Textures won't render
extensions
29 Posts 7 Posters 7.8k Views
    Ben Ritter
    After reading the Podium help files, I still can't get some textures to render in SU Podium, they render black.
    My faces are all normal. What am I missing? Do materials need to be in a special folder?
    Ben
      juju
      Ben, this is a better place to post your question than the double posting in the SketchUp Discussion forum.
      Is it possible for you to post a screen captured image of the problem before and after you've rendered with Podium?
        sepo
        Ben you can also post it on the Podium forum... Ideally would like to see the file as well...
        • E Offline
          Edson
          could it be that you assigned the texture to a group? this causes unpredictable results.
          http://www.mahfuz.arq.br
          • N Offline
            nomeradona
            i think i had the same problem before in cambodia, during our cultural exchange.
            my questions are. are Google sketchup Free version? coz when we downloaded this, some of the textures of google were protected, so when we render using Podium (30days free) became black. but those ousiders textures did not.
              Ben Ritter
              I didn't mean to double post.
              I'm trying to render a carpet material. Texture applied to a normal face, ungrouped.
              Thanks. Ben
                sepo
                Can you upload file somewhere. Would like to try to render it myself.
                  Ben Ritter
                  Sepo,
                  So you're saying that any SU texture should render in Podium, without changing the name or put into the Podium directory?
                  Here's the file.
                  Ben
                  carpet.skp
                    sepo
                    Yes . I am just downloading the file now so will see.
                      juju
                      I've downloaded and rendered the file. No problems experienced rendering here, except I don't seem to get the pile profile pictured. It looks more like noise, it could be the scale of the image, it does seem to be the scale of the image from the looks of it. What size image did you use? Try not to exceed 1024 x 1024 pixels as SketchUp will automatically reduce it to be max 1024px. Normally 512px is more than sufficient (tip I got from an expert texturer / modeler).
                        sepo
                        needed to reaplly texture as it was applied to backface and flipped. Anyway it renders fine. And just to confirm you Podium will render materials from SU ...as you see them in your model (apart from transparent .png).
                          Ben Ritter
                          Sepo,
                          I don't understand how it could have been applied to the back face, but thank you. I'll give it another try.
                          Juju, thank you too for your help.
                          Ben
                            sepo
                            It could happen like this....you apply material to reverse face....and than discover you have reversed faces... than you flip it and forget to apply to front face. I've seen it before.😄
                              Ben Ritter
                              Sepo and Juju,
                              Nope, still renders black.
                              Juju, the texture came with SU.
                              Ben
                                Ben Ritter
                                I tried several of the SU textures. I can only render the colors, the rest seem to render black.
                                Any other ideas?
                                Ben
                                  juju
                                  Have you tried uninstalling and reinstalling Podium from fresh?
                                  • F Offline
                                    Frederik
                                    I seem to recall having had a similar issue when exporting a model using the free Google SU with only the standard material package installed... (the package, which is installed together with GSU)
                                    I suggest you download the Materials Bonus Pack and try seeing how this will work...
                                    Cheers
                                    Kim Frederik
                                      Ben Ritter
                                      Juju, may have to try that.
                                      Frederick, I'm using the Pro version and I did install the bonus pack.
                                      Thanks guys.
                                      Ben
                                        sepo
                                        Ben can you tell me do you have mac or windows version?
                                        • F Offline
                                          Frederik
                                          Could it be that your textures are placed in a folder or sub-folder (meaning the entire string) containing a non-standard letter..??
                                          (something outside the English alphabet...)
                                          I'm guessing here, since I can't grasp why you can't make this work... 😕
                                          Cheers
                                          Kim Frederik
                                          1 / 2
