    Problem with export: materials
    23 Posts 7 Posters 3.8k Views 7 Watching
    • Y
      Yorky5
      Pls try again now, content should no longer be protected,...
      many thanks
      http://lookatimages.files.wordpress.com/2008/08/11.jpg
      http://lookatimages.files.wordpress.com/2008/08/21.jpg
      http://lookatimages.files.wordpress.com/2008/08/31.jpg
      http://lookatimages.files.wordpress.com/2008/08/41.jpg
      http://lookatimages.files.wordpress.com/2008/08/52.jpg
      • GaieusG
        OK, there are two problems here basically:
        1. back (bluish grey) faces: this is a modeling problem - right click on it and "Reverse faces". If unwanted faces also reverse (to grey), turn on hidden geometry (View menu) and do it with individual faces.
          In many external rendering softwares these reversed (back) faces do not render at all.
        2. UV mapping. This is tricky in SU as it does not have good mapping tools. On the cylinder part you can try this:
        3. turn on hidden geometry (see above)
        4. right click on one of the facets > texture > position > hit enter
        5. now sample it with the Allt+Paint bucket (=Eye dropper) tool
        6. turn off hidden geometry
        7. paint the cylinder.
          On the bending part this will not work properly however, there (or on the whole pipe) you can try the "Project" submenu item at step b) instead of position but I doubt that you will get a proper projection (If you knew how much I tried with simple arches!).
          REGIS
          Hi Yorky
          I've seen your post on Cheetah3D forum (I use C3D too)
          Why the arc is grey and not white ?
          It depens on the color of the face you select to use follow me :
          The face you click on with follow me tool is grey so the result is white
          The face you click on with follow me tool is white so the result is grey
          I think you've got to keep your mesh untextured and try to use Cheetah 3D unwrap tool to have a nice result on the arc.
          regards
          ( just a question : do you speak french Yorky )
            REGIS
            Hi Yorky
            I made a little try
            In sketchup
            exporting at fbx format keep the faces non triangulated if they aren't in sketchup
            rendered with Cheetah3D ( very fast and basic )
            regards
            • Y
              Yorky5
              @regis said:
              Hi Yorky
              I made a little try
              In sketchup
              [attachment=1:3mhs2w0s]<!-- ia1 -->texture arc.jpg<!-- ia1 -->[/attachment:3mhs2w0s]
              [attachment=0:3mhs2w0s]<!-- ia0 -->essai texture arc.jpg<!-- ia0 -->[/attachment:3mhs2w0s]
              regards
              Hi, thx all,
              There seems to be no 'voodoo' solution for texturing arc-stuff... I still believe that sketchup makes a mess with polygons, unless i do something terribly wrong...
              Gaieus, i tried your advice... it's still not the wanted result. Maybe someone could write some tutorial about the best way to model an arc, texture and render it the right way... I guess sketchup can't do better, and that the UV-mapping should be done in your favorite 3d program.
              In the cheetah3d forum, Frank Beckman suggests his method... http://www.cheetah3d.de/forum/showthread.php?t=3363
              Regis: je ne parle pas le français, en petit peu 😉 Some people texture in sketchup and tweak it in cheetah (like Peer in the c3d forum), you texture completely in cheetah? Can you pls explain your last post? What do you mean or suggest?
              Regards,
              Yorky
                REGIS
                Hi Yorky
                the first image shown before is the model textured in SU and the second is the model exported at fbx format and just rendered within Cheetah3D.
                I would like to learn UV mapping within C3D but at the moment, I don't know hpw to like Frank Beckmann.
                If I've got time I can make a little video showing how to tecture an arc ( 🤢 lot of time consuming )
                regards
                • Y
                  Yorky5
                  That would be wonderful! I know it's time consuming ;-( ,but the upside is that you learn instead... So, if you have some time left
                  and start this tut, let me know, i (and many other) would really appreciate. Screencapturing (like 'ishowu') is pretty easy.
                  greetings,
                  Yorky
                  • bigstickB
                    bigstick
                    There are some good video tutorials on YouTube dealing with texturing that might help you. This (http://www.youtube.com/watch?v=NV0mLPQDcJ4&feature=user) is one. This (http://www.youtube.com/watch?v=HHsRRLCAOm8&feature=related)is another.
                      REGIS
                      OK Yorky
                      I'll do a video screen capture this week end.
                      I don't know about IshowU but i like a lot ScreenFlow.
                      regards
                      • Y
                        Yorky5
                        Thx for the link!
                        @regis said:
                        OK Yorky
                        regards
                        You'r the man!
                        this one is nice too: http://www.youtube.com/watch?v=ILnIbp509cY&NR=1 (will try it later...)
                        yorky
                        • Y
                          Yorky5
                          @regis said:
                          OK Yorky
                          regards
                          any succes yet?
                            REGIS
                            Sorry, I haven't forget it, I've got a very big "to do list" on my desk so when I've got a moment ...
                            regards
                            • 2 / 2
