    Hiding Profile lines/ Edges
    17 Posts 8 Posters 2.3k Views 8 Watching
      remus
      Your right, it will only work for images.
      I dont think it's possible to do within SU, unless of course someone has come up wit a tidy little workaround im not aware of.
        Hi Susketchr,
        Unfortunately Remus is right (I mean not the fact that he is right is unfortunate or what...)
        Anyway, you cannot turn profile lines off on only some parts of model.
        Lyers on't do any good either because you cannot asign different styles to different layer (only to scenes but this is not the case here).
        I'd still uggest to turn proiles off -they are ugl anywy (and you shouldn't "lose edges" when they are turne off).
        • Jean LemireJ Offline
          Jean Lemire
          Hi Susketchr, hi folks.
          You may try hiding profiles and keeping edges visible.
          To hide all edges in the plume, try :
          1 - Go to Wireframe Mode.
          2 - Select all edges.
          3 - Hide them.
          4 - Go back to previous Mode (Shaded or Shaded with textures).
          Just ideas.
          • ToboboT Offline
            Tobobo
            You could reduce the size of the profile edges. But it works for the whole model tho
            Toby
            Philippians 4:13
              susketcher
              Guys,
              I think i will turn off the profile lines and make the other objects' textures more darker to make them more visible. This forum is great, i am pleasantly surprised with the number of replies in such a short time. Appreciate all this help guys and keep up the good work. πŸ˜„
                mirjman
                can you post the model of your jet plume? I can't recreate your problem with a simple cylinder... see attached (I have a cube with profiles and a cylinder without)
                  susketcher
                  Mirjman,
                  Here is the sketchup model file with plume and the rest.
                  JetPlume.skp
                  • utilerU Offline
                    utiler
                    or you could create your own style using Style Builder. This way you can play with the Dropout length and Fade Factor and see what comes of it.....
                    just more ideas...
                    Just Curious...
                    • V Offline
                      Voder Vocoder
                      @susketcher said:
                      Mirjman,
                      susketcher,
                      The profile lines on the flame are numerous, but not infinite in number. If you're somewhat patient, you can keep rotating the thing and hiding them until you've hidden them all. Using wireframe to see them, Ctrl-A to select them, and a hotkey to hide them, it isn't really all that time consuming and tedious, say, compared to knitting a sweater.
                      In fact, here, I've done it for you. Just be mighty sure you don't get inside that component and hit Unhide All, or you can do the redo yourself.
                      ~Voder
                      The flames component
                        susketcher
                        You guys are awesome. πŸ‘
                        Voder Vocoder,
                        I had given up on that approach under the impression i am dealing with thousands of line if not infinite. Thank you so very much. πŸ˜„
                        • V Offline
                          Voder Vocoder
                          Not really. I'd say there's one for each facet of the cylinder seen edge-on and one for each side of the sawtooth pattern you cut out. Hardly infinite, or even thousands. More like a few dozen or less I'd say.
                          ~Voder
                            mirjman
                            here's how I did it (fastest method):
                            1. triple click on the jet plume, this selects all
                            2. hold shift and click on the SURFACE of the plume, this deselects the fire surface but has all the edges selected
                            3. right click on an edge in the selection and say "hide"
                            i think this worked because you must have started with a cylinder at some point, similar to my previous post here
