I have a Scale Question
11 Posts 5 Posters 1.8k Views 5 Watching
    spence
    First, this is not a Sketchup scale question but I have to ask Sketchup people because they are the best and nicest.
    I have printed out a google earth image to the scale of 1:300 and for some crazy reason I drew a plan over that image at 1:500 scale. Now I need to find out what percentile I copy my 1:500 drawing to be at 1:300?
    Spence
      remus
      166%, although you might want to get someone else to check that.
        remus
        Daniel, i think you got the division the wrong way round. If its 1:500 the scale is to small, your going to make it smaller again by multiplying by 0.6
          Daniel
          Simply divide 300 by 500, for an enlargement factor of 0.6
          Remus, that would work if you wanted to enlarge 300 to 500 (500 divided by 300 = 1.6666e)
          My avatar is an anachronism.
            Alan Fraser
            That would be right. You can actually type the new scale 5/3...or maybe not. Stick with 1.66. I could have sworn I've scaled fractionally before today.
            3D Figures
              Daniel
              You might be correct, Remus. We (at our office) don't draw anything "to scale" and don't even understand how one would do that - everything we do is full size.
                Alan Fraser
                Actually, that scaling function is rather buggy. 1.66 is close but is not absolutely precise. It seems weird that you can enter fractional inches in the VCB, but when you try to scale a cube to 5/3 or 1 2/3 it jumps considerably smaller. SU seems to take any fractional value as a measurement...even if you think you are entering a ratio.
                3D Figures
                  spence
                  I tried setting the copier to 166% and that worked out right. I can now place a scale on it and it works.
                  I'm always confused by scale when drawing stuff by hand and then sizing it digitally. Although this was not being sized digitally it was being sized on a copy machine.
                  Thanks for the help
                  Spence
                  • W Offline
                    Wo3Dan
                    Spence,
                    Since this is not a Sketchup issue you need to scale up your drawing 1.66667:1 which means enlarge it.
                    Only then it will match the GE image that is 1:300 (Remus is right)
                    In SU you could either use the scale tool or the tape measure tool to correct things.
                    With the scale tool you can (at least I can) add decimal comma in a factor or add a unit.
                    The unit means: skip factor but aply measure, grip to grip. Tricky but it works to correct things.
                    Wo3Dan
                      spence
                      Thats good information Wo3Dan. Now how did you get the 1.66667 number?
                      Spence
                      • W Offline
                        Wo3Dan
                        Spence,
                        You are pulling my legg aren't you?
                        Anyway. Your input (in the copier) is 1:500. The output needs to be 1:300 which is a larger scale.
                        So you need ?:500 to equal 1:300. What more can I say? (500/300):500 = (1.66666667):500 = 1:300
                        b.t.w. don't underestimate the SU scale tool features whenever you encounter such a thing in SU.
                        success,
                        Wo3Dan
