    [Plugin] Window Tools: Revised, 4 tools, incl. icons.
    26 Posts 15 Posters 36.6k Views 15 Watching
      rv1974
      @tomot said:
      @rv1974 said:
      Hi Tomot!
      Can you switch to "cut window" gluing components not groups as the result?
      There's Didier Bur's ruby to cut thick wall. Even more you could
      unite 2 scripts.
      I'm sorry I don't understand your comments.
      and can you be more specific: what are the exact names
      of the scripts you are taking about?
      Hi!
      Your tools produce groups not components. Correct?
      Components instead of groups are better idea IMHO.
      Components with "cut opening" and "glue to any plane" (to cut a single plane-wall) would be the best. (See components-architecture-
      windows for instance).
        tomot
        You have 5 choices available to you:
        use existing components,
        make your own components,
        use Windowizer,
        use Window Tools,
        design your own Ruby.
        In addition once you have made a window with Window Tools, you simply select all the groups right click and make your own component. You can quickly make any number of different windows, and save each as a component.
        But, if you prefer to use only a "single wall plane" then simply use Windowizer.
        The reason why I made Window Tools is explained here.
        301 Moved Permanently
        (www.sketchucation.com)
        I have been in Residential design and construction for 39 years, during that time, I have never considered designing a 3d envelope using single planes for my Clients.
        [my plugins](http://thingsvirtual.blogspot.ca/)
        tomot
          cyan.archnet
          Hats off to you for this plugin!, thanks!!
            agrazdi
            Are you planning to extend it to draw doors ?
            agrazdi
              tomot
              agrazdi
              Yes, I'm working on this project, however I'm still unclear
              as to how many types of doors, should be included.
              probably: single, double, and sliding.
              at present I have only single door with right and left hand option.
              tomot
              • honoluludesktopH Offline
                honoluludesktop
                How about adding a pair of bifolds.
                • H Offline
                  herodes
                  I am pretty sure you have visited this,... but just in case http://en.wikipedia.org/wiki/Door
                  %(#BFBFBF)[http://arhitektonas.blogspot.com
                  I know me,... I am that guy...
                    pommes
                    hi,is your plugin ok for mac users too?Thanks.
                      tomot
                      I have no idea about that, perhaps someone that uses SU on the MAc will let us know.
                      tomot
                      • EdsonE Offline
                        Edson
                        I am not sure what is happening to me has to do with the fact that I am a mac user but none of your tools offer parameters for creating frames. to be sure, mullions will always be contained within a frame, right?
                        http://www.mahfuz.arq.br
                          Truongtom
                          Thank you very much
                          • TandemT Offline
                            Tandem
                            Thank you very much for a great plugin.
                            • 2 / 2
