    Barcelona Pavilion (Animation Added)
    19 Posts 10 Posters 2.6k Views 10 Watching
    • K
      kevsterman
      I like this. I prefer the cropped image as I think the cigarette and the mug let it down slightly but its a really good render.
      Would you mind sharing your wood material?
      "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
      • EdsonE
        Edson
        here
        http://www.mahfuz.arq.br
        • K
          kevsterman
          I've already downloaded Majid's maquette materials but I don't have the particular wood material that you have used 😞
          Do you mind posting just that one in your model?
          • P
            princedragoncok
            Here ya go: http://www.cgtextures.com/texview.php?id=4715&PHPSESSID=ed155963660e9c84e42204b0199a8376
            What do you reckon would make the cigarette and mug better? I see there is slight discoloration at the bottom of the mug - dunno why that is though
            • P
              princedragoncok
              Update - Animation Added
              • brodieB
                brodie
                Really cool animation. I think it's a really great idea to render a model as a...gasp...model! Very fun and still gets the point across, especially works well for a cubic building like the Pavillion.
                Regarding the objects around the model, my only critique would be that they seem a bit random. Ideas running through my head would be to put the model on more of a polished desk in a nice office. Sort of as if it were an office piece for some CEO type. Or perhaps on a work table in a wood shop w/ a drill and nails around, maybe a table saw in the background. Or for those of us who built stuff like that in architecture studio, I'd like to see it on a drafting table w/ scattered debris, pencils, plans, rulers, and maybe a dude head down passed out on one end of the table w/ saliva dripping for the corner of his mouth onto a pile of old eraser shavings. I think many of us could relate to that scene! 😄
                -Brodie
                • soloS
                  Brilliant!
                  Great clarity, fantastic lighting, just overall sweet.
                  This is the future of rendering.
                  • P
                    princedragoncok
                    Thanks Brodie and Solo. Appreciate the advice too - especially the architecture studio scenario. With object animation I could even have a fly buzzing around and actual saliva dripping!
                    • K
                      kwistenbiebel
                      Nice job Prince.
                      The wood comes out nicely and indeed the light is fine.
                      I wonder: is this the same model you propose AdamB to try out using LightUp?
                      That would make a great comparison in terms of the speed/quality ratio.
                      Interesting!
                      • P
                        princedragoncok
                        @kwistenbiebel said:
                        Nice job Prince.
                        Interesting!
                        Thanks kwist, and yes this is the same model I propose Adam try out using LightUp. I know it will be fast, but i'm more interested in the quality LightUp will produce..
                        • T
                          tomislavm
                          It is something beautiful!
                          • AdamBA
                            AdamB
                            The discoloration is caused by 2 things.
                            1. The handle goes through the body of the cup and is causing some bad normals on the inner surface - you'll see SU shading anomolies. Just delete the part of the handle inside the cup body.
                            2. More importantly, the smoothing groups seem wrong. You want your surface normals on the outer side of the mug to be varying around the circumference of the mug but not vertically. This false color render of interpolated surface normal screenshot from LightUp shows the normals are being smooth around the bottom of the mug causing your odd shading. If the normals were 'right', the bottom of the mug would have a near constant normal facing down (as it does right in the center).
                            • P
                              princedragoncok
                              Hmm this is interesting, but somewhat out of my realm of understanding. I should also say that I got the cup from the warehouse, so what you're saying might make more sense if i was the creator. But I do understand that you want a horizontal band, rather than vertical band of colour around the cup. So how badly is the render effected in Lightup in the end? Vray has discoloured it slightly but it's not detrimental to the final rendering. Is this the case in LightUp? Can LightUp adapt to cope with such 'bad normals' rather than the user having to make sure every component is composed of good normals?
                                mirjman
                                prince-
                                great realistic feel to the atmosphere in that room! are you saying this is lightup?
                                • AdamBA
                                  AdamB
                                  Hey its all just ones and zeros. Be that in LightUp, vray or anything else, the same applies - ie the renderer is going to take the input you give it and do its lighting thing. If that input is bad, you'll get a bad result. "Garbage in, garbage out" is the old adage with computers.
                                  Over many years of writing software I've come to conclusion that rather than try and second guess the user - by for example, ignoring the normals that are given and recalculating new ones that the software thinks are 'better' - its better to simply reflect what you're given.
                                  So, I would Explode the mug, and use the Smooth normals tool to reset the crease angle (say, 30 degrees), then regroup it and you should be good to go.
                                  Adam
                                    juanjo06
                                    beautiful... how did you render the animation, better said, what is the other software u used to join the vray image rendered. i just know how to render the each frame but i don´t know how to make the video. 👊
                                      juanjo06
                                      beautiful... how did you render the animation, better said, what is the other software u used to join the vray image rendered. i just know how to render the each frame but i don´t know how to make the video 👊
                                      • P
                                        princedragoncok
                                        @mirjman said:
                                        prince-
                                        No this is v-ray for sketchup.
                                        Thanks, I used windows movie maker which comes with all vista machines
