πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin] Lines to tubes
131 Posts 61 Posters 276.0k Views 61 Watching
    Didier Bur
    Hi all,
    Here is an update of my former script "line2cyl.rb".
    Intended to create renderable wire frame models.
    Some bug fixes and enhancements:
    • Make group of all tubes or not,
    • Each tube is a group or not,
    • Paint tubes with a material,
    • Quick doc included.
    Have fun,
    09.12.08: french version available
    Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=lines2tubes
    lines2tubes.zip
    fr_lines2tubes.zip
    DB
      johnsenior1973
      Thanks a lot for this great new plugin.
      One thing though, the PDF says that the tool can be selected in the Tools menu. That wasn't the case for me. It was in the Plugins menu.
      EDIT: I was wrong. I was using the Lines2Cylinders ruby from the Plugins. I cannot find the Line2Tube ruby at all.
        Thanks mate, works great.
        http://img80.imageshack.us/img80/2408/linetopipewv7.jpg
          A new "hit" for sure 😎
          PS In french "Hit" = tube πŸ’š
          • U Offline
            utiler
            thank didier, just what i need this week.....!!!!
            purpose/expression/purpose/....
              Menu Tool/ Convert arcs, circles, curves, lines to cylinders πŸ˜‰dome.jpg
                johnsenior1973
                  I don't know what I can say more πŸ˜’
                  Maybe for any reason the plug is not installed in the good place?
                    boofredlay
                    Didier, I am getting the same result as johnsenior1973.
                    I have placed the ruby in the Plugins folder but does not show up in the Tools menu.
                    Installed in the Plugins folder.
                    Not showing up.
                      CameronVan
                      It is not showing up for me either.
                      • U Offline
                        utiler
                        look under plugins..... [to the left of HELP!!!!] 🀣 🀣 🀣
                        sorry, had a little moment there...
                          boofredlay
                          Is that where it shows up for you because it is not there for me?
                          Furthermore the pdf file Didier attached said it would be located under Tools, not Plugins.
                          Edit:
                          Here is part of the pdf just in case you did not read it.
                          And yes... I restarted SU.
                          • U Offline
                            utiler
                            You'r right Boo, Tools is where it is.....
                            now have a little moment at my expense!!!
                              It was listed just fine for me on Vista 64bit in the tools menu. Great plugin!
                              Here's a helix, triple helix, double helix, something that isn't a helix, but sort of close, then another 10x helix or something. I'm sure most of those names are wrong, so just look at the picture πŸ˜„
                              M 1 Reply Last reply 8 Feb 2025, 13:24 Reply Quote 0
                                for the problems, maybe you must disable the old "line2cyl.rb"? πŸ˜‰
                                maybe...
                                  gaucho
                                  Thanks didier!
                                  It works great!
                                  I've already used... πŸ˜„
                                  One single possible request... would be possible to modify so we could extrude along square shapes as well?
                                  So in Solo's image above for example, i could quickly build beans, columns.. etc etc.. all square?
                                  Thanks again!
                                  PS: i've just donwloaded your all in one file... i'm feeling it'll take me ages to check them all...
                                  "eat well, stay fit, die anyway..."
                                    sepo
                                    maybe...
                                    for me it works with old tool....
                                    Thanks Didier for a very usefull plugin... I was wondering if there is way to clean up intersection...
                                    • urgenU Offline
                                      urgen
                                      ...thanks,Didier!...I expected it for a long time! πŸ˜‰ πŸ˜„
                                      --pupil forever...------
                                        rv1974
                                        Very nice Didier, thanks
                                        Additionally may be you could:
                                        1/ add a rotation parameter (when precision is 4 one would get square section (rotation 45))
                                        2/now I weld lines to get continuous result. Any chance to get it automatically?
                                        3/conjunctions?
                                        • urgenU Offline
                                          urgen
                                          maybe...
                                          ...yes! "line2cyl.rb" should be deleted πŸ˜„
                                          ...Didier, please restore this function in "projection_extension.rb" πŸ˜‰
                                          • 1 / 7
                                          1 / 7
