    [Plugin] Lines to tubes
    131 Posts 61 Posters 296.7k Views 61 Watching
      I don't know what I can say more πŸ˜’
      Maybe for any reason the plug is not installed in the good place?
      • boofredlayB Offline
        boofredlay
        Didier, I am getting the same result as johnsenior1973.
        I have placed the ruby in the Plugins folder but does not show up in the Tools menu.
        Installed in the Plugins folder.
        Not showing up.
          CameronVan
          It is not showing up for me either.
          • utilerU Offline
            utiler
            look under plugins..... [to the left of HELP!!!!] 🀣 🀣 🀣
            sorry, had a little moment there...
            Just Curious...
              boofredlay
              Is that where it shows up for you because it is not there for me?
              Furthermore the pdf file Didier attached said it would be located under Tools, not Plugins.
              Edit:
              Here is part of the pdf just in case you did not read it.
              And yes... I restarted SU.
              • utilerU Offline
                utiler
                You'r right Boo, Tools is where it is.....
                now have a little moment at my expense!!!
                Just Curious...
                • Chris FullmerC Offline
                  It was listed just fine for me on Vista 64bit in the tools menu. Great plugin!
                  Here's a helix, triple helix, double helix, something that isn't a helix, but sort of close, then another 10x helix or something. I'm sure most of those names are wrong, so just look at the picture πŸ˜„
                  M 1 Reply Last reply Reply Quote 0
                    for the problems, maybe you must disable the old "line2cyl.rb"? πŸ˜‰
                    maybe...
                      gaucho
                      Thanks didier!
                      It works great!
                      I've already used... πŸ˜„
                      One single possible request... would be possible to modify so we could extrude along square shapes as well?
                      So in Solo's image above for example, i could quickly build beans, columns.. etc etc.. all square?
                      Thanks again!
                      PS: i've just donwloaded your all in one file... i'm feeling it'll take me ages to check them all...
                      "eat well, stay fit, die anyway..."
                        sepo
                        maybe...
                        for me it works with old tool....
                        Thanks Didier for a very usefull plugin... I was wondering if there is way to clean up intersection...
                        • urgenU Offline
                          urgen
                          ...thanks,Didier!...I expected it for a long time! πŸ˜‰ πŸ˜„
                          --pupil forever...------
                            rv1974
                            Very nice Didier, thanks
                            Additionally may be you could:
                            1/ add a rotation parameter (when precision is 4 one would get square section (rotation 45))
                            2/now I weld lines to get continuous result. Any chance to get it automatically?
                            3/conjunctions?
                            • urgenU Offline
                              urgen
                              maybe...
                              ...yes! "line2cyl.rb" should be deleted πŸ˜„
                              ...Didier, please restore this function in "projection_extension.rb" πŸ˜‰
                                johnsenior1973
                                Deleting the lines2cyl ruby did sort out the problem.
                                • Didier BurD Offline
                                  Didier Bur
                                  Hi all,
                                  Sorry for the inconvenience of the "not showing plugin" problem. My fault. You must delete old "line2cyl.rb" of your plugins folder OR I must correct the name of the plugin in the code (I forgot to change it). If line2cyl is loaded first, SU doesn't create another menu item in the tools menu for the new version.
                                  Use a precision of 4 and you'll get square section prisms.(RTFM)
                                  Does this make sense ? This function has nothing to do with projection IMHO...
                                  The script can't do it (I mean, quite difficult to code). A workaround is to draw as much curves as you can, and select "Yes" in the "follow-me on curves" option. But it cannot clean intersections on T or Y or X branching edges.
                                  Maybe next version will do it ?
                                  DB
                                  • FrederikF Offline
                                    Frederik
                                    THANKS A LOT, Didier..!!
                                    http://www.kerkythea.net//users/Frederik/Anim-Icons/praise.gif
                                    Cheers
                                    Kim Frederik
                                      dylan
                                      Thanks Didier.
                                      Could this be adapted to use a semi-circle with thickness? I am thinking of use for ridge tiles on a roof.
                                      http://dmdarchitecture.co.uk/
                                      • urgenU Offline
                                        urgen
                                        ...HA!...good idea,Dylan! πŸ˜‰ πŸ˜„
                                        • ely862meE Offline
                                          ely862me
                                          πŸ‘ 😍
                                          Another piece of....what????...lets say Pandoras box!!
                                          This will help me to make tubular chassis instead of what i was making before.
                                          πŸ˜‰
                                          Thank you Mr. Didier!!
                                          Elisei
                                          Elisei (sketchupper)
                                          Come and See EliseiDesign
                                          • utilerU Offline
                                            utiler
                                            maybe...
                                            Ditto Sepo, I found the same thing...
                                            Just Curious...
                                            • 1 / 7
