !
        The update looks veryyy promising ! The answers you gave to Fletch are also just the things I need. Sometimes low poly, sometimes high. I usually make a group of the face prior to the windowizer command makes it more easy to change.
        Anyway looking forward to the update of your script.
        greetings,
        erikB
        • B
          bellwells
          For me, this script is essential. I use this thing more than any other script out there, by FAR. I'd be lost without it. In order: water, food, shelter, windowizer.
          Ron
            RickW
            Thanks for the comments and encouragement. I've got some other eyes looking over the current iteration. After that, a couple of UI tweaks, and it should be ready.
            RickW
            www.smustard.com
            • FletchF
              Fletch
              really looking forward to this one...
              Fletch
              • jujuJ
                juju
                +1!
                • boofredlayB
                  boofredlay
                    dylan
                    http://dmdarchitecture.co.uk/
                    • rodrigonotorR
                      rodrigonotor
                      • Sketchando.net • www.arqcad.net •
                      • ToboboT
                        Tobobo
                        (I can see this getting out of hand) 😉
                        Toby
                        Philippians 4:13
                        • F
                          fakircho
                          • erikBE
                            erikB
                            infinity -1
                            greeting, erikB
                            • C
                              chango70
                              I noticed that you have Catalan and no Spanish? How come?
                                RickW
                                Sorry, I forgot to say I already have volunteers for French, German, and Spanish, so I didn't include those on the list. 😄
                                RickW
                                www.smustard.com
                                • C
                                  chango70
                                  LOL for a second I though you where supporting some kind of separatist movement. 😳
                                  • EdsonE
                                    Edson
                                    rick,
                                    i can do the portuguese translation. count on me.
                                    http://www.mahfuz.arq.br
                                      spirp
                                      I'll gladly contribute a Swedish translation!
                                      Great plugin!
                                      • AnssiA
                                        Anssi
                                        I might manage the Finnish...
                                        Anssi
                                          There is no French inside the liste? 😮
                                          Cela semble curieux! 😆
                                          • CadFatherC
                                            CadFather
                                            ..i can help with italian (or sicilian)
                                            • 2 / 5
