    Are you ready for SketchUp 7 news?
    310 Posts 83 Posters 58.1k Views 83 Watching
    • DanielD Offline
      Daniel
      You can import SU directly into VUE Infinite, but I've found translating it to an obj file first much better. Hopefully VUE 7 will improve on this.
      My avatar is an anachronism.
        Jackson
        LOL, I had to open Vue 6i just to check you were right! Damn I missed that before jumping ship for Vray- I guess I wasn't looking for it so I didn't notice it. Shame you still have to go via the obj route, and more so that they haven't yet produced a plugin UI for SU, but then Vue's UI is fairly complex (albeit fairly logical by render prog standards) so maybe it wouldn't lend itself to SU integration.
        Jackson
          Bruell
          @jackson said:
          It's shameful that E-on haven't produced an SU plugin for Vue.
          You're damn right about the import and the OBJ file I do it trough the obj BUT I would wish that the objects were better organized it dissolves components....It should turn the components to groups at least!
          • soloS Offline
            I use Vue a lot and use .skp -->.3ds using Deep Exploration and it works great for me so far.
              remus
              Solo, does that preserve the textures on the SU model?
              Im looking at giving vue a go (nothing to do with the fact that theyve got a free PLE version, i swear.)
              • Alan FraserA Offline
                Alan Fraser
                I haven't used Vue for a while, but my experience of it was that it did mess up the textures if you exported to 3ds with welded vertices. The trick was to export preserving the texture coordinated then weld the vertices in Vue. You just need to be a little careful of material grouping, then it's no real problem.
                Here's a thread on the old forum that explains the procedure. This was prior to V6 and does not contain textures, but it does explain about the Split function in Vue.
                http://betaforum.sketchup.com/showthread.php?t=54994&highlight=vue+alan+export
                3D Figures
                  remus
                  Cheers alan, im assuming thats the case if you use deep exploration to convert as well?
                  • soloS Offline
                    Remus, Yes it does maintain the texture coordinates.
                    tell you what, once you up and running with the PLE version and you have a model thats textured and want it used in Vue let me get it and convert it for you. However with a prog like Vue why in the world would you want to texture in SU in the first place? Just export your model using colors for textures and do the texturing in Vue, and if using a photo texture then map it in SU and you will notice it will be maintained in Vue and can even be replaced with a higher resolution one in vue.
                      remus
                      Cheers solo. Didnt realise vue did texture mapping, another thing i'll have to have a look at.
                        Bruell
                        where is this deep exploration? in SU? in the export? or in the Vue Import? I used OBJ because the 3ds resulted in missing geometry and twisted faces.
                          remus
                          Deep exploration is a rather pricey file conversion/management program. It does a very good job of converting files between lots of formats, often a lot better than the SU exporters can do.
                            john.warburton
                            One of the new features will be called Nibble, This feature will progressively Eat away at your model until eventually there is nothing left. The process can be controlled and the amount of nibble and the rate of nibble and when to stop the nibble are user controlled.
                            I also heard that they were thinking of features called "lick" and "suck" until the marketing people thought about the slogan ...
                            Life's a reach, and then you gybe.
                            • plot-parisP Offline
                              plot-paris
                                tomasz
                                I think new version will be much different. They could call it SuckIt Up 1.0... beta ??
                                Now taking seriously. I have an impression that Google is preparing something similar to the 'Chrome' but in 3D world. It takes so long because:
                                • they are(?) almost rewriting the whole thing
                                • Google SU Team members were excited at Base Camp - because they are working on an 'open source(?)' new approach to 3D modelling and because they are able involve their own talents and ideas
                                • they are(?) creating Linux version as well
                                I wish it was true πŸ˜„
                                Tomasz
                                • soloS Offline
                                  LOL, could be a great thread, I will start.
                                  SU7 is taking so long because:
                                  They are moving the Sketchup department from Boulder to Wassilla, Alaska to avoid the 'High poly army' from gathering if it does not have features they want ...who's gonna picket in Alaska in winter?
                                    SchreiberBike
                                    Out of sympathy with current users, they are doing all development work on a single core processor.
                                    They are using old Mac's with a one button mouse and they can't figure out how to orbit.
                                    They are spending all their time at Wassilla's new sports center because there's nothing good at the library.
                                      plot-paris
                                      O.k. here is the new thread
                                      SU7 is taking so long because...
                                      [Edit] damn, we are all bored to death and don't know anything to do with our spare time, don't we? πŸ˜’ []
                                      • PixeroP Offline
                                        Pixero
                                        I asked the almighty: http://www.titane.ca/igod/main.html πŸ˜‰
                                        Me:
                                        When is Sketchup7 coming?
                                        God:
                                        At the appropriate time, no sooner.
                                        Me:
                                        When will Sketchup7 be released?
                                        God:
                                        Maybe never.
                                          remus
                                          "repenting made easy."
                                          a good find jan πŸ‘
                                            remus
                                            "Me:
                                            have you ever used SU?
                                            God:
                                            I use it as often as possible."
                                            It seems the lord is a fan of our favourite modelling program.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 15 / 16
