    Textures won't render
    extensions
    29 Posts 7 Posters 8.3k Views 7 Watching
    • N Offline
      nomeradona
      i think i had the same problem before in cambodia, during our cultural exchange.
      my questions are. are Google sketchup Free version? coz when we downloaded this, some of the textures of google were protected, so when we render using Podium (30days free) became black. but those ousiders textures did not.
        Ben Ritter
        I didn't mean to double post.
        I'm trying to render a carpet material. Texture applied to a normal face, ungrouped.
        Thanks. Ben
          sepo
          Can you upload file somewhere. Would like to try to render it myself.
            Ben Ritter
            Sepo,
            So you're saying that any SU texture should render in Podium, without changing the name or put into the Podium directory?
            Here's the file.
            Ben
            carpet.skp
              sepo
              Yes . I am just downloading the file now so will see.
              • jujuJ Offline
                juju
                I've downloaded and rendered the file. No problems experienced rendering here, except I don't seem to get the pile profile pictured. It looks more like noise, it could be the scale of the image, it does seem to be the scale of the image from the looks of it. What size image did you use? Try not to exceed 1024 x 1024 pixels as SketchUp will automatically reduce it to be max 1024px. Normally 512px is more than sufficient (tip I got from an expert texturer / modeler).
                  sepo
                  needed to reaplly texture as it was applied to backface and flipped. Anyway it renders fine. And just to confirm you Podium will render materials from SU ...as you see them in your model (apart from transparent .png).
                    Ben Ritter
                    Sepo,
                    I don't understand how it could have been applied to the back face, but thank you. I'll give it another try.
                    Juju, thank you too for your help.
                    Ben
                      sepo
                      It could happen like this....you apply material to reverse face....and than discover you have reversed faces... than you flip it and forget to apply to front face. I've seen it before.πŸ˜„
                        Ben Ritter
                        Sepo and Juju,
                        Nope, still renders black.
                        Juju, the texture came with SU.
                        Ben
                          Ben Ritter
                          I tried several of the SU textures. I can only render the colors, the rest seem to render black.
                          Any other ideas?
                          Ben
                          • jujuJ Offline
                            juju
                            Have you tried uninstalling and reinstalling Podium from fresh?
                            • FrederikF Offline
                              Frederik
                              I seem to recall having had a similar issue when exporting a model using the free Google SU with only the standard material package installed... (the package, which is installed together with GSU)
                              I suggest you download the Materials Bonus Pack and try seeing how this will work...
                              Cheers
                              Kim Frederik
                                Ben Ritter
                                Juju, may have to try that.
                                Frederick, I'm using the Pro version and I did install the bonus pack.
                                Thanks guys.
                                Ben
                                  sepo
                                  Ben can you tell me do you have mac or windows version?
                                  • FrederikF Offline
                                    Frederik
                                    Could it be that your textures are placed in a folder or sub-folder (meaning the entire string) containing a non-standard letter..??
                                    (something outside the English alphabet...)
                                    I'm guessing here, since I can't grasp why you can't make this work... πŸ˜•
                                    Cheers
                                    Kim Frederik
                                      sepo
                                      Ben...could you call back to Podium forum....It will be solved much quicker over there.
                                        Ben Ritter
                                        Sepo, I'm running the windows version.
                                        Frederick, the textures is coming from the materials folder under the SU program folder. No unusual characters in the folder name.
                                        Thanks again guys. Ben
                                          sepo
                                          I would have prefered to deal with it on Podium forum but ok....tell me what you have in your Podium folder in plugins.
                                          • FrederikF Offline
                                            Frederik
                                            OK... Then I'm out of ideas... 😐
                                            I'm sure Sepo will be able to help you out here...
                                            Perhaps you should take his advice and continue this on the Podium forum... πŸ˜‰
                                            Cheers
                                            Kim Frederik
