    [Plugin] Lines to tubes
    131 Posts 61 Posters 304.4k Views 61 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      Here is an update of my former script "line2cyl.rb".
      Intended to create renderable wire frame models.
      Some bug fixes and enhancements:
      • Make group of all tubes or not,
      • Each tube is a group or not,
      • Paint tubes with a material,
      • Quick doc included.
      Have fun,
      09.12.08: french version available
      Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=lines2tubes
      lines2tubes.zip
      fr_lines2tubes.zip
      DB
        johnsenior1973
        Thanks a lot for this great new plugin.
        One thing though, the PDF says that the tool can be selected in the Tools menu. That wasn't the case for me. It was in the Plugins menu.
        EDIT: I was wrong. I was using the Lines2Cylinders ruby from the Plugins. I cannot find the Line2Tube ruby at all.
        • soloS Offline
          Thanks mate, works great.
          http://img80.imageshack.us/img80/2408/linetopipewv7.jpg
            A new "hit" for sure 😎
            PS In french "Hit" = tube πŸ’š
            • utilerU Offline
              utiler
              thank didier, just what i need this week.....!!!!
              Just Curious...
                Menu Tool/ Convert arcs, circles, curves, lines to cylinders πŸ˜‰dome.jpg
                  johnsenior1973
                    I don't know what I can say more πŸ˜’
                    Maybe for any reason the plug is not installed in the good place?
                    • boofredlayB Offline
                      boofredlay
                      Didier, I am getting the same result as johnsenior1973.
                      I have placed the ruby in the Plugins folder but does not show up in the Tools menu.
                      Installed in the Plugins folder.
                      Not showing up.
                        CameronVan
                        It is not showing up for me either.
                        • utilerU Offline
                          utiler
                          look under plugins..... [to the left of HELP!!!!] 🀣 🀣 🀣
                          sorry, had a little moment there...
                          Just Curious...
                            boofredlay
                            Is that where it shows up for you because it is not there for me?
                            Furthermore the pdf file Didier attached said it would be located under Tools, not Plugins.
                            Edit:
                            Here is part of the pdf just in case you did not read it.
                            And yes... I restarted SU.
                            • utilerU Offline
                              utiler
                              You'r right Boo, Tools is where it is.....
                              now have a little moment at my expense!!!
                              Just Curious...
                              • Chris FullmerC Offline
                                It was listed just fine for me on Vista 64bit in the tools menu. Great plugin!
                                Here's a helix, triple helix, double helix, something that isn't a helix, but sort of close, then another 10x helix or something. I'm sure most of those names are wrong, so just look at the picture πŸ˜„
                                M 1 Reply Last reply Reply Quote 0
                                  for the problems, maybe you must disable the old "line2cyl.rb"? πŸ˜‰
                                  maybe...
                                    gaucho
                                    Thanks didier!
                                    It works great!
                                    I've already used... πŸ˜„
                                    One single possible request... would be possible to modify so we could extrude along square shapes as well?
                                    So in Solo's image above for example, i could quickly build beans, columns.. etc etc.. all square?
                                    Thanks again!
                                    PS: i've just donwloaded your all in one file... i'm feeling it'll take me ages to check them all...
                                    "eat well, stay fit, die anyway..."
                                      sepo
                                      maybe...
                                      for me it works with old tool....
                                      Thanks Didier for a very usefull plugin... I was wondering if there is way to clean up intersection...
                                      • urgenU Offline
                                        urgen
                                        ...thanks,Didier!...I expected it for a long time! πŸ˜‰ πŸ˜„
                                        --pupil forever...------
                                          rv1974
                                          Very nice Didier, thanks
                                          Additionally may be you could:
                                          1/ add a rotation parameter (when precision is 4 one would get square section (rotation 45))
                                          2/now I weld lines to get continuous result. Any chance to get it automatically?
                                          3/conjunctions?
                                          • urgenU Offline
                                            urgen
                                            maybe...
                                            ...yes! "line2cyl.rb" should be deleted πŸ˜„
                                            ...Didier, please restore this function in "projection_extension.rb" πŸ˜‰
                                            • 1 / 7
