    The one thing in Sketchup that WILL drive me nuts!
    17 Posts 8 Posters 2.7k Views 8 Watching
    • T
      toxicvoxel
      Before I post this to Google HQ and in the bug list can somebody see if they have the same problem with shadow info on pages in this file:
      (read the text file to replicate the error)
      This recurs on files from time to time making the page setups in the file useless for future use.
      If anybody has a solution or work-arround I would be happy to hear from you.
      Shadow_Info_Error.skp
      Shadow_Info_Error.txt
      • ToboboT
        Tobobo
        I have had the same issue with a few of my models not sure what the solution is. Sorry I couldn't help, but at least we are not alone
        Toby
        Philippians 4:13
        • DavidBoulderD
          DavidBoulder
          Yep, your test files have same results on my mac.
          I've had similar issues to this where scene is fine in SketchUp, but that scene placed in Layout exhibits odd shadow behavior.
          David Goldwasser
          OpenStudio Developer
          National Renewable Energy Laboratory
          • H
            HFM
            unmark the 'shadow Settings' in scene manager on each tab, activate shadow settings, click around so the shadow will update and voila! 😍
            after these steps turn back on the shadow Settings in the scene manager and your done
            • C
              caronte01
              I have a file that has that problem also. I believe it has something to do with having different north orientations on different views.
              • T
                toxicvoxel
                HFM,
                ....after these steps turn back on the shadow Settings in the scene manager and your done
                It works until you close the file down and reopen it. When you activate the tab it's the same old problem.
                Or am I misunderstanding your instructions?
                Carento01,
                North is consistently oriented in all tabs so I doubt if that is the problem.
                Thanks for your input anyway.
                • Chris FullmerC
                  I got it!
                  Turn on animation between scenes. You can put it down to "0" if you'd like, but this will fix it.
                  That being said, I have no idea why this is. I'm guessing its an odd glitch inside the file, perhaps having to do with how it was created. But maybe not, maybe it can happen in any SU file.
                  I noticed you had a custom location set based on long/lat. Did that get imported with some cad or GIS program? or did you input it?
                  This is an odd bug. I'll keep playing with it and see if I can recreate it from scratch so it can be submitted to Google with complete steps. Or maybe they can look at the insides of the file to see what is being messed up when the animation on/off gets switched. Anyhow, cool bug.
                  • Chris FullmerC
                    ok, I am totally able to recreate this.
                    1. Make a simple box model.
                    2. Turn off animation between scenes.
                    3. Change location from default. I am using something in the UK. I'll test later to see if that is necessary. I'm thinking it might be since its on the other side of the world from the default Boulder, Colorado, USA location.
                    4. Turn on shadows and set it to morning.
                    5. Make a scene.
                    6. Change shadows to evening and make a new scene.
                    7. Save model
                    8. Close and re-open.
                    9. click on scenes and at least one will be messed up.
                    OK, I just tested it using Boulder as default location. It doesn't mess up the way it does if you use something around the world. There is something quirky here and it appears to have to do with the custom location, or the country selected or the time zone. I haven't been able to pin this one down 100%, but at any rate, its not behaving as desired.
                    • H
                      HFM
                      @toxicvoxel said:
                      HFM,
                      Carento01,
                      My fault entirely, didn't check that πŸ˜•
                      • T
                        toxicvoxel
                        Chris,
                        You're the man! - Activating animations fixed it.
                        Thanks for taking the time to look into it.
                        And yes the custom location was set up in SU.
                        • C
                          caronte01
                          Chris, cool, that solves it. In my file I have a custom location also....
                          • plot-parisP
                            plot-paris
                            Chris, I am impressed how systematically you tracked down the bug. well done! πŸ‘
                            • ToboboT
                              Tobobo
                              So just to clarify,
                              It only happens when you set the page transitions to 0?
                              Toby
                              Philippians 4:13
                              • Chris FullmerC
                                Glad it fixed the problem for you Toxicvoxel and Caronte01. I'd imagine its not the kind of bug they would find in Boulder since it seems to require the location or country or something be set around the world AND have animations turned off. Kind of a sly little bug.
                                Ahh, thanks Jakob (plot-Paris). Yeah, after working on figuring it out I had about 20 versions of the file saved to my desktop where I had tried different methods to fix it. Then once I did finally fix it, I had tweaked so many settings it took a while to figure out which setting was really the offender. I'm still not 100% sure where the problem lies, but like I said, its something to do with the custom location when u have turned off animation.
                                So to clarify, its not when animations are set to 0, its whent hey are turned off completely. A workaround if you don't want animations on is to turn on animations but set them to zero. That will make it appear as though animations are off, and it will not bug the shadows system.
                                • T
                                  toxicvoxel
                                  In the mean time I received this response from Google support which is a little disappointing because it doesn't fix the problem.
                                  They seem to think page shadow information is saved in the style definition!
                                  Google Help
                                  to me
                                  show details 7:40 PM (3 hours ago)
                                  Thank you for your note. We understand you're encountering some problems
                                  with shadow information on page tabs. We've evaluated your file, and it
                                  appears as though you aren't saving style information before saving and
                                  closing the SketchUp file. SketchUp can automatically prompt you to save
                                  these settings if you browse to "SketchUp" > "Preferences" > "General" and
                                  check the option to "Warn of style change when creating scene." When you
                                  update your scene you'll be prompted with a warning message, and you'll
                                  want to "Update the selected style" then update the scene. Alternatively,
                                  if you have the Styles menu open, you'll see a circular arrow pair in the
                                  top left corner indicating that your new style hasn't been saved. Once we
                                  saved your scene, the shadow information appeared to work correctly
                                  between tabs.
                                  If you need further assistance, please let us know.
                                  Regards,
                                  The Google Team
                                  • Mike LuceyM
                                    Mike Lucey
                                    100% Chris, Well done πŸ‘
                                    Its great to have so many experts here πŸ‘
                                    Mike
                                    • Chris FullmerC
                                      Ahh, thanks Mike.
                                      Well, I agree, that response from google is a bit underwhelming because that was the very first thing I tried too and it definitely does not work.
                                      I'll see if I can drum up a bit more support from them for you. I think this is a great bug that should be looked at.
