    What's your beginners tip?
    305 Posts 169 Posters 453.9k Views 169 Watching
    • Alan FraserA
      Alan Fraser
      Watch the training videos on the Help menu...especially if you are coming to SU from another program, with a ton of preconceptions about how things should be done....more especially if you are new to 3D.
      3D Figures
        remus
        Start using groups early, makes stuff a lot easier.
        • ToboboT
          Tobobo
          and components
          My tip would be keep a tidy model. Keep up on your purging.
          Toby
          Philippians 4:13
          • GaieusG
            Display edges and profiles off...
            I'd only keep profiles turned off - edge are neded for modeling (to see where you are connecting vertices and such).
            Although never tried that way - maybe you can get used to it.
            The fastest way of modeling then would be with edges turne off in wireframe modeling 🤣
            • MALAISEM
              MALAISE
              Begin with elementary forms (box, cylinder )and play with all tool just in order to learn
              how they work.
              MALAISE 😄
              • E
                ehaflett
                Spend at least 10 minutes a day reading posts here. There's a LOT to be learned here and no shortage of inspiration!
                • soloS
                  Have fun with SU, play everyday, get into a workflow that you are comfortable with. Do not get too technical in the beginning as the details will come when the need arises.
                  As long as you are having fun you are learning, as soon as you get frustrated walk away and try again later.
                  • P
                    pmiller
                    On the contrary, I would strongly urge beginners to keep profiles on so they can properly tell when they have formed surfaces and avoid co-planar problems. Once they have got it, then they can keep them off.
                    • GaieusG
                      @pmiller said:
                      ...On the contrary, I would strongly urge beginners to keep profiles on so they can properly tell when they have formed surfaces and avoid co-planar problems. Once they have got it, then they can keep them off.
                      Yes, there is some truth in this - I also turn them on when finding out that some faces don't form properly so that I can easily see the offending edges. 👍
                        Ross Macintosh
                        Tip: Orbit, Pan & Zoom using the middle mouse button / scroll wheel.
                        middle mouse button to orbit
                        middle mouse button + shift to pan
                        and the scroll wheel to zoom
                        The tool buttons for orbiting, panning and zooming almost never need to be used.
                        • GaieusG
                          Yeah, deinitely. I even change the Orbit shortcut key (O) to Offset (while the original offset (F) is now Follow me. I think it is more logican and the orbit tool (a a button) is totally redundant.
                            Enable "Hidden geometry" can help for curved forms and explain why some surfaces can't be selected 😉
                            Works also fine with the Joint Push Pull (the plug to add first!
                            • EdsonE
                              Edson
                              the three pillars of modelling well (IMHO, of course):
                              1. work ALWAYS on layer 0;
                              2. GROUP whatever geometry you are creating (in case there should be more than one copy of it, make it a COMPONENT);
                              3. place it on another LAYER whose name makes sense (essential for controlling the model's visualization).
                              http://www.mahfuz.arq.br
                              • H
                                HFM
                                A big Amen to that, I always work this way 👍
                                My tip:
                                While selecting different kind of materials for your model to try out looks, don't forget to delete them afterward since SketchUp will remember every single material you've selected, clogging op your model's file size in the process.
                                • Jean LemireJ
                                  Jean Lemire
                                  Hi Folks.
                                  My first tip: READ THE HELP.
                                  Just ideas.
                                  • boofredlayB
                                    boofredlay
                                    But that is just one idea Jean 😄
                                    Use construction lines (with the tape measure tool) as much as is necessary.
                                    And I also agree with Alan, watch all the training videos... many times over.
                                    • AnssiA
                                      Anssi
                                      Don't curse the SU inferencing, learn its quirks so it start working for you. One of the keys is to use Shift (locking) creatively with the inferences.
                                      Anssi
                                      • H
                                        Hazza
                                        I never fought it, I just needed practice to get it to do what I wanted. I knew the Shift key locked tools like the protractor but didn't know it locked inferencing too, thanks.
                                        That's one of the things I didn't do, I was too keen to just jump right in, I downloaded all of the SU5 videos, watched one or 2 and got bored. I enjoyed the doing and learning by mistakes more than just sitting passively watching someone else do it.
                                        See all of my SketchUp models here.
                                        • Alan FraserA
                                          Alan Fraser
                                          No, no. You don't sit and watch...getting bored. You watch part way through, then say to yourself "Let's see if I understood that bit right." pause the video and try for yourself. Watch a bit more....pause it again....especially with the much longer V6 videos. Otherwise, by the time you reach the end, you've forgotten the stuff at the beginning.
                                          You know what they say about showing somebody something is better than telling them about it...but doing it for yourself is best of all.
                                          I'll bet a lot of people here learnt much of their expertise by reading questions from people that they didn't know the answer to right away. So they jumped right in...maybe refreshed their own memory by watching a video or reading the Help...and figured out the answer themselves.
                                          3D Figures
                                            Ross Macintosh
                                            Have Fun! Play!
                                            It is human nature to jump right in, be ambitious, and attempt a "real project" when you are just getting your feet wet. That's what most of us did and its great so long as you can avoid frustrating yourself. Frustrations can zap your spirit. SketchUp should be a joy - and it can be.
                                            Mix it up with some playing. Just fooling around and exploring tools and ideas is a fast-track to becoming more comfortable in SketchUp. It can be a remarkably intuitive program but you need to understand the flexibility it offers. You find that understanding through play and just trying different things.
                                            Regards, Ross
                                            • 15
                                            • 16
                                            • 1 / 16
