    Windowizer
    86 Posts 36 Posters 12.9k Views 36 Watching
      RickW
      I'll throw some items out there for a consensus "vote":
      1a. [EDITED] V4 will cut an opening in a "wall", and a "wall" is determined by the maximum distance between two faces. I can hard-code a reasonable distance value (currently 16"/~40cm maximum), or I can make it user-defined.
      1b. If user-defined, do you want to see it in the main dialog every time you use Windowizer, or would you prefer it to be located in a separate configuration dialog?
      1. V4 groups the resulting window assembly. I can add an option to group or not group this, if desired (the group would be exploded if non-grouping was selected).
      2. When multiple faces are selected for a Windowizer operation, should "undo" work on just the last window assembly created, or on all of them? For clarification: currently in v4, 10 faces selected to be Windowized would result in 10 separate actions, thus 10 separate "undo" actions. This could be an option as well, subjecting it to question 1b. (main dialog or separate configuration dialog?)
      EDIT: If you answer using this survey form, I can better track the responses.
      RickW
      www.smustard.com
        RickW
        Okay, based on responses so far, I've made some determinations:
        1. This will be user-configurable in a separate dialog, as I expect it won't change very often - if you never have a wall thicker than 16"/40cm, it will never change! 😄
        2. I will add the grouping option to the main dialog
        3. "Undo" will undo all windows created in that instance.
        Thanks for the input,
        RickW
        www.smustard.com
        • FletchF Offline
          Fletch
          Hi Rick, this looks great! congrats!
          can a value of "0" be specified for the frame and have it therefore only build divider mullions/muntins? this way we would be able to use it to subdivide panels in a previously built curtainwall system?
          Will it have the option to be only one sided curtainwall? the additional polys will be very heavy in the scene if they are not needed. I would then have to keep the old windowizer as I prefer the lowest polys possible... for quicker SU response and quicker render times.
          Is there a way to make the grouping a component instead? one that cuts the opening? Say I picked 3 identical faces, and told it to make the window, and it were to make it, make it a component, and place the component in all three places for me... that would be powerful. 😎
          Fletch
            RickW
            Thanks! 😄
            Yes 😉
            Yes, there will be a "front-only" option.
            I think I could modify it to make a component - I'd have to do some research on instance placement (haven't used it for a while, so it's a bit rusty). The more difficult part is verifying that the faces are the same size/shape.
            RickW
            www.smustard.com
            • erikBE Offline
              erikB
              Hi Rick,
              Now here is a ruby I use so often !! Even with its current limitations !
              The update looks veryyy promising ! The answers you gave to Fletch are also just the things I need. Sometimes low poly, sometimes high. I usually make a group of the face prior to the windowizer command makes it more easy to change.
              Anyway looking forward to the update of your script.
              greetings,
              erikB
                bellwells
                For me, this script is essential. I use this thing more than any other script out there, by FAR. I'd be lost without it. In order: water, food, shelter, windowizer.
                Ron
                  RickW
                  Thanks for the comments and encouragement. I've got some other eyes looking over the current iteration. After that, a couple of UI tweaks, and it should be ready.
                  RickW
                  www.smustard.com
                  • FletchF Offline
                    Fletch
                    really looking forward to this one...
                    Fletch
                    • jujuJ Offline
                      juju
                      +1!
                      • boofredlayB Offline
                        boofredlay
                          dylan
                          http://dmdarchitecture.co.uk/
                          • rodrigonotorR Offline
                            rodrigonotor
                            • Sketchando.net • www.arqcad.net •
                            • ToboboT Offline
                              Tobobo
                              (I can see this getting out of hand) 😉
                              Toby
                              Philippians 4:13
                              • F Offline
                                fakircho
                                • erikBE Offline
                                  erikB
                                  infinity -1
                                  greeting, erikB
                                    chango70
                                    I noticed that you have Catalan and no Spanish? How come?
                                      RickW
                                      Sorry, I forgot to say I already have volunteers for French, German, and Spanish, so I didn't include those on the list. 😄
                                      RickW
                                      www.smustard.com
                                        chango70
                                        LOL for a second I though you where supporting some kind of separatist movement. 😳
                                        • EdsonE Offline
                                          Edson
                                          rick,
                                          i can do the portuguese translation. count on me.
                                          http://www.mahfuz.arq.br
                                            spirp
                                            I'll gladly contribute a Swedish translation!
                                            Great plugin!
                                            • 2 / 5
