    Please help me please, Model Downloads
    extensions
    19 Posts 4 Posters 3.2k Views 4 Watching
    • FrederikF
      Frederik
      I'm sure that you're un-zipping the libraries to the wrong folder... ๐Ÿ˜‰
      I have 2 simple suggestions for you... ๐Ÿ˜‰
      1.) Please download and read the Getting Started tutorial...
      On page 5 you can see how you should install these model libraries... ๐Ÿ˜‰
      You can rename the file-extension of all the zipped model libraries you can download from the KT Download area to end on .mod.zip and use the File > Install Library... function to install these libraries...
      2.) Please visit the KT Forum, where you can find answers to many of your questions and if you post a new question, many helpful users will give you their expert advice... ๐Ÿ˜‰
      Hope this can help you further... ๐Ÿ˜„
      Cheers
      Kim Frederik
        StarWarsKnower
        Thanks, I did put them in the right folder, but oh well, I'll just change the extension then install them.
        Mike
          StarWarsKnower
          Okay, they all work but 2 model libraries. But here's the problem. In my Insert>Model>... menu, there are the two library names, but no picture next to them and no models in them. I have the correct mod.zip's but I can't install them because it says there is already the model libraries with that name. The model library's arent in the Kerkythea Render System> Models> ... folder. How can I uninstall the libraries, so I can then re-install the working libraries?
          EDIT: Also I searched the Kerkythea Render System folder for 'Xfrog' and it found nothing. Where are the models that are installed via a mod.zip kept? Because then I can delete it.
          Mike
            StarWarsKnower
            Hello all, I have been a big hassle to you all by asking lots of questions and sorry. But I now declare that everything I wanted to know I now know, and every problem I had is now fixed so YAY!
            EDIT: Because I'm clever
            EDIT: okay maybe not...
            Mike
              StarWarsKnower
              Okay, I have another question about textures, is there anyway to place textures on a model but on separate faces. So I have a chair that I downloaded, but the arms, the stand and the fabric are all the same white texture, can I get a different texture for the arms the stand and the fabric?
              Mike
              • GaieusG
                You have to do that in SU. Then you can tweak your different textures in Kerkythea but you cannot split anything by geometry there once they have the same texture.
                Kerkythea makes difference between everything only by texture, not geometry.
                • FrederikF
                  Frederik
                  Gaieus is right...!
                  You need to apply the textures to the geometry in SU...
                  This is also known as UV Mapping... ๐Ÿ˜‰
                  Once you've applied a texture to your model, you can replace the texture in KT...
                  Please also see page 16-22 in the Getting Started tutorial... ๐Ÿ˜‰
                  Same applies for all other render applications as far as I'm aware... ๐Ÿ˜‰
                  Cheers
                  Kim Frederik
                  • GaieusG
                    I think you can adjust texture features on faces and groups in Podium (well as far as I remember from about a year and a half ago ๐Ÿ˜„ )
                    • FrederikF
                      Frederik
                      Podium is working inside SU, so you still adjust the texture in SU... ๐Ÿ˜‰
                      Cheers
                      Kim Frederik
                      • GaieusG
                        You always have an answer, Kim! Until...
                        http://users.atw.hu/swb/smile/bunko.gif
                        http://users.atw.hu/swb/smile/vigyor1.gif
                        • FrederikF
                          Frederik
                          ๐Ÿคฃ Yeah... Know what you mean, Csaba... ๐Ÿ˜‰
                          Eventually you'll get me on something - I'm sure... ๐Ÿ˜„
                          Till then... ๐Ÿ˜† ๐Ÿ˜†
                          Cheers
                          Kim Frederik
                            StarWarsKnower
                            Yes but can you move your model from kerkythea to sketchup. Because otherwise, those chair models I just downloade were completely useless because they are all the same textures all over.
                            Mike
                              Jon
                              No.
                              Plan ahead. ๐Ÿ˜†
                              But the merge function might help you...
                              You can export a second chair model with proper materials from SU and merge it into KT (File > Merge). You can do the same with lights, cameras, whatever you like.
                              Try making a search for more info. ๐Ÿ˜‰
                              Jon
                              KT Team member
                                StarWarsKnower
                                I want to use the chair models i downloaded. I cant open them in Sketchup because it is just a .mod.zip with crap that SU cant open in it. I dont want a chair that is just white, i want different textures on different bits, whoever made the model was a bit of an idiot if you can only have the chair in one colour and not different colours for different bits.
                                Mike
                                • FrederikF
                                  Frederik
                                  @starwarsknower said:
                                  ...whoever made the model was a bit of an idiot...
                                  Hey, hey, hey... What kind of tone is this..?? ๐Ÿ˜ฎ
                                  The models are made available for you to use free of any charges, so please show a little gratitude or find your own 3D models... ๐Ÿ˜ก
                                  If you had just spend a little time, you would be able to find the models made for SU...
                                  You can get the models from the Fritz Hansen Content thread... ๐Ÿ˜
                                  Cheers
                                  Kim Frederik
                                    StarWarsKnower
                                    Sorry if that came out wrong, I didn't mean to call the guy an idiot, what I meant was it's stupid not being able to have materials on the model.
                                    Mike
